Question about Singer 2732 Mechanical Sewing Machine
Buttonhole This is a 4 step buttonhole machine. When I get to the third step (which is when the left side of the buttonhole is about to be sewn, going up) the machine hangs up and the fabric doesn't move. I don't know if it is the feed dogs or not. It works fine for straight stiching. I've cleaned it and tried different types of fabric and neither seemed to help.
  • Anonymous Mar 13, 2014
    My machine is starting on the right hand side of the buttonhole going in reverse
    Master:
  • 539 Answers
Make sure you are using a needle size compatible with the weight of the fabric you are using. Make sure you chose correct stitch dial for the side of the buttonhole you are attempting to sew. Make sure you have buttonhole foot properly attached.
Hope this helps.
Jimmy
Posted on Mar 30, 2012
    Novelist:
    Scholar:
  • 84 Answers
I'm afraid that you are unable to correct this glitch on your own. Any sewing machine service center/shop will do...call around and look for the shop with the lowest 'minimum' charge. It is such a simple fix. However, although simple, the adjustment is so incrementally precise that without thorough understanding, your stich patterns could be rendered unuseable. I have no idea of the current value of your sewing machine, but if you deem the repair costs prohibitive, there is a workaround so you can complete your buttonhole. Complete your buttonhole setup as normal. I assume that you run tests first to adjust your stitch length/density of the buttonhole using the Step 1 setting. When you find the the length/density that you want, using an ink marker/crayon...whatever...being as precise as possible, mark a linear line from the edge of your length selector dial, continuing to the body of your machine. Now, select Buttonhole Setting #3, and increase the stitch length until you see the length/density that you want. Find a clear spot on your length dial and repeat the marking procedure. When you are ready to make a buttonhole, align the markings for Buttonhole Step 1 on your stitch length dial and proceed, complete your tack of step 2, stop, manually raise your needle out of the fabric using the balance (hand) wheel on the right, adjust your stitch length dial accordingly for Step 3, then on to your final tack #4. If it's only your buttonholer that is giving you trouble, take the extra 15 minutes or so, and use the workaround and mark your machine. It doesn't have to be ink, it can be pinstriping tape...whatever, and spend the money you saved on fabrics and notions instead.....good luck my friend.
Posted on Aug 02, 2007
SOURCE:
It does not have 4 steps to do a button hole and will only stitch on the right hand side when I put it on the button stitch. How do I do the end pieces and the left hand side?
You can perform all the steps of a buttonhole without the buttonhole option (ask how sewists used to do it before sewing machines offered the buttonhole option). You'll just need a machine that can zig-zag.
How to sew buttonhole with an old machine
Making Buttonholes Without Special Feet
There are a lot of web sites and tutorial videos available.
Jan 22, 2016 | Sewing Machines
Singer 2277 buttonhole makwer makes half way then doesn't sew other side, or doesn't go past first step I've followed instructions step by step about 2 dozen times. I got 5 good buttonholes out of about 3...
Make sure your buttonhole lever is all the way down (I think it probably is, if you it will sew some of the buttonhole), and also sure that your bobbin winder is not partially engaged. In other words, make sure it's all the way to the left.
Dec 05, 2014 | Singer 2273 Mechanical Sewing Machine
How do i widen buttonhole stitches to make larger buttonholes?
Stop using the button hole program ! Use the button hole foot but do the stitch by hand adjusted satin stich ! Remember to lock off after each rib sewn !
Aug 27, 2014 | Sewing Machines
Buttonhole
Set the machine to button hole and use the "C" foot. The machine sews backwards first. When it reaches the correct length push the reverse button. Then when it has sewn the left side even with the right side push reverse again.
Dec 23, 2013 | Husqvarna Viking 1
Huskystar 219 224 type buttonhole
Attach the buttonhole foot. Then pull down the arm to interact with the foot. It is next to the presser bar to the left. Select buttonhole stitch. Start sewing. It should stitch all four sides in one step.
Oct 13, 2013 | Sewing Machines
Viking 6360 buttonhole procedure
you start with the broad zig zag stitch bar across the top
then you go down the left side using a smaller zig zag stitch
then you make the the broad zig zag stitch at the bottom
then you make the smaller zig zag stitch on the right side
all the way to the top broad zig zag stitch & your done
the right side zig zag does not go beyond the top broad zig zag
stitch
Aug 01, 2012 | Husqvarna Sewing Machines
Need to know how to do button holes
for an older sewing machine, one knob usually sets the button cams, or the step by step adjustments. for newer models, there is likely a button hole setting, the icon is probably a button hole (a tall narrow rectangle with thick lines). if none of this works, here are the manual steps for a proper button hole
1) Align needle all the way to the left. Set stitch length to smallest possible. Set stitch width to medium (2 or 3, machines are all different).
2) Stitch down in a line half again as long as the length of the buttonhole (always allow a little extra; it's okay!). Remember not to feed the fabric yourself; let the feed dogs do the work. The stitches will be very close together. This is the left side of the buttonhole.= '
3) Align needle to center. Stitch length remains as small as it gets. Set stitch width as wide as it can go.
4) Backstitch a small bit. Probably no more than 8 or so stitches; you may want to use the handwheel. This is the bottom of the buttonhole: '_
5) After reducing the stitch width to "middle" (same as step 1), you have two choices here: You can either backstitch up the entire right length of the buttonhole (pretty tricky, but a tad faster), or you can crank the needle gently down into the bobbin, lift the foot, rotate the garment 180 degrees, re-align the button hole so the lines will be parallel, and drop the foot again.
6) If you pivoted your garment, the settings for the third stitch are identical to the first stitch. If you did not, align the needle to the right before you backstitch. Either way, this is the right side: '_'
7) Return the needle to center, widen the stitch completely again, and either stitch or backstitch the final side 8 or so stitches.
8) use a seam ripper to rip the cloth in the middle... make sure you do not cut any of the stitching!
Sorry this is so long, I remember making these and wanted to get it down right.
Oct 30, 2010 | Janome MyExcel 3123
I have sewn very little with this 160 even tho I have had for many years. I attempted to make a buttonhole recently and could not figure anything out from the manual. How do I make a buttonhole? I...
Instructions would be the same as in the manual.
If you call your local Bernina dealer and ask, they would be able to show you how to do this.
Mar 19, 2010 | Bernina Virtuosa 160
Buttonhole making instructions from the manual of the Singer Simple do not seem to be accurate. The tension is incorrect and the machine is only sewing down one side without creating the satin stitch/...
Some machines will start out by sewing a straight stitch all the way around the buttonhole area first and then will zigzag/satin stitch along the sides. Bar tacks will be the last stitches sewn - hope this helps!
Nov 09, 2009 | Singer 3116 Simple
EP 382 My user manual buttonhole instructions don't match my machine.The instructions talk about turning the dial to ABC but on the dial I have buttonhole markings. On the dial there are 3 clicks for the...
Yes, you are right. To make out what is wrong place a plain cloth under the foot and try these 3 ABC positions as well as other positions and see what type of stitch you get in each position.
I don't claim this to be a solution to the problem. But it should help you solve it.
Oct 17, 2009 | Euro-Pro Denim Sewlution 380 Mechanical...
Singer 2732 Mechanical Sewing Machine Logo
263 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
