Question about IBM ThinkPad T23 Notebook
My hard drive gose on and off on and off dont want to boot.
  • anibal aviles Jan 30, 2009
    sorry the nly think i wen i tun it on i heart is the fan not the hard drive.
  • Christopher Sherwood
    Christopher Sherwood May 11, 2010
    when you start up the computer, do you see the bios (black screen with white writing) and then playes up during or directly after that
    Problem Solver:
  • 5 Answers
Life expectency of hdd is 3 -5 years but just to make sure go to hitachie's website or just google drive fitness test and burn it as a bootable image, boot your machine from the disk ( drive fitness test) and run the test, look out for the error code at the end of the test, anything other than 0x00 means the hdd is faulty
Posted on Feb 13, 2009
Changed hard drive on emachine e725 now says no bootable device insert boot disk. dont have boot disk
You will need to install the operating system on the new hard drive for it to boot.Also you need to set you're boot order in the bios to CD then the HARD DRIVE.Get the operating system set the bios boot order then install it.
Mar 28, 2013 | eMachines eM250-1915 Netbook
On the primary hard drive it is connected to the sata1 on mother board. I added another hard drive as a slave. How do I get my system to boot without the boot menu options on
select the primary hard drive as the first boot device, or if you dont have option for this in BIOS, it means that your system boot from the primary drive as default
Apr 22, 2012 | HP Compaq Presario SR2027X (RK554AA#ABA)...
On my IBM t21 laptop when I press the power button the hdd light flashes ones and then it just gose off Help me pls
This usually means thehard disk has failed or the hard disk needs re-seating or the disk controlleris faulty. First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty. Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an USB mass storage device and you cannot open the various folders and fileson this drive, then this confirms the hard drive is faulty. Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Sep 03, 2011 | IBM Computers & Internet
Emachine wants to: " reboot an select proper boot device or insert boot media in selected boot device an press any key " . I dont have a boot media or know what is the proper doot device....
The proper boot device is your hard drive, when you boot hit F2 while it is booting up and it will bring up the screen to change boot devices select the hard drive and save the settings and this should work if it dont it is possible that your hard drive has bit the dust.
B52computers
Jan 14, 2011 | E-Machines eMachines Desktop PC
Computer will boot up with the external hard drive connected
if u dont want to bootup with external HD goto bios under boot device property first boot for {make it system intarnal HD}
Jun 26, 2010 | Maxtor OneTouch III Mini Edition 120GB...
I nead help with my laptop whene i turn it on it gose to cmd and dose nothing
Use the operating system to repair windows. This would solve your problem.
Regards
Sep 21, 2009 | Gateway 40GB NOTEBOOK HARD DRIVE KIT FOR...
Windows xp will not start, only leaves me with this message on a blue screen STOP: c0000218 {Registry File Failure} The registry cannot load the hive (file):SystemRootSystem32ConfigSOFTWARE or its log...
1) Restart your computer and when it's booting up press F8 and try and get it into safe mode.
2) Restart your computer press F8 and select last good configuration.
If methods 1 or 2 worked you can ignore the others.
NOTE: you might have to press a different F key then F8, but most times it's F8.
3) Get a hard drive enclosure and turn you internal hard drive into an external hard drive DO NOT FORMAT ANYTHING. From there just back up all your important data and return you computer to factory settings. (http://lifehacker.com/software/hard-driv…
4) Download Linux on a CD and use that as a live CD to boot up your computer and save your files. (http://lifehacker.com/software/disk-reco…
Aug 27, 2009 | Computers & Internet
Laptop won't turn on
keep pressing f12 when the computer first starts up this should show a list of boot devices, choose the hard drive. if the boot menu doesnt show up youll need to go into your bios setup and make sure the hard drive is the first boot device. if it still wont boot then you likely have a faulty hard drive or connector. Im guessing you dont have a backup of your assignment? You may need to take out the hard drive and have someone who knows what they are doing plug it into a desktop computer to retrieve your documents off it.
Dec 02, 2008 | Toshiba Axiom 60GB HDD Satellite Pro 4300,...
Problem Installing XP
you can go to your BIOS system set up and select the right sequence if you prefere HDD first then CD-ROM,
depends on your manufacturers settitng pls press F2 or F10 immediately upon start up then you will be prompted to enter password, ( if you know ) then scroll down until you see the booting sequence, dont forget to save this and end your system set up
goodluck
Aug 06, 2008 | Sony PCG-TR3A Notebook
IBM ThinkPad T23 Notebook Logo
57 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
