Question about E-Machines eMachines Desktop PC
Colors are messed up
today when i started up my computer the colors were nessed up. everything is kinda red and green is red too.
I already checked for viruses and reinstalled my video driver and nothing changed...i really need help.
  • freitagjen Jan 29, 2009
    I think my monitor isn't very old, i got i a few years ago and its a flat screen.
    I checked, my color quality is 32-bit i also tried out different resolutions and nothing changed.
    The monitor connection also seems to be good.
    is there anything else except that the video adapter is failing or the cable is going bad.
    Maybe it might help you, i have Nvidia geforce 7300 GS...
  • freitagjen Jan 30, 2009
    I went on the nvidia page downloaded the newest driver, uninstalled my old one and installed the new one and nothing changed. If the cable is broken I just need to get a new one or? What if the video adapter is broken?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 51 Answers
If You are using a CRT monitor (older Monitors similar to a TV) It may be time to replace it
Also you can try right clicking in a empty space on your desk top
go to properties>settings and check to see if your color quality is set to 32-bit
Double check you monitor connection
If all else fails your video adapter could be failing or you Monitor(VGA/DVI) cable is going bad
Posted on Jan 29, 2009
  • Jarrett Jan 29, 2009
    Is there anyway you can check the cable and test it with another cable?
    you can also double check and make sure you drivers are up to date
    the driver is found herehttp://www.nvidia.com/object/winxp_181.2...
  • Jarrett Jan 31, 2009
    next would be to replace or test the cable with one that is known to work
    if the video adapter is going bad its time to replace it depending on what it will be used for these can be found fairly cheap
Dp32746 Sanyo Picture is messed up?
try to play a DVD on your TV to determine if the problem is on TV or signal..
If the DVD plays same image you have bad t-con board,.,just replace it to fix the problem..
Aug 25, 2012 | Sanyo DP32746 32 in. LCD Television
My hp monitor's colors are messed up.
Did you already try it on another PC?
Try new VGA cable?
Otherwise you may have to open it up and look inside for failed components.
http://s807.photobucket.com/home/budm/allalbums
Mar 29, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Ok i have a 47in samsung hd tv today it started acting funny the picture and colors arent right like there a blue red and green colors its like the main picture is being copied 3x times once by each color...
this issue is caused by a failure in the convergence ic's and possibly a bad resistor and fuse in the circuit if you need instrution on how to change I may be able to help though it is kinda tech heavy
Jan 25, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
My monitor is all weird colors
Generally, this is caused by the loss of one of the main color inputs (Red Green Blue). Do the Following:
  1. Check the cable connections at both the monitor and the computer. Look inside the connector for any bent bent pins (there may be some that appear to be missing, generally that is normal) then reset the connections firmly and tighten the retainer screw snug, but not extremely tight.
  2. If that doesn't resolve, try the monitor on a different system and see if the problem follows the monitor. If it does, try a different cable. If the problem doesn't occur on another system, then the video card of the effected system is suspect.
  3. If issue occurs on multiple systems with known good cables, then the monitor will need replacement.
Dec 21, 2009 | Computers & Internet
Tv works good picture is good and clear sound is good but im only getting blue and red colors??? is that the board? or the green bulb?
That is what happened with are tv. My husband took the tv apart and started messing with everything and got the tv to line up better. he just turned the nobs and messed with the coloring.
Dec 09, 2009 | Hitachi 61HDX98B 61" Rear Projection...
The only issue with it is it has a double vision screen (The colors are kinda messed up)
JUST GET MAGNET AND TRY TO PASS IT BY THE SCREEN, OR GET IT CLOSE TO THE MESSED UP COLORS, I HOPE IT WILL HELP, LET ME KNOW IF IT WORKS
May 13, 2009 | Samsung PCH521R 52" Rear Projection...
Canon i860 won't print deep colors
I had similar problem: everything muted and with brownish tint. Tried everything, finally discovered that I installed wrong cartridge: 6PC instead of 6C. The "photo" cartridges are pretty much the same, make sure you have the right ones: 6C, 6M, and 6Y.
Nov 17, 2008 | Canon i860 InkJet Photo Printer
Faded colors
If the picture is dark or messed up too bad, the magic focus will not function, are all the primary colors faded? RED GREEN BLUE? You might have a bad CRT, would call a service man to check out.
May 21, 2007 | Samsung HCN5527W 55" Rear Projection...
E-Machines eMachines Desktop PC Logo
132 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
