HP DeskJet 722c InkJet Printer Logo
Bruce Buckno Posted on Jul 27, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printer problem I have a HP 722c and it started no to print correctly in black and color. It seems to skip in the line of printing every inch and a half. Changed the printer ink cartrige but still have the problem. I am at a loss.
Anonymous
Level 2:
Sniper:
  • Expert 58 Answers
  • Posted on Jul 29, 2007
Anonymous
Expert
Level 2:
Sniper:
Answers
58
Questions
0
Helped
86386
Points
205
You'll need to clean the encoder strip, encoder wheel, paper feed rollers and the carriage rod (where the cartridges ride -plus lube this) and cartridge service station. If you can't figure out how to do this, you'll need a tech that knows how. It will get pretty involved and I would recommend getting a new machine because they have come down in price and you could replace this for very little.
Black ink is skipping lines
Take out cartridge put in a sandwich baggie and shake it; then re-install
I have just replaced the color ink cartdrige in my HP Deskjet 722c printer and I tried to print a color picture in bond paper and it was a total mess
A new ink needs a little cleaning before using. Just dab lightly on a damp paper towel and look for a inch log stripe of each color on the towel. If all colors are not there it won't print very well and you should return the cartridge. Some have reported no yellow in their new cartridges.
1helpful
1helpful
Word text document not printing clearly on every line.
What version of Word do you have? What OS are you using?
Can you append a print to file to this thread so that I can see what data the printer is being sent?
HP psc 2175 skips when "copy"
replace the black print cartridge. I guess that the text is B&W. Pictures are printed in color - from the color ink cartridge.
Color Printing Problem
If a document displays in color on the screen but prints in black and white, try the following solutions. Print a test page to determine if the color cartridge is working
  1. Turn on the printer.
  2. If you have an HP Deskjet 710c, 712c, 720c, 722c, or 820c series printer, follow the instructions below:
    1. Turn the printer on.
    2. Press and hold down the Power button while pressing the Resume button four times.
    3. Release the Power button.
  3. If you have any other HP Deskjet printers, click here for instructions on how to print an internal test .
  4. If the printout is black and white, with no color, follow the instructions below:
    1. Open the top cover of the printer and remove the cartridges.
    2. Verify that the correct cartridges are installed in the printer. Click here to see if you have the correct cartridges . If the correct cartridges are installed, make sure that the tape has been removed from the cartridge nozzles.
    3. Insert the cartridges firmly back in their cradles and close the latches.
    4. Close the printer door.
Verify the correct printer is selected as the default printer
  1. In the software application that you are using to print, click File .
  2. Click Print .
  3. In the Print dialog box, verify that the name of the HP printer you are using is listed in the Name box.
  4. If the printer is not listed in the Name box, click the arrowhead to the right of the box.
  5. Click the name of the HP printer.
  6. Click OK .
Check that the printer settings are correct
  1. Close the software application that you are using to print.
  2. Click Start , click Settings , and then click Printers .
  3. Right-click the icon (picture) for the HP printer.
  4. In the menu that displays, use the left mouse button to click Properties .
  5. In the Properties dialog box, click the Details tab. (In Windows 2000, click the Advanced tab.)
  6. Check that the driver listed under Print using the following driver or Printer matches the HP printer you are using. The following setting may be in one of several places, depending on your printer driver and operating system.
  7. In the Details tab, click Setup . Under Printout, select one of the color options. (If other options have check marks, click in the check boxes to remove the check marks.) If there is no Setup button, click the Graphics tab, and then click Color . Under Color Control, choose a color option, and click OK . If there is no Graphics tab, click the Advanced tab and look for the text Print in Grayscale . If there is a check mark in the box by Print in Grayscale, click in the box to remove the check mark, and click OK . If you are using Windows 2000, in the Advanced tab, click Printing Defaults . Click the Advanced tab. The box by Print in Grayscale should not be checked.
  8. Click OK .
  9. Close the Printers window.
  10. Open the software application that you were using to print.
  11. Try printing again.
Install a new driver If none of the above options worked, the wrong driver might be installed on the computer. For the most current HP printer drivers, go to the HP Web site.
2helpful
Epson Printer - Skipping When Printing Black
If you try the print head alignment or head cleaning wizard under the maintenance tab, they may help!
2answers
HP 722C has quit printing black in color draft
WORKAROUND: Select EconoFast or Draft as the print quality setting in the printer properties. This will prevent the color cartridge from being used. - Or - Try another color cartridge. The color cartridge is used to print grayscale images in Normal or Best print modes, so if one color has run out, the printout will have the wrong tint. With a full color cartridge, the colors can be properly combined to create a composite black. CAUSE: When printing with Normal or Best as the print quality setting, the HP Deskjet 710C or 720C or 722C series printer will use the color ink to improve print quality output, even when printing a grayscale image.
k24674
Grand Canyon Tech
Grand Canyon Tech
