Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Water dispenser not working but ice maker works
Resevoir must be frozen. How do I fix this?
    Problem Solver:
  • 12 Answers
It could be the water valve located on the back, lower left corner of the freezer. On the outside. It's fairley easy to test. Just swap your water lines around. If you get water from the door then you need a knew water valve. If not then it could be the circut board in the dispenser. You will have to slide the face off of the dispenser. Hope this helps.
Posted on Jan 31, 2009
No water or ice
First thing to check is if the water filter is out of date, this will cause you not to get any water to the ice maker or the dispenser. Another thing to do is to get behind the machine and with someone pushing the dispenser see if the water valve vibrates. If it does and there is no water and the filter is good either the valve is bad or the resevoir inside the refrigerator is frozen and not letting water come through, but the last is unlikely due to the ice maker water supply does not go through the resevoir. The filter is the first place I would start with.
Sep 06, 2012 | Maytag MSD2456G Side by Side Refrigerator
Water dispenser doesn't work
Replace the water valve on the refrigerator. The valve solenoid is stuck open causing water to flow freely. This should fix both issues with icemaker fill tube freezing and water dispensing.
May 05, 2017 | Whirlpool ED5SHAXM Side by Side...
Water will not dispense to ice maker
The water dispenser in the door of my Kenmore side by side will not work. The ice dispenser does work. What do I need to do to fix it?
Thanks Kel
Sep 06, 2009 | KitchenAid KSCS25FKSS Side by Side...
On my Kenmore model 106.74254400 refrigerator the water dispenser quit working. I push the button dispenser but nothing happens. The ice maker is working fine. Could it be the water dispenser switch?
It could be the switch. It also could be the resevoir is frozen behind the crispers. It could be the water valve has a bad coil. It could be a plugged filter if you have one in the line. Was the frig recently extra cold just before the problem? Check the resevoir first.
Eric
Jun 29, 2009 | Refrigerators
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
Jun 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker will not make ice, water dispenser is working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
oypyiooiyp
May 27, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Ice Maker Not Working
Hi: A lot of reverse osmosis systems don't supply enough water pressure to the ice maker to fill. Contact your manufactrue of your reverse osmosis system and see if it works with icemakers. I thind usually the require at least 20-30psi. Or hook your refrigerator to city pressure to see if it works. Also I don't know if you have just an ice maker or a water dispensing side by side, or your water quality. If you just have an icemaker, most chlorine will evaporate before the ice is frozen, any odors in the water will still be there. Good Luck, Jeff
May 26, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water dispenser fine but ice maker not working
Hi. A good way to check the ice maker water solenoid valve is to swith the wire lead from the dispenser water solenoid valve to the ice maker water solenoid valve. Now push the water dispenser lever and water should come out your ice maker fill tube. If not, either the fill tube is frozen or the ice maker water solenoid valve is bad. Take the 1/4 inch tube that runs up the back of your freezer off at the ice maker water solenoid valve and blow thru it. If you can't, the tube is frozen. If you can, the valve is bad. Good luck, Mack
Jan 31, 2008 | Refrigerators
Water dispenser and ice-maker do not work
open ice maker cover buy pass T_H will move if still water not come in ice maker change fill valve
Sep 03, 2017 | Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
170 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
