Question about Motorola Mobility RAZR V3
Number 2 presses itself
Hi, any advice on how I can fix my V3? as soon as it opened its as if the number 2 is being pressed continually, or sometimes it goes straight to browser without me pressing any buttons. If solution is to open the phone up, then any advice about how to do that would be helpful as well. Thanks
Replace the lcd flex cable which also contains the keypad, it's a v ery common problem.
Posted on Jul 30, 2007
  • Anonymous Jul 30, 2007
    Note, this requires removing the electronics, flip cover, separating the flip from the body, removing the silver keypad and tearing out the old flex (it's tack glued to the body). You reassemble by first feeding the "ends" of the new flex at the top (two ends, lcd cable and flip sensor), peel the backing off being careful not to let the flex contact the body just yet. Use round toothpicks from the bottom to align and hold the flex, the flex and body have two alignment holes (the alignment is extremely important) feed the lower ends of the flex through the body (board contacts and microphone). Finally remove the toothpicks from the back, one at a time, insert them on the flex side lightly (no glue contact yet). Make sure everything is straight, you must have clearance on the outer edges of the flex to reinstall the silver keypad. When satisfied with alignment, press flex into place and reassemble the phone. If you do this yourself, buy two flex cables, it's easy to ruin a new one. (Note, after disassembly just before ripping out the old flex you can test with a new flex to make sure it truly is the problem, requires acrobatic ability.)
6ya staff
SOURCE:
I have a brother MFC 7340. I have replaced the drum unit and reset the counter. Even I tried to clear the memory by *00. Still when I switch on the the machine display comes as "change drum soon". Pl
The instructions you were given to clear the drum message are incorrect.
  1. Open the Front of the machine.
  2. Machine will say "Front Cover Open"
  3. Press the Clear Button
  4. Machine will say "Replace Drum 1. Yes 2. No"
  5. Press the number 1
  6. Machine will say "Accepted"
  7. Close the Front Cover
Jan 14, 2015 | Brother Office Equipment & Supplies
When I press certain keys like P I get 6
This is yoru number lock function
look along the "F" key row for the NumLk or picture of the number 1 in a square. then hold down the Fn key on the lower left of the board. press the "F" key that corresponds to it and this will disable it.
Feb 18, 2010 | Acer NSK8458AN Keyboard
I NEED TO RE-PROGRAM PRESET NUMBERS, BUT DON'T HAVE MANUAL FOR CANON L350 FAX MACHINE?
Open panel cover Press DATA REGISTRATION Press V to display 2. TEL REGISTRATION Press SET twice Press V (if necessary) until an empty space appears Press SET twice Enter Fax number Press SET twice Enter name using number keys (e.g. 2 = A,B,C like a mobile phone) Press > to enter next letter Press SPACE to enter a space Press * to enter a numeric Press SET To continue press DATA REGISTRATION Repeat steps 5 to 10 To end press STOP
Feb 09, 2010 | Canon FAX-L350 Plain Paper Laser
HOW DO I CHANGE A SPEED DIAL NUMBER
1 Open panel cover 2 Press DATA REGISTRATION 3 Press V to display 2. TEL REGISTRATION 4 Press SET twice 5 Press ^ or v to find the number you want to change 6 Press SET twice 7 Enter new fax number 8 Press SET twice 9 If you don't want to change the name then enter SET once more. Otherwise enter the changed name using the number pad as if it were a mobile phone (2 = A, B, C etc) 10 To continue press DATA REGISTRATION 11 Repeat steps above for other numbers 12 To end press STOP
Razr V3: How can I delete a voicemail messasge
You have to be logged in to the voicemail system to delete any message. There is no other way. You don't have to listen to it, you can press 7 as soon as the message starts to play or starts to give you time and number...
Please email me back if Iam not understanding what you need.
Please leave good ratings, they are very important to me..
Aug 06, 2009 | Motorola Mobility RAZR V3
Casion Fx-300MS
If I understand correctly you result do not display any decimal.
If you want a fixed number of decimal digits (exemple 2) Press the [MODE] key a number of times until you reach the screen that displays Fix Sci Nom and under them the numbers 1 2 3
Press 1 to choose Fixed format followed by 2 for TWO Digits
3 decimal digits [MODE] ---------[1 ] (Fix) 3
Hope it helps.
Feb 13, 2009 | Casio FX-300MS Calculator
I can't access business phone menus with my V3 cell phone keypad
I have the same issue with an earlier version of the Razor. I haven't found a solution yet but still looking.
Aug 22, 2008 | Motorola Mobility RAZR V3
My phone dials out the last number when opened.......
hi,
you could try some things such as,
- Restoring the factory settings of the phone.
- Get your phone to your salesman and ask for a software update.
It will not cost much and would definately fix your phone.
Looking forward to hearing from you regarding further assistance!
Aug 12, 2008 | Motorola Mobility RAZR V3
Text messages
Hi, Hi-Tech people! I got a Motorola RAZR V3, my problem starts when everytime I press the keys to type a message...it HANGS. Once it HANGS, I can't type anymore and continue the message I suppose to write. It wont move no more. It just STUCK-UP right there on the last letter I'd pressed. I have to take-off the battery at the back to re-start the unit again. Then, start typing again...same thing happens. It just HANG by itself and I can't press other keys no more.
Any HELP?
MannyQ
Jan 21, 2008 | Cell Phones
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
