Question about Panasonic Lumix DMC-LC70 Digital Camera
No longer staying on
I recently dropped my lumix and when i turned it on again, it would start up like usual but once the lens was out for a second it would retract again and and tell me to turn the camera off and on again on a blue screen. I know the lens isn't broken because for the brief second it's on it does show what your looking at on the screen. Also it will stay on if I turn the camera on in the play mode. So I can look at the pictures I have already taken, but then once i switch it to take a picture it is on for a second and then tells me to turn it on and off again. It sounds confusing i know, but has anyone had this problem or know a way to fix it?
Hey same thing happened to me today differnt type camera but, when it does it i shake the camera or tap it on a counter top and it fixes it
Posted on Jul 28, 2007
  • Anonymous Jul 28, 2007
    I forgot to mention it can take a few times to work
    New Friend:
Thank you!!! I've been worried sick for months. And All i did was hit it against my sidetable! and voila its working
Posted on Jul 13, 2010
6ya staff
SOURCE:
Camera lens wont open
Saw a similar problem recently, same cause, and result was the lens was jammed.
Did manage to wiggle it free after many attempts...it only stays on for a few seconds before faulting and going off...but it's a bit hard to get a hold on the edge of the lens to pop-out the low side.
Started by laying it on it's back and checking the level of the lens edges for the low spot, then used a thick sewing needle to lift up while turning the unit on (again and again) until the gear-ring popped back in during the lens-check at start-up.
Apr 06, 2010 | Casio Exilim EX-Z40 Digital Camera
Panasonic DMC-FX35 error message
Sounds as if it has either received a knock, or foreign matter (grit etc) has got into the lens mechanism.
May 30, 2017 | Panasonic Lumix DMC-FX35S Digital Camera
LUMIX DMC-LS80 SHOWING MESSAGE PLEASE TURN OFF CAMERA AND TURN ON
This fault is usually caused by a lens problem.
Over 95 percent of lens problems are from Knock damaged or sand/grit in mechanism. It will need to be serviced by an experienced technician.
Sep 30, 2009 | Panasonic Lumix DMC-TZ1 Digital Camera
When i turn my camera on it says to turn it off again
Usually a lens problem. 95 percent of the time it has suffered a knock or has grit/sand in the lens. will need to go in for service. Does the lens move out at all?
Sep 28, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Dropped and can't take pics.
New capacitor or circuit board. company will fix it for $50
Jul 06, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Have Panasonic Lumix DMC-TZ5. get message turn camera off
Did you drop the camera on the lens?
You have to replace the barrel (cost around 175,00 euro)
try to find a cheap second hand camera en replace the lens unit...
Jun 17, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
'Please turn camera off and then on again'
The barrel is defect inside,dit it fall on the lens? A new barrel will cost about 175 euro.
Jun 07, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Camera was dropped. Now it will turn on, but after a few seconds, lens begins to move in and out for about 3-5 seconds, then a messag is displayed: Pleaase turn camera off then on again". Doing this r
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 17, 2009 | Panasonic Lumix DMC-LZ3 Digital Camera
Lumix lens retracts and extends
Belikes, any external object is trapped in between your Lens Motor and Camera Body. You should consult Authorized Service Personnel to handle this trouble.
Jul 28, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
Problem with Panasonic Lumix DMC-LZ2 camera
hello baylie101, this message shows when the camera picks up a lens fault, if the camera has taken a knock or drop something could have went faulty in the lens. camera should be looked at by a qualified technician.
Jun 14, 2008 | Panasonic Lumix DMC-LZ2 Digital Camera
Panasonic Lumix DMC-LC70 Digital Camera Logo
110 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
