Paper jam in hp deskjet 5900 series. how do i correct?
Paper jam.How do i correct/
Hp 5900 printing report after print
Posted on Apr 20, 2009
    Guru:
  • 57 Answers
 Follow these steps to remove a paper jam:
1. Press the Resume button.
  If the paper jam does not clear, then go to the next step.
2. Turn off the printer.
3. Remove the rear access door. Press the handle to the right, and then pull out the door.
4. Remove any paper that is inside the printer by pulling it out from the back of the printer.
  If you are printing labels, verify that a label did not become detached from the label sheet while passing through the printer.
5. Replace the rear access door securely.
6. If the paper jam cannot be removed from the back of the printer, raise the printer cover, remove the paper jam from the front of the printer, and then lower the cover. Caution Remove the paper jam carefully as it is possible to damage the
  printer when removing paper from the front.
7. Turn on the printer, and then press the Resume button.
8. Reprint the document. Note If paper jams occur frequently, try using a heavier paper. See the reference guide for paper weight specifications.
Posted on Jan 30, 2009
How to Fix Paper Jamming Issue in HP Printers?
not sure if this helps...
Skip to the two-sided printing accessory section if you have a two-sided printing accessory instead of a rear access door.
  1. Turn the knob on the rear access door counter-clockwise.
  2. Remove the door. ...
  3. Pull the jammed paper out of the printer. ...
  4. Check to make sure no scraps of paper are stuck in the printer.
More items...
HP Deskjet 900 Printer Series - Clearing a Paper Jam ' HP® Customer ...
https://support.hp.com/us-en/document/bud09128..
or go to this link...
How to Fix Paper Jamming Issue in HP Printers Google Search
Oct 27, 2017 | HP Office Equipment & Supplies
Printer show paper jam without paper in it
hp deskjet 3600 series
Printer show paper jam without paper in it try blowing it out with compressed.
Aug 12, 2016 | hp deskjet 3600 series
Fix inner paper jam hp cm1312
I Suggest You To Watch HP Video Gallery Fixing Paper Jam HP Deskjet 1510 All in One Printer To Fix Your Brother Printer Issue.In Case You Still Having Problem Then Follow Us For On : HP Printer Support Team.
Nov 19, 2013 | HEWLETT-PACKARD HP Color LJ CM1312 MFP...
I have use the HP Deskjet D1360 series printer paper jam
Simple and slowly remove the jamm'ed paper. Please be sure to inspect the system in detail (you may need tweezers) for any small pieces of random paper laying around.
After this you should be set please let us know if this issue persists as this would be a sign of other issues.
Thanks
Frank
Live-Tech
1-888-361-8511
May 24, 2010 | Office Equipment & Supplies
HP Deskjet F4185 series says a paper jam error everytime I print using a photo or matte paper.Everything is clean though so I don't know what to do with this error.
did your orinter experience a paper jam before?
try to clean inside again maybe there are small paper left inside
i hope this can help
Oct 12, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Hp deskjet d2360 paper jam
dear sir
I miss my Driver CD so I want this Deskjet D2360 Driver
Jan 19, 2009 | HP Deskjet D2360 InkJet Printer
Printer Will Not print
There probably is, in fact, a "paper jam". A very tiny piece of paper is stuck somewhere in this printer. If the printheads (where the ink carts. are) move freely when cover is opened, it's most def. a paper jam.
gurutim
Dec 18, 2008 | HP DESKJET PRINTER, HP OR COMPATIBLE
Using JETCET Print with OKI C5200n Printer
The OKI 5200 is a 'GDI' or Windows only printer and does not support PCL or PostScript languages.
Most if not all of the printers listed support either PCL or PS or an inkjet based language.
I'm afraid you will not be able to print the the 5200 without it's driver loaded on the PDA.
If the 5200 supported PCL you would be able to choose any of the
Color HP Deskjets.
Oct 15, 2007 | OKI C5200n Laser Printer
732 people viewed this question
jasbo
jasbo
