Question about Maytag MTF2156GEQ Top Freezer Refrigerator
Whole room stunk . Refer had Ice on the back panel on the Freezer
GE 19 ft Refer Side By Side, built in 1994. The refer is located in the laundry room. Went in the other morning and the whole room stunk. Opened the freezer door and there was ice on the back panel. Opened the refer door and it was warm so it quit cooling. That is all I know about it. I thing that a tube broke and all of the refrigerant leaked out thus causing the pungent smell. You have a thought?
Regards,
Howie
  • 410 Answers
The fact that ice was built up on back of freeezer tells me that the refrigerant system is probably ok. most likely from your description you have a defrost system problem. whne ice builds up very heavily it starts to act like insulation (think igloo) so it will allow frozen foods to thaw and fresh foods to spoil. here is how to check. in refrig compartment I need you to remove the control panel/light lens in rear, these are held in place by the control knobs and then you pull out on the cover to release. once this is removed I need you to look for the defrost timer there will be a hole to the right of the temp controls it has a grey or black looking knob in it that you can turn with a flat tip scre driver. turn this knob until the unit clicks off. now you will have to wait a few minutes but listen in the freezer compartment for a sound that sounds like water falling into a hot frying pan, you may also notice a glowing red light at teh bottom of the cover in the back of the freezer.
if the heaters don't come on then the timer is ok. teh next step is remove the rear freezer cover and defrost the ice out of the coils. you can use a hair dryer, or a wet dry vac set to the blow position. once the ice is gone inspect the heaters for burnt or broken condition. (ge uses glass rod heaters and heater breakage is very common) I suspect the heaters are the problem anyway.
be aware that you are going to get lots of water the drain pan will not contain all of the defrost form this bad a freeze up. good luck peyton
Posted on Jan 29, 2009
How do I replace the evaporator fan?
You have to remove the back panel in the back of the freezer sections by removing the screws that hold the panel and you will see the fan motor, unplug and replace
Nov 02, 2015 | GE Profile PSB48YSXSS 48" Built-in Side by...
On my GE GTH21SCXSS, top freezer bottom refer, the freezer and refrigerator settings are on the coldest settings and the freezer won't go below 15 degrees and the refer won't go below 43 degre
Do you see any ice buildup on the back panel of the freezer? You may need to remove the back panel to see if the coils are iced over. Post back your results.
Feb 10, 2013 | GE GTH21SCXSS Stainless Steel (21 cu ft)...
GE Artica (pss26msrss) both the freezer and the refridgertor will not cool down...
Unplug and manually defrost with a hair drier because that ice you see on back wall of your freezer is a result of frost buildup behind that rear panel. Place all the frozen items in another safe place until the defrost is complete.Here is what your freezer may look like behind that rear panel. Not much cooling in freezer or fresh food section because this frost is blocking airflow.
The replacement parts for your model are the=> WR51X10042 Defrost Heater Assembly
7_12_2012_8_36_56_pm.jpgWR51X10042
And then the defrost thermostat=> WR50X10068 Defrost Thermostat
7_12_2012_8_45_50_pm.jpgWR50X10068 If you would like instructions on how to remove and replace I will be here to answer any questions you may have. How to test these parts can be found on the same page as the replacement parts, Thanks Sea Breeze
Jul 12, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Side by Side PCF25PGTAWW Ice maker started to leak inside several weeks ago. Ice column formed inside back of freezer and on shelves. Removed ice and turned off ice maker. Refer and freezer...
when you removed the back panel if you look on the right side you'll see a round coil next to the fan you have to clean that out at least once a year,if you get a shop vac you can vac off the coil and then set it to blow and blow the coil out to clean it,if your food is staying clod you don't have a problem,when the machine goes into defrost there's a heater in the freezer that melts the ice off of the coil,when it comes on the temp will get warmer for like a half hour or so until it comes out of defrost and starts to cool again.hope this helps
Oct 05, 2017 | GE Refrigerators
Lights on inside, refer/freezer do not work
check electric to the light see if the bolb is good and your switch might be bad on the door...
Dec 30, 2009 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
GE 24 Profile refrigerator: The freezer part
my refrigerator goes into auto defrost every 60hrs for 45 minutes or till the bi metal(defrost thermostat) says it had enough....recently i had ice built up on the coil because my defrost thermostat was stuck open...
ice builds up because the moisture that comes from opening the door or food condenses on the cold coil...tempurature of the coil is below 32 degrees which will ice up the condensed moisture...
defrost is timed to remove this build up
Oct 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker stopped working w/red light blinking
The blinking light is an indication that your built in water filter needs to be replaced, it's in the refer. side, middle top or rear of refer.
May 25, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 02, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Fridge not cooling
Icbdeb, more than likley your defrost heater failed. To make sure you want to go to the board located on the back side of the refer. Unplug the refer. Remove the cover. On the board you will see a 3 pronged blue harness. It will say line, comp, def on the board. Leaving the harness on,.take a jumper wire with clips and jump line to def. (defrost). Plug the refer back in. This will send 120V to your heater. In the freezer comp. remove the back panel, the heater will be on the bottom of the evaporator. After jumping line to defrost, see if the heater comes on. If it doesn't get a meter and see if you have `120V to the heater. If you do, the heater is bad. Part number WR51X10032. Look it up at repairclinic.com to see what your after.Easy job. Catriver.
Feb 26, 2008 | GE GSS20IEM Side by Side Refrigerator
GE side by Side Fridge
froggy, First check the back panel of the freezer section and see if you have a big frost build up. If so, you probably have a defrost problem, heaters more than likely. If there is no frost build-up check to see if the fan in the freezer (evaporator fan) is running. If that's ok, next would be the automatic damper. Have someone unplug the refer. Open the refer door and listen for the damper door to open when someone plugs the refer back in. If thats operational, next would be the thermistors, you would have to ohm them out to see if they are in range. Seldom is this the problem. Check these things out and get back on what you find. Catriver..post back.
Apr 03, 2007 | GE GSS20IBPWW / GSS20IBPCC Side by Side...
Maytag MTF2156GEQ Top Freezer Refrigerator Logo
79 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
