Question about Motorola HNN9628A Two-way Radio Battery
Problem off,on i have GP 360 and when is cold out my radio is off, and i cant to turn ON, where is problem>?
  • 35 Answers
When it is cold outside, the batter life can be very short
just dont store the battery in cold and the problem should be gone.
Motorola recommends these temperatures, depending on battery chemistry
NiCd - 30 °C, NiMh - 20 °C, LiIon - 10 °C
Sincerly
www.oppermann-telekok.de
Posted on Sep 23, 2009
    Problem Solver:
  • 17 Answers
First, check the battery and radio terminals. Is everything in place and clean?
There should be 3 terminals on the radio and 6 on the battery. The battery terminals of interest are the bottom 3.
Clean them all with a small flat screwdriver or similar and then give them all a damn good soaking with Brasso or any liquid metal cleaning liquid. wipe off with cotton wool buds or a clean rag.
If the problem persists, its probably the battery itself.
When cold, it affects the internal chemistry of the battery. This can make a poor and tired battery fail early.
Does the same thing happen in the warm?
Get thee to Ebay and purchase a new battery. Its probably not what you wanted to hear, but they really are quite cheap and will last for years if looked after.
P.S. Run the radio until the battery is flat. Do a full charge. And i mean a FULL charge! Then run the radio until flat. Do this 3 or 4 times and the battery might perk up a little!
M3ODQ
Posted on Feb 02, 2009
2 Suggested Answers
eradiostore
  • 1654 Answers
SOURCE: GP 360 Radio Charger
On a Motorola charger, when the battery is charging the light should be a constant red (or amber depending on the charger). When the charge cycle is complete the light will change to solid green. Sometimes the solid green time is brief, as the battery will begin to lose charge, and the charger will go back into trickle mode and change once again to red (or amber). In most cases, a flashing light indicates a problem, such as a bad or shorted battery, an incorrectly seated battery, dirty battery contacts, or a bad connection with the battery. (Note: Batteries last 18-24 months typically. Check your date code for the age of the battery.)
There were several chargers made for the GP360, including but not limited to a 60-minute charger, a 90-minute charger, a 10-hour trickle charger and a 6-unit gang charger which would be a rapid rate, either 60- or 90- minute. If you would supply your charger's model number we could tell you which one you have.
Posted on Nov 02, 2008
Where are the fuses located for the windows and radio on a '99 gp gt 3.8l eng?
The windows and radio do not share the same system, so that is not the problem.
Jul 08, 2012 | 1999 Pontiac Grand Prix
Require Frequencies for CTCSS codes for Motorola GP 2000
check this link at page 21 or see below
CTCSS PRIVACY CODES FREQUENCY CHART (Hz) Code Freq. Code Freq. Code Freq. Code Freq. Code Freq. 1 67.0 9 91.5 17 118.8 25 156.7 33 210.7 2 71.9 10 94.8 18 123.0 26 162.2 34 218.1 3 74.4 11 97.4 19 127.3 27 167.9 35 225.7 4 77.0 12 100.0 20 131.8 28 173.8 36 233.6 5 79.7 13 103.5 21 136.5 29 179.9 37 241.8 6 82.5 14 107.2 22 141.3 30 186.2 38 250.3 7 85.4 15 110.9 23 146.2 31 192.8 8 88.5 16 114.8 24 151.4 32 203.5 * Channel 8,9 and 10 are designated Canadian Marine Frequencies * Channels 8~14 are low-power FRS license free channels Note: Privacy codes can be programmed for use on Channels 1~22 only
Feb 01, 2010 | Motorola GP300 Compatible 2 Way Radio...
Motorola gp-68 low battery beeps comes on too soon
I'm not sure that you can manually reset the low voltage threshold on your radio. Most of Motorola radio use programming software to turn on/off low battery beep and many other features. Everything is done by software.
radcom907
Mar 10, 2009 | Radio Communications
I need to protect the communications through gp 340?
Midian manufactures voice encryption devices for two-way radios. Here is a link to their website http://www.midians.com/html/voice_security_products.asp.
Feb 02, 2009 | Motorola GP300 Compatible 2 Way Radio...
Nov 02, 2008 | Motorola HNN9628A Two-way Radio Battery
Motorola gp 63
The GP-63 and the GP-68 uses the same users manual. You can download the user manual which also has programming and cloning information in it from:
http://www.batlabs.com/2way.html and choose GP-63......Good luck
Oct 23, 2008 | Radio Communications
Motorola gp 68
Batlabs at http://www.batlabs.com/2way.html (Hand Held Radios) has the GP-68 users guide(Operation Guide), on the right side I think what you might be asking is in "Basic Operation 2", if not look into the Programming section below it.
MOTOROLA TWO WAY RADIO GP-63
Go to http://www.batlabs.com/gp68.html the manuals here should get you going. if not find someone with a frequency counter. this is alot easier than getting software for the radio.
Oct 02, 2008 | Radio Communications
Please Help me
MOTOROLA GP-2000 Programming Instructions
Switching between Dealer and User Configurations
- Turn off radio
- Press PTT + Monitor Buttom and + buttons together and turn radio on
- LCD Displays PRO-CLR
- To confirm switching to Dealer configuration, Press PTT. To cancel, press any other button
- Turn off radio. The radio now operates in Dealer configuration
From Dealer to User
- Turn off radio
- LCD Displays PROTECT
- To confirm switching to User configuration, Press PTT. To cancel, press any other button
- Turn off radio. The radio now operates in User configuration
ENTERING PROGRAMMING MODE
If the radio is turned on, turn it off. Press and hold the MON button and turn the radio on. A ringing tone will be heard,which indicates that the radio is in Programming mode. The PW and [] indicators are displayed.
EXITING PROGRAMMING MODE
To exit programming mode, turn off the radio
ACCESSING PROGRAMMING MODE PARAMETERS
In dealer config., Programming mode parameters are grouped into 3 (three) main categories.
RW = Radio Wide
Channel (001 to XXX) and
VFO (Variable Frequency Operation)
User + or - buttons to move from one category to another.
RW < >CH 001 < > CH 002 < > …. < > CH XXX < > VFO
Note : Radio operating in User Configuration is only restricted to PW parameters
Once you have selected the category and wish to view its parameter, use PTT or MON to move from one parameter to another.
Nov 06, 2007 | Radio Communications
Motorola HNN9628A Two-way Radio Battery Logo
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
