Question about Ricoh Aficio CL7200 Laser Printer
Paper jam leading to error code sc440-01
We had a paper jam. the jam was removed. now it keeps flashing SC440-01 & won't do anything.
  • Anonymous Mar 11, 2009
    thanks, but do you know how to go about fixing that problem? i'm not sure what the pcu motor lock is.
  • 95 Answers
I think the code is a black pcu motor lock. Replacing the black pcu might fix it, but the black waste toner section could be backed up.
Posted on Mar 11, 2009
Paper jam error without a paper jam
sometimes the printer keeps telling you one thing first you have to read again your instruction carefully or sometimes its just the position of your printer where the paper was
Apr 17, 2012 | Office Equipment & Supplies
Paper tray
Follow the Introduction:
The flashing error code that indicates a jammed printer is the digital-age equivalent of a flat tire. Sooner or later it happens to everyone, so you'd better know how to get things moving again if you want to finish your print job.
Instructions
Difficulty: Moderate Steps
1 Step One Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
2Step Two Turn off the printer.
3Step Three Remove any paper trays. Inspect them for wrinkled or damaged paper.
4Step Four Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
5Step Five If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
6Step Six Click to enlargeIf you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam. SEE PICS http://www.imagehost.ro/pict/0104361047293b9a4006c.jpg
7Step Seven Click to enlargeIf the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.SEE PICS http://www.imagehost.ro/pict/0104365847293bcaa9870.jpg
8Step Eight Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
9Step Nine If the printer paper jam message still appears, then there is still some paper in the printer.
Reinspect the paper path.
Nov 02, 2007 | Brother DCP-330C All-In-One InkJet Printer
How do I clear paper jam
1.Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
2.Turn off the printer.
3.Remove any paper trays. Inspect them for wrinkled or damaged paper.
4.Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
5.If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
6.If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
7.If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
8.Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
9.If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Sep 21, 2011 | HP Photosmart C5180 All-In-One InkJet...
My paper keeps jaming
paper keeps jaming - Brother MFC-3240C All-In-One InkJet Printer
Nov 09, 2010 | Brother MFC-3240C All-In-One InkJet...
Error paper jam light still flashing after jammed paper has been removed and all covers are closed
Unpluging the printer for ten to fifteen minutes after removing the paper jam. This will clear all the memory in the printer and the error codes. If the error code still pops up contact the manufactor.
Aug 12, 2009 | Brother HL 2140 Laser Printer
Printer all in one
E3 is a paper jam error, but I would use a flashlight and small mirror to check for any paper scraps or paper clips and remove them carefully. If you can't find anything then it's possible that the paper path sensor is broken and would require a shop repair.
Jun 22, 2009 | Office Equipment & Supplies
Error code 6A00
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 22, 2009 | Canon imageRUNNER 210S Copier
Paper jamming
Step1
Step
Step
Step
Step
5
Step
6
Step
7
Step
8
Step
9
Sep 05, 2008 | HP PhotoSmart 7760 InkJet Printer
Paper Jam feeder
Step1
Step
Step
Step
Step
5
Step
6
Step
7
Step
8
Step
9
Aug 14, 2008 | Dell 3100cn Laser Printer
Paper jam
Introduction
Instructions
Nov 02, 2007 | HP DeskJet 3325 InkJet Printer
Ricoh Aficio CL7200 Laser Printer Logo
1,529 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
