Question about Pioneer SD-P50A5-K 50" Rear Projection Television
Pioneer SDM1407 Rear Projection Monitor System (TV) 42"
When I turn on the TV it has like a popping sound, normally this goes away and the TV operates fine. It has been without sound for the last day and just hisses quietly? What should I do, we are vacuuming behind the back to see if this will make a difference but I think it is not good. Your advice would be welcome? Kind regards Tina
  • Tina Simcock Jul 28, 2007
    Pictures great but definately no sound?
What happened was we called in a technician, and he replaced the little sound thingey which had burnt out. He was really surprised that our TV hadn't blown up? It's working a dream now - like brand new.
Posted on Aug 16, 2007
    Genius:
  • 1,153 Answers
Check IC1402
SOURCE:
We moved our tv from a room with surround sound, and we now have no volume at all on our tv. How do we reprogram the tv?
You have to get in the Audio Menu and tell the TV "What You Want". Things are now set-up to operate with an external sound system. You have to set things back to Normal or Default.
Sep 13, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
We can watch maybe 15 minutes of tv and then there is a electrical pop and the tv goes blank. it is followed by a high pitch chirping or ticking. we can turn the tv back on after an hour or so, only to get...
Have someone remove the power supply board and resolder it; almost all of these sets had problems with soldering.
The high pitched sound is shutdown or a voltage missing will give the same symptom.
I have seen over 80 of these sets where soldering the power board restored the set to normal operation.
Let me know by commenting here and I will assist you.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
REGARDS, SD TECH
Aug 13, 2010 | Pioneer PRO-710HD 64" Rear Projection...
Pioneer elite tv turns off from a pop sound and manual says-will
It is most likely the power supply. Do not try to fix this yourself. There are LETHAL voltages inside such a TV, which can persist for WEEKS after it has been turned off.
Jan 09, 2010 | Pioneer PRO-710HD 64" Rear Projection...
TV goes blank - no sound or picture
Sounds like a bad capacitor or two in the power section. Do you hear a hissing sound also?
Nov 18, 2009 | Pioneer PRO-510HD 53" Rear Projection...
Pioneer projection tv SD-582HD5
I had the same problem, try running the TV on Mute, if it is a bad solder joint the sound can vibrate the solder point and trip the relay, if the TV doesn't trip off with the sound on mute then it is probably the big power transformer's solder connection needs resoldered. sound vibration from those big pioneer speakers may loosen the solder joint over a period of time because the transformer is heavier and bulky and vibrates a lot.
Jan 10, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
TV picture goes out after 10 minutes of viewing with popping sound
It can be a couple things. Something bad on the power board. Or the vertical output circuit. How long ago did you purchase the television. Your best course of action is to have it serviced.
If you need any information or other assistance let me know.
Thanks,
Lee
Sony Wega 42
Sounds like the bulb popped up... does it smells like there something that burned? any error light?
Apr 24, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Samsung tv
as far as it turning off on its own I would get a fan on it and see if that make a difference make sure that the fan is able to flow around the tv especially through the back of it, if this stops it from turning off then it is an overheating problem
Mar 22, 2008 | Samsung HCN4226W 42" Rear Projection...
TV not working
need mor info the tv when turn on after 15 or 30 minuts works fine ?
Mar 21, 2008 | Pioneer PRO-520HD 53" Rear Projection...
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
576 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
