Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire Front loader won't pump out water - Frigidaire ATF6000ES Front Load Washer
  • 1 more comment
  • zw6914 Jan 30, 2009
    yes,Water in washer does not drain
  • snpynme Jan 31, 2009
    After running the first wash cycle, the machine will not pump out the water. All that happens is a continuous string of three end cycle beeps until I turn it off.
  • onthethejob1
    onthethejob1 May 11, 2010
    will it wash,,
  • 640 Answers
Next we have to check the pump...and see it its jam,,thats a job ,,its best to get a tech,,but if you want to try ..i will talk you through..onthejob
Posted on Jan 30, 2009
Frigidaire lft6700fso washer not filling with water
water pump is clogged i pulled it out and cleand it and put it back and its working like it should and the part n is m222-5 on the frigidaire front loader
Mar 12, 2012 | Frigidaire ATF6000ES Front Load Washer
I have a mo# FTF2140ES0 front loader washer that won't spin
check the pump for a blockage,if the water cantget out of the wash tub,the machine senses this and wont spin out the load,also make sure to check both sides of the pump from the tub to pump and pump to house drain sides
Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
My front loading washer will not give a high speed spin out. It shuts off at the 7 minute mark
There are two things you can look at that are common problems for this type of model. One is on older Frigidaire front loaders the shock absorbers tended to break, you can remove the front panel and view both shocks, look for a end of the shock broke off. Second is check the trap for the water pump, have a towel for the water. The replacement shocks are better........and most front loaders will not spin if the pressure switch is not open(water pumped out) The remaining problems are electrical, reconnect your connectors on the electrical harness and board or timer, figure out tech sheet or call the service company......(unplug when doing any service)
hope this help
Feb 23, 2010 | Frigidaire Washing Machines
My front loader, model #FTF30ES1 won't spin out
This could be due to water discharge. Clean filter/ pump if needd be could also be slow motor speed , worn belt/ brushes in motor. good luck
Nov 13, 2009 | Frigidaire ATF6000ES Front Load Washer
If the machine doesn't drain the place to look is the drain pump. there is probably coins or some other blockage in the pump (very common). If this unit doesen't drain it will not spin. The pump is difficult to get to if there is no front access panel call local authorized tech to solve problem. good luck
Dec 22, 2008 | Frigidaire ATF6000ES Front Load Washer
Washer won't final spin
After charging me $275 to change the water pump, the repairman said I needed a new computer board for another $160. I went & bought a new washer - this time a regular top loader mechanical washer with no computer. The repairman said computerized washers & front loaders in particular have lots of problems. He said top loader Whirlpools have the least problems.
Nov 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Issue with front loader going through spin cycle
you can try removing the lower acess panel(2 screws along the bottom of front) behind the panel youll see the pump assy mounted to the right, disconnect the hoses and check for debris in the hose assy. the machine will not spin if it cant get rid of water, and it cant get rid of water with a clogged hose. very commom.UNPLUG UNIT FIRST PUMP WIRES ALWAYS LIVE!!!!!!!
Nov 03, 2008 | Frigidaire ATF6000ES Front Load Washer
Front loading washing machines
not really front loaders have top loaders beat all the way but stay away from admiral and maytag .a front loader will wash your clothes using the soap that your top load failed to get out if i may suggest buy a frigidaire with a mechanical timer not electronic control more junk on them more to fail the best combo in my mind is a frigidaire front loader and whirlpool dryer front loaders use 2/3 less water 2/3 less soap and will get your clothes twice as clean they have no transmissions and are direct drive the most common promblems with them is having to clean out the pumps where people leave stuff in their pockets also you need to buy soap thats for front loaders its called high effincey or he soap and they will get your clothes make sure you read the installation guide and remove ALL the shipping braces
Mar 18, 2008 | Admiral AW22 Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
