Question about Panasonic KX-T7630 Corded Phone
Can't change ringtone
Changed personal (ring of my phone) ringtone and can't change it back. Followed directions in book but doesn't work. Technician was here when I did it and I don't remember doing it the way it is in the book
Lisa- Atlanta
  • lwatson171 Jan 30, 2009
    That didn't work. What I found out was that the annoying ring was coming from line 1. To correct the problem you do the same thing but instead of pushing intercom twice you press line 1 twice then enter to save it. It was a long and winding road to get this problem solved but I am now very happy. :>)
  • Panasonic Master
  • 2,460 Answers
This one is sort of easy, but I can't find it in the manual. It's somewhere, but here's the deal. Each line or the intercom can have 30 different rings. It's programmed by PROG press the button twice, and dial a 2-digt number from 01-30 or use the navigator up/down button to change it, and ENTER to save it.
If you happen to have 72/74xx phones on a TDA, you only have 8 tones.
Posted on Jan 30, 2009
  • Carl Navarro
    Carl Navarro Jan 30, 2009
    P.S. The default is 01 :-)
  • Carl Navarro
    Please reconsider the rating. I gave you the correct answer. EACH LINE OR INTERCOM CAN HAVE 30 DIFFERENT RINGS.
    I would rate that a FixYa :-)
Change ring tone
How to Change the Ring on a Motorola V360
When you change the ring on your Motorola V360 from the standard ring to another of your choice, you give the phone a personal touch. Rings, or ringtones, are included with your phone. You can also download and install ringtones from a mobile content provider or your mobile service provider. The ring you select sounds anytime you receive an incoming call. You can change the ring at anytime through the Motorola V360's settings menu.
1.Press the "Menu" key on your Motorola V360 and click "Settings."
2.Click "Ring Styles" and select "Style Detail."
3.Highlight "Calls" and press the "Change" soft key.
4.Highlight the ring you want to use on your Motorola V360. When highlighted, a brief preview of the ringtone will play.
5.Press the "Select" soft key to choose the ringtone.
6.Press the "Back" key to set the ringtone on the Motorola V360
Read more: How to Change the Ring on a Motorola V360 '
---a score of 4 is highly appreciated----- ---if you think this resolution is helpful kindly click on "YES"---- ---you may also leave testimonial-----
Thank you for choosing fixya
Sep 07, 2011 | Motorola Mobility V360 Cellular Phone
How can i change the "ringtone's message" of my corby GT-s3650
Here's how you can change the ringtone/ message tone:
  1. Go to Menu
  2. Settings
  3. Phone profiles
  4. Edit Profile Name (this will be dependent on the profile that you'll use)
  5. Go to the right "New Messages"
If you want them to be personalized per contact, you will need to access the phone book, go to the specific contact then personalize the message tone or ringing tone
Nov 24, 2010 | Computers & Internet
No sounds for alarm texts calls or windows media
Mine did that and I just changed to profile and changed it back to normal and it worked. I hope it helps
Jul 21, 2009 | Motorola Mobility Moto Q
I was given a phone and would like to change the ring. ??
You need to go to the 'Profiles' option. It will be inside the 'menu' option. select 'profile', then select 'personalize'. You will find an option of ringtone there. Select that, and choose ringtone from your gallary. Once you are done with that, save the changes. Then again go to the 'profiles' option again and select 'activate'. Your phone will play the new ringtone.
Jul 11, 2009 | Lands Phones
I'm trying to set a unique ringtone/sound for individual callers. Even though I select Brass Call for my husbands number it still plays the Settings/Ring Style/Loud Detail/Line 1 sound (Yummy). How do I...
I had the same problem, then decided to see whether it would make a difference if I deleted that person's manual entry and instead stored the number and name,etc, from the recent received call lists. I set my parameters as I wanted, including the ringtone I wanted, and voila ! It works now ! So, store them from the logged call when the person has called you and it should work !
Jul 04, 2009 | Motorola Mobility MOTOROKR EM330 Cell...
When i set a ringtone for a particular contact it will ring as the ringtone i set for the whole phone why is it
It shouldn't use your custom rigntone as the default - which is what it sounds like is happening.
How are you setting the custom ringtone - is it from options in the address book or profiles?
Check the ringtone set in profiles and random custom ringtones in address book/ "Contact A" options. Check at least one that you have changed and another that you haven't to see the difference in your settings.
May 19, 2009 | RIM BlackBerry Pearl 8100
Ringtone problem
U can only assign any mp3 ringtones only if it is placed in Phone memory. U need to make phone memory as default storage device. U can do it by going to options when in multimedia->pics/sounds/video clips.
Send me a feedback and rate my solution too.
Dont forget to post a clarification request for ur problem after it is solved.
May 17, 2008 | Motorola Mobility RAZR V3
Ringtones for caller id
To assign ringtones, you need to make sure the entries are stored to the phone, and not to the SIM card. To check where it's stored, go to the phone book, select the name of the person you want to personalize (ring tone, picture, etc), and click edit. In the Entry Details screen, the Store to: option probably says SIM. Change it to Store to: Phone. After you do that, there should be alot more info you can put in for the person. Near the bottom is "Ringer ID" and "Picture" which you can then customize for the person.
Hope that helps!
Apr 25, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Dumb question but applying ringtones
first the telephone number must be storage in the phone not only in the smart chips in case your phone use one ok lets go ,,
address book, choise the person, press" view", then "edit" scroll down to "ringer ID" and press change, and scroll to the desire ring tone and press select.... you didit.....good luck and rate me
Dec 31, 2007 | Motorola Mobility RAZR V3
Voice sound has gone on phone (but ringtones and all other sound working).
there is problem inside ur phone. the speaker which gives sound to listen in caller's voice that has spoiled. take it to technician it need to be replaced
Jul 02, 2007 | Panasonic G50 Cellular Phone
Panasonic KX-T7630 Corded Phone Logo
154 people viewed this question
Top Panasonic Lands Phones Experts
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
