Question about Ridgid 9 Gallon Wet/Dry Shop Vac 96882 Canister Vacuum
How do i go from dry vacuming to wet vacuming with the rigid shop vac
Can I run my sears shop vac without the paper bag, for dry pickup?
Posted on May 02, 2009
    President:
  • 1,214 Answers
Just do it.
The vacuum cleaner is made to handle both dry dust and wet dust to include sucking up water.
Notice the little deflector on the inside of the collection drum where the suction hose connects. That prevents water from being thrown at the motor.
Posted on Jan 29, 2009
How do I remove the filter from a Rigid 4 gal portable wet/dry vac
James the attached link/video shows filter just pulls off. I also put a link to the manual and it show the filter held on with large plastic nut, which would have to be removed first.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
4 Gallon Portable Wet Dry Vac
http://www.ridgidparts.com/pdf/WD40500.pdf
Rigid WD4070 Wet Dry Shopvac Unboxing and Overview
RIDGID Shop Vac Review must have tool 2
Apr 30, 2016 | Filter Vacuums
My rigid shop vac 4 gal 5.0 WD4070 wont start
Check elecrical connection, or switch may be bad.
Apr 14, 2013 | Ridgid Wet/Dry Vacuums Wd4070 4 Gal...
Trying to vacum and it starts to blow
There are two outlets on a shop vac one to blow and the other to vacum.
Dec 13, 2012 | Craftsman 12 gal 5.0 peak hp Wet/Dry Vac -...
I have a 6 gall wet dry shop vac bye rigid . do i need a foam wet filter on the inside or will it work properly without the filter on i need it for water only. people in the store said the paper filter was...
Always use the foam filter when using the Shop Vac, keep your filters clean and it will operate more smoothly. When sucking water I usually take the foam filter off as well as the cylinder filter
Oct 02, 2017 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
How do you remove the filter from Rigid wet dry vac?
Unscrew the 'tab/nut' at the BOTTOM of the filter and pull off the filter cartridge
Jul 07, 2010 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
How do i change from leaf blower tovac? vac will only blow i need to cahange it to vac mode
fell on top of vacum for the place where the air is being sucked in that is the vacum port put hose on this port
Oct 22, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Dry/Wet vac is blowing instead of vaccuum
Check to see if the plastic ball is stuck . There should be a ball under the motor , make sure it moves freely. Make sure your vacum lines are not plugged . Best of luck Ed.
Jun 18, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Ridgid 9 Gallon Wet/Dry Shop Vac 96882 Canister Vacuum Logo
937 people viewed this question
Top Ridgid Vacuums Experts
Dan
Level 1 Expert
ken skalski
Thomas Perkins
Thomas Perkins
Are you a Ridgid Vacuum Expert? Answer questions, earn points and help others
