Question about Hoover AAA160 Front Load Washer
Hoover AAA 160 Error 3
Having read all the solutions about clearing the filter and ensuring that the pipes are clear, I am still getting the error 3. The pipes have been removed and cleaned, both from drum to pump and from pump to waste. On a wash cycle all water is pumped out, but error 3 comes up after 3 mins and so the spin cycle will not start. Even emtied the pump completely of water through the filter access and used the machine on a spin cycle and still get error 3. Has any one any technical details or cct diagrams as to what triggers the error 3 condition? Many thanks in advance for any help given.
  • 1 more comment
  • David Henderson Jul 29, 2007
    Many Thanks for your assistance, I have cleaned out the pressure pot and ensured that the hose is clear.
    Even with no water in the machine and the filter has been emptied, I am still getting the error 3 just trying the spin cycle.
    After leaving the machine over night and then tryingthe spin cycle it worked, tried a rinse cycle with no washing and that works. tried a speedwash with no washing and error 3. Then tried a spin cycle, error 3 again
  • Anonymous Mar 16, 2008
    hi there i have a hoover six whispa AAA 140 washer
    it starts up and after 4 mins errer 3 pops up on display then washer stops,
    it says in book the pump is not working, but it is,
    could you please give me another anser,
    thanks ****.
  • Anonymous Aug 24, 2008
    Jag får oxå error 3 ofta på min maskin fastän att man har rengjort allt men vad betyder det egentligen har tappat bort bruksanvisningarna på den
  • 51 Answers
If you are certain that all pipes are clear, then you may wish to check the pressure pot & pressure switch ( & small hose joining the two as this could be telling lies to the program unit. If the machine is emptying but the switch fails to read the level correctly, it can cause the same sort of error problem. Pressure pots can fill with the "grey soap gunk" and switches pressure are a reletively common fault also. Good luck
Posted on Jul 28, 2007
Where is this pressure pot?
Posted on Apr 20, 2008
I have a Haier HWD1600 washer dryer combo that I am getting an error 2 on. It will not drain the water out and I have not been able to clear it for the past two months
Its a common error,
Error message:Drain error, water can be not drained fully within the required drain time
Reason 1. Pump filter is blocked.
Solution 1. Please open and clean the pump filter. (Filter access door is on the bottom right, at floor level of the washing machine)
Step 1.Push a flat blade screwdriver into the slot on the filter cover and pull it open ,do not use excessive force.(Fig 1).
Step 2.Remove the rubber hose from its clip and stand a suitable container under it, remove the bung to drain the water (Fig 2-3)
Step 3.Replace the bung and fit it back into its clip (Fig 4-5).
Step 4. Unscrew the filter and rinse it under running water, replace it and close the flap(Fig 6-7-8).
Caution:
1. The filter must be in place during operation, ensure it is in place after cleaning to avoid leakage.
2.Place a container under the drain pump filter, to collect any excess water that may come out of the drain pump when the filter is removed.
Reason 2. Drain hose end is higher than 100cm above the floor level.
Solution 2. Please adjust the height of drain hose to 80-100cm above the floor.
Reason 3. Drain hose is blocked or twisted.
Solution 3. Please check and clean the drain hose for blockage.
Reason 4. Drain hose is too long, or water is back filling from waste water pipes.
Solution 4. Remove any extension to the original drain hose.
Ensure the highest part of the drain hose is nearest the washing machine.Check the waste water pipes in the building are clear of any obstructions and flow freely.
Nov 08, 2015 | Haier Washing Machines
What do I do when the dishwasher is stuck on P2?
GENERAL INFO ERROR CODES PROBLEM PARTS SOLUTION E1 NOT ENOUGH WATER INLET VALVE CLEAN OR REPLACE E2 NOT DRAINING DRAIN PUMP KINKED HOSE--ADJUST HOSE TOO HIGH--ADJUST PUMP FAULTY--REPLACE E3 WATER TEMP TOO COOL THERMOSTAT STAT OPEN--REPLACE TIMER CONTACTS OPEN-- REPLACE HEATER OPEN--- REPLACE ABOVE FAULTS CAN ALSO CAUSE TIMER TO STALL(TIMER STOPS TO ALLOW HEATING OF WATER) TIMER WOULD STALL AT THE 2,5,7 AND 10 O'CLOCK POSITION E4 OVERFLOW SWITCH ACTIVATED CHECK FLOAT IS FREE CHECK LEVEL OF D/W SOAP- AMOUNT AND KIND WASHARM STUCK OR SPLIT E5 E6 & E7 TEMP SENSOR THERMOSTAT REPLACE ERROR CODES: DDW497W Problem Solution Error 1 Water supply is turned off Turn water supply on Detached / damaged pipe Replace / readjust pipe Low water pressure Requires min. 0.04Mpa water pressure Defective water fill valve Replace water fill valve Damaged or defective wiring Repair the wiring Defective pressure switch Replace pressure switch Heavy water usage elsewhere in home Use unit when water usage is at a minimum Defective electric control Replace electric control Error 2 Sump or filter is obstructed Clear the sump and filter Damaged/defective drain pump Repair or replace drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 3 Voltage is too low Minimum voltage of 198 V Damaged/ defective thermostat Replace the thermostat Damaged or defective wiring Repair the wiring NTC thermistor damaged/out of position Replace or readjust the thermistor Damaged/ defective heating element Replace the heating element Defective electric control Replace the electric control Error 4 Sump or filter is obstructed Clear the sump and filter Loose or damaged sump pump/drain pump Repair or replace sump pump/drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Loose heater element Tighten heater element mounting nuts Loose spray arm Tighten spray arm Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Defective Microswitch Replace microswitch Float- defective or not in the right position Reajust / replace float Error 5 Damaged/ defective power switch Replace power switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 6 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too low Temperature should be above -20? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 7 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too high Temperature should be below 120? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric contr
Nov 27, 2014 | Danby DDW611WLED
Why woun't my 6500 ransond generator start its a diesel
See id it is actually pumping fuel and if so see if the glow plugs are getting hot.
Oct 07, 2014 | Cars & Trucks
NIssan Wingroad Malfunction producing error Code P0171
this code relates to fuel mixture to air so first check for any leaks worn pipe's check air filter also worth adding a fuel addative to clean through the valve,cylinder and catalytic converter and then get the code re read.Did you get the code removed when first had it read if not do the above and get the code cleared then drive again and recheck as sometimes a stored code can remain even when fault has been cured
Apr 09, 2014 | 2005 Nissan X-Trail 2.0
Hoover error codes
Ben, the simplest solution would be to unplug the machine from the wall socket, wait 5 minutes plug it back in and see if that clears the error code.
Jan 29, 2014 | Hoover H160E Front Load Washer
Hoover Interact 1600
This might sound silly, but try it. Run the washing machine through an entire cycle with nothing in it. Select the largest and longest cycle you can. Once this is done, is that error code still there? In some cases, this will clear it. This can be due to overfilling the soap and thereby triggering the sensors that are there to monitor pressure. Running it with no soap or clothes in it may clean this excess out of the machine. Another solution may be a faulty inlet valve allowing too much water into the tub to begin with...let me know what happens
Jul 01, 2012 | Hoover Washing Machines
Problems in Yahoo Messenger "script
Scripting errors may affect the expected functionality of Yahoo! Messenger and result in the following error message: "There is a problem with the script on this page". I will provide you steps for troubleshooting script errors encountered while using Yahoo! Messenger.
Having the most recent Java application will ensure proper communication between Internet Explorer and the Yahoo! Messenger application. Please follow these steps to uninstall and reinstall your Java runtime environment.
1. On your keyboard, hold down the Windows key and press the R key. This opens the "Run" command.
   2. Type in appwiz.cpl and click OK. This opens "Programs and Features."
   3. Select Java and then click the Uninstall button. There may be multiple installed versions, so be sure to remove all of them.
   4. Next, download and install the latest version of Java Runtime Environment.
   5. To ensure the update is effective please Clear the Yahoo! Messenger Cache.
   6. Restart Messenger to determine if the issue is resolved.
If the problem persists, try Resetting the Browser Configuration.
Hope this one solved your problem. If you have additional doubts, please come back to us.
P.S: If the solution is helpful, please accept the solution.
Regards,
Sunny.
Sep 02, 2011 | Yahoo Messenger
3 YR OLD MODULATING FURNACE GIVING PRESSURE SWITCH ERROR CODE (3 FLASHES) BEEN REPLACED & DRAIN CLEAR STILL GOES OFF GIVING SAME CODE
Check the air filter and also check both air intake vent for blockage and exhaust pipe for sag where water could collect.
Jan 20, 2011 | Heating & Cooling
Having error code se, have cleaned filter sometimes machine works sometimes it doesnt
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON. Clean the filter, check the impeller, and internal drain line. Be sure to also check the drain line and waste pipe for any obstructions.
Dec 17, 2010 | Samsung Washing Machines
Hoover AAA160 Front Load Washer Logo
1,690 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
