Question about Honda Quincy 17 - Gallon Air Compressor with 5.5 Hp - G15H17PC3B
Installing push rod guide
How do you Install push rod guide on Honda 5.5 160GX Motor?
    President:
  • Honda Master
  • 1,388 Answers
I have worked on many gx160 engines and have found that the most economical way to repair an engine with worn valves/guides is to replace the complete head with a clone usually available on ebay for around 60 bucks or so. A honda gx runs perfect with a new clone head. To repair the head properly you need special tools to cut/shape re-seat etc. Then when you consider the cost of honda parts and the chance of making an error, well even the best small engine mechanics make bad calls. However on the other hand, there is great pleasure in rebuilding an engine that has given you great service. Small engine parts/supply outlets like Rotary inc. sell valve guide cutter kit that comes with instructions. You should also use new valves and cut the valve seats.(another kit) If all you want is a great running motor, consider the clone head. Good Luck on your project.
Posted on Jan 30, 2009
    Scholar:
  • 149 Answers
Do you want to replace the valve guide or push rod guide?
If its the push rod guide, loosen the 10mm nut on top of the 14mm nut and remove both of them and the valve rocker...now get a long deep 10mm socket and remove the valve rocker stud on both valves.remove the plate take note of which way the plate goes, reassemble in reverse and reset the valve clearance to .15mm intake and .20mm ex. make sure the piston is at TDC and the valves are closed if you dont know if they are closed turn engine over slowly and you will see the valves rock (intake thenex straight away) then turn engine over 1 turn....
keep the valves clearance correct and you wont have this problem..Check the rocker for wear on the part that pushes the valve open it should be flat if not the valve may be US as well...
Posted on Feb 27, 2009
How to install tensioner roller guide honda wave 100
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
How to install tensioner roller guide honda wave 100 Google Search
Part 19 4 stroke installing cam timing chain tensioner YZ250F example
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
http://www.partsfish.com/page/oem-parts-for-honda
Honda Wave 110i User Manual
Oct 26, 2013 | Honda NF 100 Wave Motorcycles
Installing push rod Mitsubishi Eclipse
The engine is a overhead cam engine so no push rods are fitted
the first thing to check will be the starter motor solenoid then the starter motor for operation
anything else will require the engine to be removed to check the timing and why the engine won't crank
Sep 07, 2017 | 2002 Mitsubishi Eclipse Spyder
Got a problem with pushing my push rod up so I can install new fuel pump on 1978 chevrolet half ton truck, to slippery. It is a Chevrolet Cheyenne 1000 which is not listed
You will see a bolt on the front of the block which is removed and replaced with a longer bolt to hold the fuel pump push rod in while installing the fuel pump. It will be a 3/8" threaded bolt
Sep 03, 2011 | Chevrolet 1500 Cars & Trucks
We need to remove the drives side head rest to install a seat cover, but we cannot figure out how to remove the head rest. How do you remove the driver's side head rest?
Head Restraints Removal
  1. Unscrew front seat head rest guide rod retainers (610A18) .
  1. Pull up on front seat back head restraint (611A08) . Compress foam in area of front seat head rest guide rod sleeves (610A16) .
  1. Remove front seat back head restraint positioning springs. Pull front seat back head restraint up and out.
Installation
  1. Slide front seat head rest guide rod retainers onto front seat back head restraint posts.
  1. Compress foam in front seat head rest guide rod sleeve area. Install positioning springs on front seat head rest guide rod sleeves .
  1. Insert front seat back head restraint posts (notches on posts facing rearward) into front seat head rest guide rod sleeves and push down to engage positioning spring.
  1. NOTE: Front seat back head restraint must operate smoothly throughout its range of travel, must remain in any fixed position, and must not be freely removable from the seat back. If any of these conditions are not met, check for proper installation of positioning spring onto front seat head rest guide rod sleeve .
    Tighten front seat head rest guide rod retainers onto front seat head rest guide rod sleeves .
  1. Adjust front seat back head restraint by applying hand pressure, either up or down, to center area of front seat back head restraint .
Aug 21, 2010 | 1998 Ford Taurus
Replace window motor on 1997 del sol
Remove the door handle with one #2 phillips screw, push forward. Push the 2 plasic clips on the release handle and the lock rod by rotating them away from the open end of the clip (clockwise for drivers side, counterclockwise for passenger side). Pull the lock rod and relese out of the clips. Remove the phillips screw in the bottom of the door grab handle. Remove the small black plastic piece on the upper forward corner of the door panel. Remove door panel, should be aproximately 10-12 clips. Once off, you'll see the window motor. Remove the outer window trim. Yes, you WILL break all the clips. I've not had much sucess no matter how careful I am. Use a 10mm wrench or socket to remove the window from the window regulator. You'll see 2 white plastic wedges with 10mm head bolts in them. Pull the window out of the track. If needed, loosen or remove the rear guide track. There also are two 10mm bolts holding the guide rail in. Remove the windoe regulator and motor assembly with (I believe) 3 10mm bolts. Once on the bench, remove the motor from the regulator and reinstall!
Dec 08, 2009 | 1997 Honda Civic del Sol
Briggs motor bent one push rod
This is a vary commom problem with an Intek engine, I have a similar 21HP engine with similar issue. The valve is sticking in the valve guide, the valve guide usually slides in or out. If out, the guide can jamb against the keepers and not allow full valve opening, thus bending the rod. Fix the loose guide and tight valve before you put in another rod, or you will soon be putting more rods in. I think B&S should help everyone on this one. If the guide goes in, it can cause the valve not to close fully and cause a no run condition.
Sep 14, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Honda GX160 Valve Guide Displaced
You may not need to replace the head but a new valve guide may be called for. That will require the proper tool for installing it, so it runs in line with the valve stem.
Aug 22, 2009 | Garden
I have crafsman 48" riding mower with a 24 hp intek motor
Bent push rods are a function of the valve guide coming loose in the head. The valve binds and you end up with a bent pushrod. Fix: Replace head. $94.00
Jul 13, 2009 | Briggs & Stratton Briggs Stratton Intek V...
How do you remove the headrest on a 1996 ford crown victoria?
Head Restraints Each front seat is equipped with dual-post design front seat back head restraint (611A08). The front seat back head restraint is installed as follows:
  • It travels on dual posts which have notches to engage a spring-loaded catch in the guide.
  • The front seat back spring assembly retains the front seat head rest guide rod sleeve (610A16).
  • The front seat back head restraint is adjustable from its normal position to a raised position of approximately 25 mm (1 inch).
  • Pull up on the front seat back head restraint to raise it. Pushing down will return it to its normal position.
Removal
  1. Unscrew front seat head rest guide rod retainers (610A18).
  1. Pull up on front seat back head restraint (611A08). Compress foam in area of front seat head rest guide rod sleeves (610A16).
Installation
  1. Compress foam in front seat head rest guide rod sleeve area. Install positioning springs on front seat head rest guide rod sleeves.
  1. Tighten front seat head rest guide rod retainers onto front seat head rest guide rod sleeves.
  1. NOTE: Front seat back head restraint must operate smoothly throughout its range of travel, must remain in any fixed position, and must not be freely removable from the seat back. If any of these conditions are not met, check for proper installation of positioning spring onto front seat head rest guide rod sleeve.
    Adjust front seat back head restraint by applying hand pressure, either up or down, to center area of front seat back head restraint.
Mar 01, 2009 | 1996 Ford Crown Victoria
Honda Quincy 17 - Gallon  Air Compressor with 5.5 Hp - G15H17PC3B Logo
571 people viewed this question
Top Honda Air Tools & Compressors Experts
John Trevino
Renee Knafel-Bullock
Are you a Honda Air Tool and Compressor Expert? Answer questions, earn points and help others
