Question about Toshiba Satellite A205-S4617 Notebook
Toshiba satellite a205 s5825 memory upgrade
I want to upgrade my laptop from 1 GB 2* 512 MB and have 2* 2G memeory when i used only one (2G) the laptop working , when i used both the Laptop stuck on the Toshiba screen
  • yafea1 Jan 29, 2009
    when i insert both memory sticks the laptop count only 1G and stuck
    when using only 1 its counting 2 GB and booting
    this laptop support only 2gb
What my audio setting suppose to set to step by step on my Toshiba satellite A205-S5880
Posted on Jan 29, 2009
My Toshiba Satellite A205 S5000 came with 2 Ram memory chips of 1GB each. The OS is Windows 7 with 32-bits. Can I upgrade the memory to 4 GB by inserting 2 memory chips of 2GB each?
Hi Lewis
yes you can
here is the link but is cheaper if you just write down the exact numbers from the website and buy in computer warehouse or shop.
http://www.crucial.com/uk/upgrade/Toshiba-memory/Satellite+A205+Series/Satellite+A205-S5000-upgrades.html
but don't forgot to clean your laptop airflow with air duster every month with this you prevent the dust clogging up.
blocked airflow lead to owerheating
and heat differential is not good especially on lead free compound because the composite of welding material contain
silver and aluminium these metals hate each other both has different friction and heat transfer.
lead is more efficient but by eu law is not permitted any more.
if you want to run fast tasks you should go for pc laptop has modified core voltage is slower than computer
and all the high spec numbers are to attract customers to spend money.
Oct 23, 2013 | Toshiba Satellite A205-S5000
How to get another product key for toshiba satellite A205-S5825?
there should be a product code on the bottom of your laptop, maybe its behind the battery on a green and blue xp sticker
Mar 23, 2013 | Toshiba Satellite A205-S5825 PC Notebook
Toshiba Satellite A205-S5825 graphcs upgrade
This is a laptop correct?
If so you cannot upgrade laptop, Unlike a desktop the graphic's processor is built into the motherboard.
As for the CPU it is most likely also incapable of upgrade depending on most of almost all laptops
Laptop's are pretty much incapable of upgrades. (excluding RAM and HDD drives)
Mar 01, 2013 | Toshiba Satellite A205-S5825 PC Notebook
How do I upgrade my bios for toshiba laptop ?
Why do you want to update the BIOS of your laptop? Be careful about updating your BIOS because it might cause your computer to crash.
Or are you trying to update the drivers in your computer?
If you are having some issues with its performance, then you need to update all the outdated drivers in your computer. I know that it's a total headache if you do the update manually but don't worry because there are Automatic PC Updater like RadarSync. It will scan and update all outdated drivers in your computer.
I hope this helps!
David
Feb 07, 2013 | Toshiba Satellite A205-S5879 Laptop
Can it support expanded ram - what is the upper limit on ram capacity
below are the specs for your laptop,
Standard Memory 64 MB (non-removable) Maximum Memory 192 MB Memory Expansion 1 socket Memory Comments PC100 SDRAM SODIMMs CPU Type 650MHz Intel Mobile Pentium III Model Comments 100MHZ FSB
Memory Upgrade for Toshiba Satellite 2775XDVD Laptop, the Toshiba Satellite 2775XDVD Laptop takes the PC100 SDRAM SODIMMs Memory Type, and comes installed with 64 MB (non-removable) of Memory. You can upgrade your Toshiba Satellite 2775XDVD Laptop to up to a maximum of 192 MB Memory, the system has 1 socket to install Memory, already with 64 MB (non-removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Choose the following Memory Upgrade for Toshiba Satellite 2775XDVD Laptop
buy more ram here: http://www.memorystock.com/orderitem.asp?it=330ms-069&MnfId=&MdlId=22646
May 20, 2010 | Toshiba Satellite 2775XDVD Notebook
Can I upgrade memory to only one gb of memory or install 2 512 mb on a toshiba satellite m35x series
http://www.shopping.com/xPF-Toshiba-Toshiba-Satellite-Notebook-PC-M35X-S114
Looking at the specs, the max is 2gb for your Toshiba. According to this website, its only a 256mb ddr sdram. So my guess is you only have 1 slot for the ram. I'd go with a 2gb ram if you can afford it, 1gb just don't cut it in todays technology.
I believe its the PC2700 model, so find a 1gb or 2gb PC2700 @ 333mhz and you should be set.
Sep 09, 2009 | Toshiba Satellite M35X-S114 Notebook
I purchased 2x 2GB DDR2 rams for my laptop (toshiba A205-s5823) but only one will work in the slots with a 1 GB in addition. I've tried every variation in both the slots. What am I doing wrong?
Your laptop can only accommodate a maximum of 2GB of physical memory. If you are running Windows Vista, you can get a little extra memory by using the "ReadyBoost" feature that is built into the OS. I have done that in the past and it works well for me.
Here's a link to Kingston's (a good memory mfg) memory guide for your model laptop:
http://www.ec.kingston.com/ecom/configurator_new/modelsinfo.asp?SysID=43561&mfr=Toshiba&model=Satellite+A205&search_type=&root=us&LinkBack=&Sys=43561-Toshiba-Satellite+A205-S5823&distributor=0&submit1=Search
Let me know if that helps!
Mar 11, 2009 | Toshiba Satellite A205-S5823 Notebook
Hard drive and memory
the laptop should pick up a 20gb or 60gb ide hard drive with no problem
Dec 01, 2008 | Toshiba Satellite 2775XDVD Notebook
Maximum Ram upgrade?
this is the link
http://www.memorystock.com/memory/ToshibaSatellite2400103.html
In this link u have following details
1)Maximum capacity RAM Information Available
2)Toshiba Laptop Memory Installation Video
3)Laptop Memory SODIMM Installation Guide
If you r Satisfied with information provided from my side please give me good ratings thanks
If u require more information search in google
Aug 09, 2008 | Toshiba Satellite 2400-S251 Notebook
Toshiba Satellite A205-S4617 Notebook Logo
423 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
