Question about Brother MFC 7420 All-In-One Laser Printer
I can't scan
When I try to scan the machine prompts to select e-mail, file, etc..., then it says connecting to pc and nothing else happens.
  • 3 more comments
  • admin828 Mar 10, 2009
    It's the same problem as me - I ask it to scan to an email or an image and it just says it's connecting to PC and then nothing happens...
  • Anonymous Mar 11, 2009
    I have the same problem but with the Macbook.
  • spssmouse Apr 30, 2009
    but is there anyway to make the scan key working? I can scan by using the control center, but not working when I press the scan key on the printer itself
  • Anonymous May 12, 2009
    Are you kidding me. You are a Brother tech and your solution to the scan key problem is not to use it. Please try again.
  • Anonymous May 14, 2009
  • 22 Answers
When scanning documents on my MFC 7420, this is what I do. Place document on th scanner bed and don't press any buttons, leave it whatever mode it is in. Go to the computer and click on start> program files> scansoft paperport> open paperport se. When paperport is open click on the scan icon in the upper left corner. A dialog box on the left hand side will ask what you want to scan a picture or document. Select accordingly and press the scan icon.
A new window will pop up and ask what you want to scan and the size. You can either select pre scan or scan. The computer then will send a scan request to the scanner. When it is done scanning close the second window that popped up and the document that you just scanned will be there with a red box around it. Click on the document and it will open, then you can edit and save as needed.
Happy scanning
Posted on Mar 10, 2009
  • 320 Answers
The best way and simple wat to use the scan function is tthrough you computer, it some times gets confusing, brother tech
Posted on Feb 16, 2009
I want to scan a document to send to email how do I do this
scan the document , save to your pc , laptop , then when wanting to send on attach it and send
Mar 15, 2016 | Canon PIXMA MX432 Office All-In-One Inkjet...
How to scan on brother mfc-240c
Two methods are:
1) Insert a USB Flash drive into the machine.
Select the SCAN function.
Follow the prompts on the display (asking for filetype, etc)
2) With the machine directly connected to a PC via a USB cable you can use the Brother scan software that came with the machine. If you do not have the disc that came with it you can get the software from their website.
Here's a link to Brother's SCAN support section
May 31, 2011 | Brother Multi-Function Center MFC-240C...
How to scan through pc in xerox 3535 ?
there is a scan procedure manually in 3535
on machine go to scan option
set scan option like paper, photo mode etc
and just scan remember mail box name
then form pc browes ur machine ip
if ur having java aplet on ur pc
it shows web tools
go to
webscan option
write ur mail box name
it shows ur scan document
then set ur file format JPEG or pdf then click to save as
it will be download to ur pc
Aug 05, 2010 | Xerox DocuColor 3535 Copier
I am trying to figure out how to use my Brother MFC-8440 scanner. I would like to use it to scan documents to email out. When I go to and look at the direction book, it doesn't have directions...
It is part of the Network User's Guide (section 10) and the Software User's Guide (section 3 for a PC using Windows, Section 8 for network scanning), not the User's Guide. The directions below are for XP and Win2K primarily. Slight changes may exist with other OS versions. (Full software is not available for Win7 so the buttons on the unit will not work. You will need to launch scans from the computer only. You can use Windows Paint or Fax and Scan without needing third party software. Then attach the file to an email either in the email software or by right clicking on the file and choosing Send to Mail Recipient.)
For either use, put the document face down on the glass or face up in the ADF.
If you use a directly connected computer, you need to set the destination for the Scan to E-mail in the Control Center (section 4-4 in the Software User's Guide). Open this program and make sure the correct machine is in the drop-down menu. This program needs to be running to hear the buttons being pressed. Click on E-mail to set which program will get the scanned document as an attachment for your e-mail. You can also set the resolution and type of attachment. If you do not want to use available file formats, you will need to scan in PaperPort (or other software) and then use that to attach the file to the e-mail. Then click Scan to launch the scan from the unit. Hit Set when ready to send.
If you have the unit set up on the network, then you can enter the LAN setup in the Front Panel (or a browser). Hit Menu 6 (and then the appropriate number for the next feature), such as TCP/IP, DHCP or Static IP (these are under 1), SMTP, POP3, Mail Address (Menu 6 2). Setup the Scan to email with Menu 6 7 1 for color and Menu 6 7 2 for black and white.
This automatically sends the item to the email server or PDF as either a PDF or JPEG. Then you need register the PC that will get the file to the unit, if you use scan to email (PC). (Your version of Windows will matter for exactly where the information is: Control Panel > Scanners and Cameras or Control Panel > Printers and Other Hardware > Scanners and Cameras.) Right click on the icon for the unit and select Properties to see the Network Properties box. Go through all of this set up including the Scan To Button. Then the Control Center will launch the e-mail program when it "hears" you press Scan, select Scan to Email, press Set, then choose PC and press Set again. (or select the destination PC which has e-mail access and press Set again). Scanning will start.
If you have set the POP3 and SMTP servers and the unit can directly access them, then you can scan to e-mail and enter the recipient address. Press Scan, select Scan to Email, press Set, choose Email Server and Press Set again. Adjust the scan quality as desired pressing Set at each step. Once you go through all of the layers, the LCD screen will prompt you for the recipient's email address. Then press Start.
I hope this helps.
Jul 20, 2010 | Brother MFC-8440 All-In-One Laser Printer
I cant open my attatchment on yahoo mail it just keeps saving them but wont open them or let me read them
To read the attachment associatedn programm must be installed on your Laptop. Also please check Antivirus setting. I think Antivirus may be blocking attachement file to be open.
Mar 09, 2010 | Toshiba Satellite A100-S8111TD Notebook
Display reads "connecting to PC" nothing happening
Was this function working fine before? When you choose Scan => To Email, what the device actually do is launch the scanning software and scan it and save to temporary folder THEN open your default OUTLOOK email account and creates a new mail with the scanned file attached to it. So it could be a scanning software error or low in memory since the process requires an amount of memory.
So you better try to Scan => To File and see if the scanning completes. If you have problem with it, then try to reinstall the program of your printer and scanner in one.
Nov 01, 2009 | Brother MFC 490cw Color Inkjet...
Cant get into my inbox
Try clearing internet cache, temporal files etc.
from internet explorer go to tools delete browsing history then select everything.
Jul 19, 2009 | Yahoo Mail
Hp 2210 allinone
I just went through this with HP tech. Seems this is an known problem and their solution is for you to purchase a refurbished or new printer from them which happens to be more than you can purchase online.
You can try taking a lint free cloth, popping out your cartridges and briskly rubbing the copper and ink nozzle part of the cartridges to see if that works. Also briskly rub the connections inside the printer itself where the cartirdges make contact. If this doesn't work then you now have a HP paperweight.
I haven't had any luck with HP printers. Always something goofy going wrong. Software gets corrupt, update can't update, won't print, etc... I purchased this thing new and had to return it the first week for a replacement because it wouldn't power on.
I'm going to another brand. Possibly Cannon or Epson and hope for the best. Anyway good luck!
Aug 22, 2008 | HP Officejet 5610 All-In-One InkJet...
Won't scan
You have to go to Windows Photo Gallery. Click on "File". Select "Import" and it will prompt you from there
Dec 31, 2007 | HP PSC 2410 All-In-One InkJet Printer
Brother MFC 7420 All-In-One Laser Printer Logo
779 people viewed this question
James Cagle
James Cagle
Jim Keysor
