Question about Brother ML-100 Typewriter
Replacement ribbon I have a brother 100 and would like to know where I can bye replacement correction for it? Many thanks.
    Scholar:
  • 75 Answers
Your office supplie store should have them. it is a common corr. tape if you look at your ribbon there is a colored knob on it ( orang, yellow or blue ) buy the same color. make sure you have a low tack corr. tape. if can't fined one we sell them 320-251-0092
Posted on Jan 30, 2009
I just replaced the typewriter ribbon my Brother ML-100 typewriter; however, it does not advance properly so typing does not appear on paper. What is the problem?
Take the ribbon off, see if it advances with the hand feed wheel if not you have a bad ribbon. Type without the ribbon and be sure the ribbon driver is turning. There may be a switch or setting for use of an overstrike ribbon,
DickyO
Aug 28, 2013 | Brother ML-100 Typewriter
Supplies - Correction tape replacement
It takes a Nukote B199 or a Gen. Ribbon T333C Ribbon and a Nukots 86TL or Gen . Ribbon T355.
We have them in stock.
DickyO
216-241-0027
Mar 18, 2011 | Brother ML-100 Typewriter
I can't get the ribbon cartridge in the down position to type.
It seems to me that your cartridge is not sitting correctly. If you are using an OEM ribbon, then it may well just be that you have not correctly inserted the casing. In that case, I suggest you try again.
If you are using a COMPATIBLE ribbon, then it is most likely due to wrong design of the casing. Unfortunately, some compatible ribbons in the marketplace do come with lugs, even though they look very similar to the correct cartridges. If you require further advice or would like to replace your ribbons, i suggest you contact www.inkribbonpaper.co.uk.
Sep 22, 2009 | Brother ML-100 Typewriter
Brother ml 100 can't get it off the correction tape mode
First remove the correction tape, then turn it off and back on and let it do it's reset, if it will now type OK check to be sure you have a dry L/O tape, if it is at all tacky replace it with a dry L/O tape.
Jan 05, 2009 | Brother ML-100 Typewriter
Ribbon/correction tape
Ribbons:
Correctable film - MODEL 1230 or 1030
Nylon - MODEL 1032
Multi Strike - MODEL 1031
Correction tape:
Lift-off - MODEL 3010 for use with correctable film ribbon & cover-up - MODEL 4010 for use with nylon ribbon and multi strike ribbon.
Aug 22, 2008 | Brother SX-4000 Typewriter
CORRECTION TAPE
correction tapes will not work with multistrike ribbons. You have to use a correctable ribbon. If you can find a white out tape, it will work with multistrike. What model typewroter do you have?
Aug 12, 2008 | Brother ML-100 Typewriter
Correction Tape
The correction tape which should be a yellow spool and the correction ribbon cartridge should be a yellow also, sometimes orange, first. The correction tape has to in front of the black correction ribbon. in othe words this is the order. Platen, paper, correction tape, correctable film ribbon, printwheel. Also make sure correction tape is dull side toward paper. Shinny side should face operator...
Correction Tape
Two possibilities, one the correction tape is twisted and the wrong side is .facing the paper. The shinny side should be facing you, the dull side facing the paper. Second possibility you must make sure the ribbon is compatible with the correction tape. There are 2 types of ribbons. A correctable one (orange or yellow knob) and a multi strike (blue or purple knob on ribbon cartridge). The lift off correction tape (orange or yellow spools) only works with the correctable ribbon and the cover up correction tape (blue) works with the multistrike ribbon.
Jul 17, 2008 | Brother ML-100 Typewriter
Brother ML100 Lift-Off Correction Tape won't lift off
Correction tapes DO have a shelf life, Also make sure the ribbon is moving and very important and this may sound dumb, but I have seen it that the ribbon is not a correction ribon. Are the spool turns orange or yellow? should be. Blue is multistrike and will not correct. Don't know the shelf life of ribbons but they do loose the ability to correct.....Good luck try new supplies..
Jun 30, 2008 | Brother ML-100 Typewriter
Brother ML100 typewriter
Make sure that the correction tape is place in the guides one on each side small metal guides, remove ribbon to see, it should be behind ribbon guide (closes to you). Dry lift-off tape only(#3015)
Dec 05, 2006 | Brother ML-100 Typewriter
Brother ML-100 Typewriter Logo
90 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
