Question about Konica Minolta DiALTA Di200 Copier
Display misfeed detected
Minolta Model cf3102
Display misfeed detected . But unable to find paper misfeed
  • 1 more comment
  • sola119 Feb 06, 2009
    Thanks for your help.
    I tried resetting the copier as you instrcuted.
    But ubable to solve the problem. Still display " misfeed detected".
    I looked at the ADF input tray but I am not find two optical sensors to the right side of the tray. Thank you
  • Ginko
    Ginko May 11, 2010
    Open all doors and close them back.
    Remove the toner units, inspect underneath and put toner back in place.
    also unplug the machine from power for ten minutes.
  • 15,935 Answers
Starting on PDF Page 189 of THIS DOCUMENT, you will find a step-by-step clearing/misfeed instructional.
You will have to go through every tray and also check the elctrical contacts (noted on page 190)
If you have touched one accidentally - this may have caused a static electricity charge and damaged a sensor.
In this Minolta printer there are many, MANY places for a paperjam to occur - and it will take persistence to find. Sometimes it will not be a full sheet, but a tiny bit of paper on a sensor.
Compressed air shots in each door will help move things around to clear sensors and bits of paper sticking around.
(dont forget to check the lid feeder as well)
Once you have gone through each of the steps in the document above under "Document Misfeed" and have blown air into each tray - and still get the error, there is a faulty or misaligned sensor that will require a Minolta Service call to repair.
Thanks for using FixYa - If you need further clarification or step by step help, please clarify with me.
Posted on Mar 28, 2009
    President:
  • 2,559 Answers
You can try to Get some canned air and blow the feed area and sensors clean.
Posted on Feb 06, 2009
    Sergeant:
  • 326 Answers
To clear a paper misfeed in the bypass tray 1 Remove all paper from the bypass tray.
2 If misfed paper cannot be pulled out, pull the lever for the sliding plate of the bypass tray, and then pull the sliding plate toward you. 3 Pull the sliding plate toward you, and then carefully pull out any misfed paper. 4 Pull the lever, and then open the right-side door of Tray 1. 4 Pull the lever, and then open the right-side door of Tray 1. 5 Carefully pull out any misfed paper.
6 Close the right-side door.
for more refined details with more instructions and diagrams just click this following link below as the copier mentioned in the link is quite different but will match your copiers functions  http://www.kn.nl/data/handleiding/176366/User%20manual%20bizhub%20C450P.pdf
the solution is mentioned from page number 318 of the link. thanks.
  • 6,784 Answers
This may be a bad sensor that has failed for some reason or another.Also, there could be a jam due to gear failure as well. i would disassemble and check for a gear jam just in case.
    Master:
  • 848 Answers
Hi
chances are the paper feed roller is either slipping or in some cases not turning at all. If you can't clear the jam by turning off the machine, and back on, then you have a bad jam detect sensor ...a small piece of paper lodged on the jam sensor....need to open printer to inspect sensor.....
  • 679 Answers
There is most likely a small piece of paper on a sensor/
remove paper tray and look inside, is there paper behind the tray? look at the tires are they bald and sniny? replace. Look at the tires and see if there is any scrap of paper there.
open right door and look down towards the paper tray, do you see any pieces of paper? there is a small black lever there, it's the sensor is it stuck?
look into the fuser (where it gets hot) ,you may have to remove it the paper sometimes gets crumbled like an accordion there, htere is also a small black lever there see any paper is it stuck?
  • 1,800 Answers
Take it you have a misfeed condition that will not clear? Your condition is in the ADF Length sensors. If you look at the ADF input tray, you will see two optical sensors to the right side of the tray. Check these... they are probably dirty or disconnected.
Posted on Feb 02, 2009
  • 80 Answers
Lets try resetting the copier.
First, with the copier powered on open the front door
  • remove the small cover on right hand side
  • press reset button
  • close front door
  • the machine should boot
    President:
  • 1,214 Answers
Have you opened the unit up to see if there mught be a piece of paper caught between rollers?
Reply back what you see, and I'll look for the manual.
  • Mark Egan Feb 02, 2009
    There are number of things that can be done to fix this, and are described in the service manual on the Minolta website.
    http://kmbs.konicaminolta.us/productsatt...
    Reply back if you have any further questions.
Misfeed detected but there is no paper jam have removed the paper
It is possible that a switch is stuck. Most commonly on that model it is the switch just above the fuser (the hot part of the machine ). This switch can get stuck or knocked completely out of the machine.
Apr 21, 2015 | Minolta C350 Printer
How removed misfeed indicated problem?
a miss feed mean the roller could not get the paper, so clean the roller (s) or have them replaced, try a different paper draw
Jun 25, 2014 | Konica Minolta Di2010 Di2510 Di3010 Di3510...
Misfeed detected
have the rollers been replaced, misfeed means the rollers cant grab the paper not a JAM
Jan 30, 2014 | Konica Minolta Office Equipment & Supplies
Misfeed detected but no paper jam
Di 251 is legacy Minolta machine, Minolta is now Konica Minolta
for the image unit try this site
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
as for the adf replace!!! the rollers all three try the same site above
Nov 03, 2009 | Minolta Di251 All-In-One Printer
Misfeed
Your running double sided copies? Have you open the duplex section? What type pape using
Mar 28, 2009 | Konica Minolta Office Equipment & Supplies
I have a Minolta cf3102 color copier. I pulled out 2 paper jams in fusing unit. Now it displays paper misfeed in duplex unit. I have checked all the paper transport way but I can not see any obstacle....
on the duplex unit is located on wright side .open the first outer door looks like 2 door in one .if you do not see any paper look for black actuator .in the center make sure it's not hanging up.
good lock
Mar 28, 2009 | Konica Minolta DiALTA Di200 Copier
Model cf3102 display misfeed detected
We get a miss feed on our when we load too much paper. Try loading a little less. To undo a miss feed from overloading it you have to open and close all the drawers and eventually it will go away.
Jan 29, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
MINOLTA CF3102 PRINTER
This code is related to fusing pressure, which could mean fusing unit malfunction.
Put paper clip through a hole under LED cleaning pads inside the front door to reset.
Caution!!! Not recommend for the end user to reset fusing related codes since it could result in a fire.
Mar 07, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta DiALTA Di200 Copier Logo
312 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
