Question about Speed Queen Dryers
Dryer Does not turn on when pushing the button
It is a Speed Queen HE5003W
  • Speed Queen Master
  • 1,525 Answers
Hello is the door making the switch if thats ok check wires see if they are loose if thats ok . at the bottom of the dryer next to the motor theres a part called a capacitor its got 2 wires coming off it. this can stop the dryer working.i hope its works
shaun
Posted on Jan 30, 2009
Fixing dryer. The start button won't "say on"the dryer turns on, but the start switch doesn't stay on, and has to be held/pushed for Speed Queen AGM479W2 the dryer to work.
well why didn't they come back and fix it?check the wires going to the motor or the switch in the motor is bad, basically you have to replace the motor.you can go here this guy really drags this video out but it can show you what's happening to your dryer.i know on ge dryers if this happens it's the belt switch that's bad and on the older whirlpool dryers it was usually a bad relay or a bad even heat board but you don't have any of these in your amana dryer,it might say speed queen but it's an amana when you look up the model number,i don't know if by shorting out the dryer it could have damaged the motor,i would call whoever worked on it and tell them it ran fine until they worked on it you never had this issue
https://www.youtube.com/watch?v=CaaqRXQERVc
Nov 18, 2017 | Dryers
Kleensmaid heavy duty washer by speed queen, washes but shuts down on what seems to be overspeed on the spin cycle
Amazon.com: Customer Reviews: Speed Queen 3.3 Cu. Ft ...
www.amazon.com/Speed-Queen...Washer/.../B004ZO...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Speed Queen 3.3 Cu. ... If you need more water in the tub you can hold down the reset switch until the machine ... I tried the delicate wash and spin cycle, but the clothes retain too much water and ..... It takes time to correlate the number of turns and the direction to turn it.Missing: overspeed
Commercial Washer and Dryer Problems
www.affordablelaundry.com/commercial-washer-and-dryer-problems
The water should shut off once it reaches wash level, if it doesn't, and water level hasn't... (these are the glass type fuses) be sure to turn power off before checking them. ... If you have the voltage in, but not out, it's the contactor. .... We repair: Speed Queenwasher, IPSO washer, Milnor washer, UniMac washing machines.Missing: overspeed
[PDF]View document in PDF
Dec 19, 2015 | Speed Queen Washing Machines
Hi, I have a Speed Queen LTSA7AWN washer/dryer combo. It will not start hte cycle. After closing the door, the door light flashes.
This is a door lock error. The control is not seeing that the door was locked.
Try pushing the door closed where the door strike is. If this does not work you may nee to adjust the door strike.
Dec 28, 2010 | Speed Queen CTS99AWN Front Load Washer /...
Dryer stops running shortly into cycle. When button is pushed to restart, dryer groans. Holding button may get the unit going again - but it makes noise running and stops again soon. Bad motor? Bad...
Sounds like start winding switch. I would replace whole motor assembly. Try on ebay for a used one that looks newer. Used motors will save you some serious money.
Jun 21, 2010 | Speed Queen AES28AWF Electric Dryer
Speed Queed Dryer Motor makes humming noise when starting.
motor is no longer strong enough to turn drum,soory-mike
Jan 24, 2010 | Speed Queen AES28AWF Electric Dryer
I have a Mcgraw-Edison speed queen Heavy Duty dryer. We used it last night and it worked fine except there was alot of condensation inside the dryer with a little water coming out the door. Now this...
You may have a venting problem. Check outside to make sure vent is blowing good. It is possible that the motor may have went bad with all of the problems associated with a clogged vent.
Dec 02, 2009 | Speed Queen AES28AWF Electric Dryer
I have a speed queen gas dryer. do i have to
It would be safest to turn off the gas supply. You should have a gas **** in line for this purpose.
Aug 29, 2009 | Speed Queen Dryers
Dryer won't start
belts, as in 2?? you do have an old speed queen. did you make sure the blower is able to turn freely?
if so then you most likely have a bad winding in the motor. it is costly to replace and you should go out and get a new dryer. too much money to fix this old unit.
by the way the model number is under the front panel in the center, on a metal plate.
doesnt matter since you know its 25 years old and its time to update.
Jan 22, 2009 | Dryers
Dryers Logo
170 people viewed this question
Top Speed Queen Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Kristy Heard Duke
Kristy Heard Duke
Level 1 Expert
Are you a Speed Queen Dryer Expert? Answer questions, earn points and help others
