Question about Whirlpool Duet GHW9150P Front Load Washer
F2 error code
Our front loading washer has been sporadically showing an f2 error code. We have removed the front bottom panel, cleaned out the lint as per the machine user manual, and it works fine for a few loads. But then it happens again. When we check the lint trap, it is almost clean, with very little lint. What else should we do?
  • 640 Answers
Check your drain hose for kink,,when you cleaned filter did you check for coins in the impeller..also check drain pipe for slow drain problem,,check the pump connection and make sure its not slipping off..onthejob
Posted on Jan 29, 2009
I have a Kenmore HE3t washer than continues to stop during the cycle and flash the F2 error code even after cleaning out lines, hoses, trap, boot and replacing the drain pump.
It is possible that the brushes on the motor that spins the drum are worn down. The drum will start and stop when this happens. Check the brushes.
Nov 07, 2013 | Kenmore Washing Machines
My Duet front loader.. once it starts washing it stops and an error f2 code comes up and it will not complete the washer the clothes are left wet. if i move to spin only it still wont same code comes up
Hello & Welcome to FixYa
F2 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display suds and then F2. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jun 14, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F2 error code flashes and machine wont finish the drain cycle
F2 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display F2. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
May 30, 2011 | Siemens WXLP1460 Front Load
Our Front loading High Efficiency Washing Machine (Maytag) had a F2 code flashing and I can't locate the manual after I moved. Could you help diagnose the problem?
F2 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display sud and then F2. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
May 02, 2011 | Maytag MAH8700A Front Load Washer
F2 Shows up on control screen and cloths dont go throw spin cycle.
F2 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display sud and then F2. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Feb 15, 2011 | Whirlpool GHW9400 Front Load Washer
GETTING A F2 CODE AND THE MACHINE JUST BEEPS
F2:---Drain pump error. Clean out the drain pump catchment.
- Pull the suction boot off the drain pump, clean out any gookus.
- Blow through the drain hose starting from the connection at the pump.
- If all else checks out, replace the pump.
---------------- remove the bottom front panel and there is a white plastic catch basin with a removable-by-hand, large facing forward lid. Remove it
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate thissolution and show your appreciation
Sep 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F2 code coming on several times during a wash
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} FO2 is the code for long drain. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
Regarding 'suds', the junk in your filter could be affecting the thin tube going from the pump area to the 'pressure switch' near the controls. This should not be blocked, remove clip from top & blow into it (after cleaning out the filter). If blocked clear it out. Do not wait for filter to clog up. Check it now & then, according to usage.
Nov 06, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE 4T
HE 4 front load remove bottom panel 3 screws once remove now you have access to pump get towels and bucket oper lint filter and remove debris from inside ,,,,, and that its F2 long drain,,,,,,
Oct 13, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
F-21 error
no f21 code but there is an F2 which is long drain remove the lint filter behind the bottom panel and check for a blockage first
Jul 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
151 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
