Question about GE (PSS26MSRSS) Side by Side Refrigerator
We lost power & now our icemaker wont work
Everything else works fine?
  • 700 Answers
You will have to wait for a while for the temperatures inside of the freezer to get down and then it should start to make ice again.
Posted on Jan 30, 2009
What this can be?
On the rear of the refrigerator, there is a water control valve, that controls the flow of water to the icemaker and the water dispenser, if equipped. Hard water is usually the cause for this to quit running. The icemaker and water dispenser, are two separate circuits, and each one has it's own water control valve.
Mar 13, 2015 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Luxor LED550FHD Wont start
I'm afraid if the power was lost during the update, the TV has a real software problem. But you don't have the tools to put in a complete set of new firmware. When the TV is still working, the processor and the program can manage the upload to the memory and after a restart everything should work fine. But no perfect firmware in the TV now that can do the upload rot the flash memory. A technician has to connect the TV to a computer and flash the firmware manually.
The best thing is to contact a certified service centre from luxor and ask them.
Sep 06, 2014 | Luxor Televison & Video
Amana model tg21vl stops making ice
pull on icemaker fingers to force icemaker , check for ice in tube to icemaker and listen for the valve to open , if all checks ok replace icemaker
Feb 24, 2013 | Refrigerators
Kenmore coldspot not working properly after power outage
I am glad you made it thru the storm OK. I am in New Orleans and I am no stranger to what you guys went thru.
First, are you sure the compressor is running?
Post back to me.
Nov 02, 2012 | Refrigerators
Replaced the defrost heater,defrost thermostat,worked good for about 3
If the icemaker refill solenoid does not close properly or stays open too long excess water enters freezer compartment and that will freeze over the ice making machine plus other areas of freezer. There is an adjustment on the ice maker to regulate the amount of water going in - locate the screw (behind front panel of maker) and turn counter clockwise to lessen time of fill operation). Problem is not with the GE
Sep 06, 2017 | GE GSH25JFR Side by Side Refrigerator
My icemaker is not dumping the ice when it's frozen.
Replacing the icemaker is neither expensive nor hard. Order a replacement on the Internet.
Sounds like a malfunction in the icemaker itself.
May 27, 2017 | Whirlpool 25.6 cu. ft. Side-by-Side...
Golf mk4 wont start has power wont run
Part of the Speedo on a Golf has a connection to the engine immobiliser If a fuse has popped it was for a reason Is there a warning light on the dash display which looks like an engine with an arrow through it ?? You need a man with a laptop and software to check which codes have ben lost or corrupted
Jun 14, 2009 | 2002 Volkswagen Golf
Icemaker dont work after power outage
Make sure the ice bail wire is not lifted. If it is, the ice maker will not make ice.
The water valve may have failed to. It's in the bottom back of the refrigerator, and the water line normally connects near where the valve is.
Let me know what you find.
Jan 30, 2009 | Refrigerators
Ice maker not working
ONE OF THREE THINGS,THE INLET WATER VALVE ON THE BACK BOTTOM HAS FAILED,THE WATER SUPPLY TUBE IN FREEZER BEHIND ICEMAKER HAS FROZE,OR THE ICEMAKER ITSELF IS BAD,LET ME KNOW WHAT YOU FIND-MIKE
Jun 11, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
HSS25IFMDWW- freezer frosting up but working
sounds like the defrost thermostat or you may have a crack in the water line causing the freezing.
Jun 10, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
