Question about Minolta EP1083 CS/PRO Copier
Minolta Copy Machine
Whenever i make copies, the bottom half of the document comes out with multiple black stripes!!!
Where do I have to clean to get rid of this?
  • support159 Jan 29, 2009
    Hello Swan34!
    Thank you so much for the fast reply!!
    But where is the drum cleaning blade? or the cartridge?
  • Minolta Master
  • 990 Answers
Hello sir; You need to replace drum cleaning blade or drum cartridge will be take care of your problem.
Posted on Jan 29, 2009
I have a minolta ep2030 and when i hit copy all i get is black page.
- clean the scanner optics
- if this don't work check and replace drum cleaning blade
Jul 26, 2012 | Minolta EP1030/1030F CS/PRO Copier
Toshiba eStudio 2830c-getting a light line across
Hello sir; Is the stripes allway in same place and you use document feeder to copy, then you have to clean up a piece stripe glass on the plateform, otherwise ,you have to change drum cleaning blade or drum cartridge.
Dec 24, 2009 | Toshiba Office Equipment & Supplies
Minolta ep 1080 copies have vertical grey stripes with a white halo around the text
You need a drum cleaning blade. This blade cleans the drum between copies.
You can verify this by opening the "clamshell" or lifting the top half of the machine like you do when removing a paper jam. Then look under the top half of the machine on the inside. You should see a reddish or greenish colored cylinder called the drum. It is about in the middle from right to left. If you see the same black bands on the surface of the drum as you do on your copy then the drum cleaning blade is bad.
This cylinder should normally be clean.
Good Luck.
Nov 18, 2009 | Office Equipment & Supplies
Black bar printed in the center of copied document
try copying the document to your computer and then from computer take a print out.
Aug 23, 2009 | HP Photosmart 2575 All-In-One InkJet...
Hello, I work with Osceola County, FL Habitat
Sir the AFR-12 is the document feeder desiignation, the machine model number is located on the back of the machine or the right hand side of the machine (You saw the AFR-12 when you raised the document feeder correct?) As for copies being black the drum/cleaning blade mite need replacing. Remove the orginal glass the big sheet of glass and clean the optics use no liquids just a clean paper towel, there are about four minors two the right side plus clean the expose lamp (Bright lite that lites up) to copy the orginal be gentill. remove the black cover on the right hand side two mirrors under there The model mite be a EP2010, 2030, 2080, and or 3000?
Aug 22, 2009 | Office Equipment & Supplies
Black stripe across copy
The orange roller is probably contaminated from toner that is sticking partly to the photodrum in the cartridge. That roller is likely made of silicone rubber (heatproof) that presses the paper against the fuser roller to 'fix' the toner to the sheet.
I suggest replacing the cartridge and cleaning whatever is accessible before you put the new cartridge in.
May 04, 2009 | Minolta Office Equipment & Supplies
Pana KX-FL511 will not take mlt. pgs to copy, black lines, hot
It's time to upgrade. The THERMAL head is about to **** out.
Jan 30, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Is the Minolta cs pro 5000 strickly a copy machine or is it a printer too?
Im pretty sure this is an analog machine. One way to test this for sure is to make multiple copies of one original. If the light scans the paper each time, then it is a analog machine and can't be hooked up to a computer. Digital machines generally scan the document only once then print many.
Dec 04, 2008 | Minolta EP4000/5000 CS/PRO Copier
Horizontal black and white lines are coming on copy
you don't mention whether the document you are copying also appears on the paper.If it does you could have 1 of 2 problems-
The drum cleaning system could be at fault or-
the fuser roller has picked up some **** easy test...... run copies and when the 1st copy edge appears switch OFF. This is a crash stop.Now examine the sheets in there.Is the stripe on the copy before the fuser (Heat) roller? If yes you could have a drum cleaning problem, usually fixed by changing the drum module.If no and the stripe appears after the heat roll, the problem is with the fuser system,dirty rolls etc. There are a number of other problems with stripes, but you have to start somewhere! If the document does NOT appear on the copy, forget all above, could be scan or ROS problem
Jul 20, 2008 | Sharp AR-5320 Black and White Copier
Gestetner 9940 Fax machine
okay it sounds like you have something wrong with the scanner which could be one of a few things.start by really looking close at the black stripe you need to make a copy of something with text across the entire black stripe. try both laying a sheet on the glass and throught the document feeder. what you are looking to see is if it's still able to scan the text and just is very dark in that area or if it's solid black with no text being exposed. one means that either your scanner is being blocked in that area due to dirt, white-out, smudges on glass, dust etc. the later being a diffective scanner.. I would clean glass paying close attention to the 1 " **** glass on the left that's what the machine uses to scanning with the document feeder. if you haven't solved it yet and you Must then lift the document feeder open, be sure machine is off. remove 5-6 screws securing the 2 guide plates for the glass, before doing so notice there is a gap between the two peices. the **** glass is for using the document feeder the other is orginal glass, they are two pieces so be careful when lifting the glass and clean both sides, then while you have the glass out, very gently hold the shiny mirrors just below and very gently slide to the left, there are 3 mirrors that may need to be cleaned using glass cleaner on very soft cloth, doing this ever so gently.
I hope this helps.
Thank You,
Apr 05, 2008 | Office Equipment & Supplies
101 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
