Can I make the typeface more legible in Internet Explorer 7
The small typeface looks like little dots joined together!
How can I make this more legible and easier to read please?
  • Gary Loney
    Gary Loney May 11, 2010
    first I need to know what internet explorer your using.....may I suggest downloading IE 7, Its an upgraded IE, and down in the lower right hand corner, you can easily change the font, or print size....go to www.microsoft.com If this helps please rate me, and thank you
  • Peter Steiert
    Peter Steiert May 11, 2010
    Could you post a screen-shot of the problem? You might also try out Fire Fox:
    www.mozilla.com
  • 122 Answers
First I need to know what internet explorer your using.....may I suggest downloading IE 7, Its an upgraded IE, and down in the lower right hand corner, you can easily change the font, or print size....go to www.microsoft.com If this helps please rate me, and thank you
Posted on Jan 31, 2009
Want to erase my Dell latitude E6400, windows 7 professional laptop. If successful,can I put a Windows 10 program disk n jus change it all together????
Yes, as long as your Windows 7 key is still present and legible, it can be used to activate Windows 10. The free upgrade program *officially* ended a while back, but still works fine, I use it on clean Windows 10 installs 3-5 times a week. Just make sure you install the Windows 10 version that matches your Windows 7 key (in this case Professional).
Aug 16, 2017 | Dell Computers & Internet
I have a LG 42PC3D-UD Plasma TV That had no picture but had sound I had 6 blowed capacitors I changed out the main board and the T-Con board still don't have a picture HELP me please
hello, you have blown buffer board, on left hand looking from the back there's either 1 long thin board or 2 joined together, the black ic chips, some have metal heatsink over the top if they haven't look for little white dots, if they are present the buffer is no good, you may also need to change the ysus board as well, thanks
shaun
Feb 16, 2017 | LG Televison & Video
Where is the orfice tube located on a 1999 chevy express van
Inside the ac line where they join together,, look at the aluminum tube find where the join together should be i little fatter that the rest of the tube
Oct 19, 2014 | 1999 Chevrolet Express
Timing guides collapsed dropped timing chains.
if you have the v6 with the 4.0 OHV set the #1 piston to top dead center and then when looking at the gears where your timing chain goes look for a dot on your engion near the small gear and align the dot with the dot on the small gear. you will have to put the chain around both the top and bottom gears at the same time you might need to turn the piston a little past top dead center when doing this to get the little gear to sit in place with the slot on the back side of the gear. ( i just rebuilt my engion )
Jul 08, 2011 | 1997 Ford Explorer AWD
Poulan chainsaw 2001 usa epa ph1 35 cc ser. 010730200112-5. family-1pwes.0424cs:em. the plastic tubing between the carburator,primer and the gas tank broke in two or three places. i am...
No they don't join together. One goes in and the fuel filter is attached to it. The other is the fuel return line, and that is the one that is attached to that plastic part. It is usually a one way valve and nothing else is attached to other end. To get the line in the tank get a small stiff wire, put it through the fuel line hole and other end through filler neck. Wrap the wire around the end of fuel line about 2 to 4 times and pull it through helping it along by pushing on line. I think you see where I am going with this so use your own judgment also. I hope this helps you out a little bit. Regards and good luck.
Dec 13, 2010 | Poulan Garden
Looking to join two Nortel MICS pbxs using E&M 8 wire cards and cisco Vic2-2e/m cards with the two cisco boxes both plugged into the public internet and faking an E&M channel so the nortel switches...
There is another web forum that specializes in this type of task, they are a group of techs... the forum is called Tek-tips(dot)com...
This is for techs that have major issues and need connections to other techs in the field.
Under the Search: look for Nortel and Norstar systems.
May 12, 2009 | NorStar M2616 PBX Phone
White screen suddenly appears Blank Page Windows
Try these steps first. I assume you are using IE 7. If these steps do not work try reinstalling your IE. Let me know if you need anything else. Good Luck.
Method 1: Clear cached data in Internet Explorer 7 loadTOCNode(2, 'moreinformation'); To determine whether a performance issue or an error message is caused by corruption in the temporary Internet files or in other cached information that is used by Internet Explorer 7, you must clear cached data. To do this, follow these steps:
  1. Open Internet Explorer 7.
  2. Click Tools, and then click Delete Browsing History.
  3. In Delete Browsing History, click Delete All.
  4. Click to select the Also delete files and settings stored by add-ons check box, and then click OK.
A progress bar is displayed to indicate that the browsing history is being cleared. After this process is complete, test Internet Explorer to verify that it works correctly. If issues still occur, try Method 2.
Method 2: Reset security settings for Internet Explorer 7 loadTOCNode(2, 'moreinformation'); If you configure security settings to be too restrictive, you may prevent Internet Explorer 7 from displaying certain Web sites. To determine whether an issue is caused by overly restrictive security settings, revert to default security settings. To do this, follow these steps:
  2. Click Tools, and then click Internet Options.
  3. Click the Security tab.
  4. Click Reset all zones to default level, and then click OK.
After you do this, test Internet Explorer to verify that it works correctly. If issues still occur, try Method 3.
Note If this method does not resolve the issue, you can restore Internet Explorer 7 to its previous security level.
Method 3: Run Internet Explorer 7 in "No Add-Ons" mode loadTOCNode(2, 'moreinformation'); Internet Explorer 7 add-ons, such as ActiveX controls and browser toolbars, are used by some Web sites to provide an enhanced browsing experience. An error may occur if an add-on is damaged or if an add-on conflicts with Internet Explorer 7. To determine whether the error is caused by an add-on, run Internet Explorer 7 in "No Add-Ons" mode. To do this, follow these steps:
  1. Click Start, and then type Internet Explorer in the Start Search box.
  2. Click Internet Explorer (No Add-Ons). Internet Explorer 7 opens without add-ons, toolbars, or plug-ins.
  3. Test Internet Explorer to verify that it works correctly. If issues still occur, try Method 4.
If no errors occur, the problem is caused by one of the add-ons that typically load together with Internet Explorer 7. In this case, use one of the following options.
Option 1: Reset Internet Explorer 7 loadTOCNode(3, 'moreinformation'); Reset Internet Explorer 7 to its default configuration. This step will also disable any add-ons, plug-ins, or toolbars that are installed. Although this solution is quick, it also means that, if you want to use any of those add-ons in the future, they must be reinstalled. To reset Internet Explorer 7 settings, use Method 4.
Option 2: Use the Manage Add-ons tool to determine which add-on is causing the issue loadTOCNode(3, 'moreinformation'); Use the Manage Add-ons tool in Internet Explorer 7 to individually disable each add-on to determine which add-on is causing errors. To do this, follow these steps:
  2. Click Tools, point to Manage Add-ons, and then click Enable or Disable Add-ons.
  3. In the Show box, select Add-ons that have been used by Internet Explorer to display all add-ons that are installed on the computer.
  4. For each item in this list, select the add-on, and then click Disable under Settings.
  5. When you have disabled all the items in this list, click OK.
  6. Exit and then restart Internet Explorer 7.
  7. If issues do not occur, repeat steps 1 through 3.
  8. Click Enable for a single add-on.
  9. Repeat steps 6 through 8 until you determine which add-on causes errors to occur.
Mar 13, 2009 | HP Pavilion dv4000 Notebook
Typeface too large for page
i use firefox so its on tool bar,view zoom in or out i think its the same for explorer
Feb 27, 2009 | Computers & Internet
Motorola q9c
Go to your main menu and select: System Tools:
Select Task Manager:
And Internet Explorer will show up as a process.
Leave the Internet Explorer Process Highlighted, this may require scrolling through the list till you find it/
Select the Menu key: (the little dot that next to the end call button)
And click the Kill Process button.
Generally I go through once or twice a day and "Kill All Processes" just to clear up the processor load.
Jan 21, 2009 | Motorola Mobility Moto Q
Google search results are hijacked
Install Spybot. (www dot spybot dot com)
run and clean your PC
Dec 27, 2008 | Microsoft Internet Explorer 7
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
