Question about GE JTP70 Electric Single Oven
GE JTP70 convection oven - defaults to self-cleaning mode
Sometimes in the middle of a bake cycle, and sometimes when the bake, or other button is pushed, the control panel lights up in the self-cleaning mode. If I cancel that, then none of the buttons respond. Wait a little while and try again. Sometimes it works, sometimes not.
  • 979 Answers
I believe your control board is going bad. This isn't that expensive. However, get one from a GE parts store. They tend to be better priced.
Posted on Jan 30, 2009
My top oven won't reach temperature. Convection and broil work, bake doesn't. Over a year ago I did a self clean...hasn't worked since. I really need it to work especially with Thanksgiving next week.
It does sound like the element may be bad. The control will cycle the bake and broil elements to even the heat in the oven. if the element is out the oven won't heat well.
Nov 22, 2014 | GE Profile JT952 Electric Double Oven
JKP70-27" SINGLE CONVECTION WALLOVEN
Replace the transformer and hope nothing else went bad. Good luck!
May 27, 2014 | GE JKP70 27" Single Electric Wall Oven...
Have a wall mounted Jenn-air oven. Have used self-cleaning feature before. Followed step by step instructions to the end including locking the door and pushing "Enter". Went to bead expecting to wake
This is a general answer and not specific. The oven thinks is still in the cleaning mode. If it has one, push the clean button again. Set the oven to a regular bake cycle.
Dec 15, 2013 | Jenn-Air 27 in. Electric Single Wall Oven...
How to clean oven model JSP46D P1BB
That model is self cleaning . So you have to remove the oven racks and press the button marked self clean. The self cleaning cycle will last anywhere from 2-4 hours . once the oven unlocks after the cycle is over you have to wipe the surface with a clean clothe. It is very important to never use regular oven cleaners (i.e. Easy Off ) in a self cleaning model. If you need to spot clean something without using the Self cleaning mode you can make a paste of baking soda and water and let it sit for an hour before wiping.
As far as the top is concern, use a mild soap and a dish cloth on an everyday basis. There is products specifically designed to clean the ceran tops (good brands are "Cerama Bryte" and "CookTop", they are available at any Wal Mart) you should use one of those cream cleaner at least once a week. If something is really baked on , you can use a razor blade ( same ones ones used to removed paint off windows) or a scotch brite pad ( the blue one only.. the yellow one is too abrasive)
Mar 14, 2011 | GE Ovens
How do I use this oven? Is it working correctly?
It would seem that the oven is small enough that a fan to flow the heat from the unit would be in use for both convection and bake modes. Usually convection ovens will have a "burst" of fan action during the bake process and it is not a steady fanning of the air that would dry out your cookies, ect. I have a small oven / microwave and my larger oven is a GE that has the "burst" convection that I described. Might not be that much help, but it's hard without more info on your unit. sometimes the model is behind the oven door.
Nov 04, 2009 | Jenn-Air Ovens
Ge profile oven/convection oven humming when on convection settin
ensure that your convection fan is turning
a hum on this model usualy means that the convection motor can seize up a bit
sometimes all you need to do is redjust the fan blade
Oct 13, 2009 | Ovens
F9 error code while using the convection baking function
This is a lock switch error code. Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. If the switch cannot be re adjusted, it must be replaced.
Jul 30, 2009 | GE Ovens
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
Self-clean not cleaning
I was wrong (I think).  the baking element probably was burnt out as the repairman said.  He replaced it and I thought selfclean still wasn't working.  In fact, I think I just had to give the self-clean function more time.  Also, I was judging by smell.  We have become used to a bad odor during self clean which was missing when it was broken and still missing after the repair.  Bottom line, the oven was clean after the baking element was replaced, sans smell.
Apr 19, 2008 | GE Profile JTP18 Electric Single Oven
GE JTP70 Electric Single Oven Logo
157 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
