Question about iRobot 5900 Scooba Robotic Wet/Dry Vacuum
Scooba doesn't put watter. Pump not working?
Hi, After using the Scooba for about 10 times, it stopped putting down watter. Seems like iRobot do not have any kind of support/warranty for the device. Waited for 17 minutes on the line, than hangup wrote an email. took them 4 days to get back with the answer - no support). Any idea how to fix such a pump ? Thanks
  • 3 more comments
  • Anonymous Apr 19, 2008
    SCOOPA RUNS A FEW MINUTES BUT DOES NOT PUT DOWN WATER AND THAN IT STOPS ASKING FOR SERVICE
  • magmish Jul 11, 2008
    my scooba works but does not put water on the floor. it just picks up dust and when I check the dirty water tank, its empth and the filter has dust in it. I cleaned the filter and checked the tanks. The clean water tank was still full and the dirty water tank was empty.
    The scuba ran for a long time and did not prompt about detecting a problem.
  • jsrm Aug 31, 2008
    Runs a few minutes. No water out put down. Stops with check tank light on. Tried using link offered in 2007 comment, but site states "answer no longer available". Tried cleaning, refilling, reassembly. No change.
  • Lauren Caverly Apr 30, 2009
    Worked for me! Just used the bulb that it came with and squeezed water into the solution valve. Works Great.
  • corbani May 11, 2010
    Unfortunately the link to the site says: the answer is no longer available.
I calledthe company and they told me to forcefully flush warm water repeatedly through the valve that is just  above  the brush release button the the mechanical part  of the scooba.  It may take 20 or 30 flushes (I used a turkey baster, iRobot suggested a children's nasal syringe) and "Scooby" is  running great.
Posted on Jan 31, 2009
  • Faith Stringer Apr 03, 2013
    Turkey baster worked for my Scooba thank you so much!!!!!
This probably has something to do with your solution valve (located by 'eject brush' button). When my scooba stopped pumping out water I used the bulb syringe that came with my unit, place the opening over the solution valve 5-10 times and squeezed the bulb very hard. This probably forced out some debris that might have been stuck inside not allowing the water to flow from the tank and now my units works fine.
Posted on Feb 04, 2009
    Problem Solver:
  • 18 Answers
Check and make sure the vaccume port is properly installed. I also went on their website, and they do have a faq about this. I have included the link to the site for your convenience: http://homesupport.irobot.com/cgi-bin/irobot_homesupport.cfg/php/enduser/std_adp.php?p_faqid=2&p_created=1153319315&p_sid=DCawHwJi&p_accessibility=&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTEmcF9wcm9kcz0zMSwzMyZwX2NhdHM9JnBfcHY9Mi4zMyZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX2ZubCZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PXdhdGVy&p_li=&p_topview=1
Posted on Aug 19, 2007
SOURCE:
10 notes alarm
try here > http://uksupport.irobot.com/app/ask you can email them with your question.
Jan 09, 2013 | iRobot Scooba 380 Robotic Vacuum
Cant remove top to get to the tanks
I had this problem and got the solution form i Robot customer service:
1. Put the Scooba on a solid surface
2. Press on the back of the tank on the IRobot logo
3. At the same time push down on the front switch
Good luck, it works for me.
Sep 14, 2009 | iRobot 5900 Scooba Robotic Wet/Dry Vacuum
Scooba battery light turns red as soon as irobot starts
Do you leave the battery on charge long enough? Try 4-hours up to overnight. If so, then the battery is probably at the end of it's useful life. Getting a new battery depends on cost versus life expectancy of the robot and whether it does the job you want it to do.
Jul 19, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Scooba problem
Does it put down clean water onto the floor? If so, rinse the four ports on the underside of the tank really thoroughly. You might have a clog; it's not difficult to dislodge it if you use enough warm water. Also make sure that the squeegees on the cleaning head cartridge (which holds the brush) are straight and in good condition.
If it doesn't put down water at all, try the tank rinse anyway, as it can help with that issue, too.
Jun 20, 2009 | iRobot 5800 Scooba Vacuum
Scooba says check tank and won't move.
Rinse the four ports on the underside of the tank with warm water, particularly the round opening that covers your Scooba's vacuum port and the curved one that matches the filter. Odds are, there's a clog in there and your Scooba knows it. Rinse the two oval ports as well, as thoroughly as you can.
Also, try priming the pump with water. The iRobot website shows how to do this under the Scooba troubleshooting section.
Then run the unit with water and vinegar (in place of the Clorox Cleaning Solution) if possible.
May 10, 2009 | iRobot 5900 Scooba Robotic Wet/Dry Vacuum
I cant open my scooba
If you haven't used the scooba before or if it has been a long time, the pump may need to be primed.  Go to irobot and do a search for how to do this.  I also had difficulty opening my scooba.  Press down with the palm of your hand on the back silver plate as you push down on the silver release handle.  This worked for me.
Apr 28, 2009 | iRobot 5800 Scooba Vacuum
I have a iRobot Scooba Vacuum Received an error message to check brush. I cannot get into the tank. Lever will not release.
Press down on the silver tank saddle at the back of the robot. While putting pressure on the saddle, tap the release handle quickly, right at the edge. That should cause the tank to pop up.
~Fembot
Apr 18, 2009 | iRobot Scooba 380 Robotic Vacuum
Scooba in diagnostic mode
This is a common issue :)
his morning, I turned on my Scooba and it started beeping a scale of tones and blinking all its lights in sequence. After an hour or so of resetting, cleaning, disassembling, researching, and scratching my head, I stumbled across the solution on Roomba Review. But, for me at least, it was even easier than all of that. I don't have any of my own pictures for this procedure, but it's pretty straight forward.
  • Remove the battery and power.
  • Remove the two screws holding the bumper shell in place and remove it.
  • Carefully peel up the sticker with the control buttons on it. This sticker is actually the control panel. There is a data cable attached to it just below the "Clean" button. Be careful not to break it!
  • Clean the surface under the sticker with some isopropyl alcohol. (I didn't actually have to do this, but I'm sure it doesn't hurt.)
  • Gently replace the "sticker" (i.e. control panel) and make sure it's completely flat.
  • Check to see if it works again. If not, repeat.
  • Replace the bumper shell and screws....
thnx.
Jan 23, 2009 | iRobot 5800 Scooba Vacuum
Scooba 5800
did you try priming the pump?
Sep 22, 2008 | iRobot 5800 Scooba Vacuum
Stuck on check tank indicator
If your Scooba's Green Check Tank light is coming on immediately on startup, please try the following steps:
1. Remove and reseat Scooba's battery, ensuring that you hear it click into place.
2. Remove and reseat the brush head
3. Remove and reseat the vacuum port and filter. When replacing the filter, be sure to press firmly into the hole. There is a magnet on the filter that must connect with the magnet on the Scooba.
4. Fill Scooba’s Clean Tank with approximately 1 cup of cold water, shake vigorously, and empty it to remove any debris in the tank.
5. Empty the Dirty Tank, refill with water, and slosh it around to pick up any sediment. Empty the Dirty Tank again.
6. Refill Scooba’s Clean Tank with water, adding a pinch or two of table salt. Run the Scooba. If the issue persists, please follow the steps below:
With the tank removed, press the Power button and then the Clean button.
If the robot tries to start a cleaning cycle, power off the robot and repeat, pressing the Power button first and then the Clean button. If the pump makes a “whirring” or squirting sound and the robot does not start a cleaning cycle (Check Tank indicator will light), this indicates that the pump is working. Replace the tank and try starting a new cleaning cycle with the tank on.
If Scooba does begin a cleaning cycle the second time you press the Power and then the Clean button with the tank removed, the pump valve could be blocked with debris. Using a turkey baster, straw or sports bottle, force water through Scooba’s solution valve. Confirm that the baster, straw or sports bottle fits snugly over Scooba’s solution valve, push water through the system at least three times, and then try re-starting Scooba.
Below is a link to a diagram of these steps for visual reference:
Title: Scooba is not putting down cleaning solution
http://homesupport.irobot.com/cgi-bin/irobot_homesupport.cfg/php/enduser/std_adp.php?p_faqid=322&p_created=1167154849
Nov 01, 2007 | iRobot 5800 Scooba Vacuum
iRobot 5900 Scooba Robotic Wet/Dry Vacuum Logo
5,002 people viewed this question
Top iRobot Vacuums Experts
Oliver Street
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
