Question about Samsung LE40R74BDX 40 in. LCD Television
Delay with my tv coming on.
I have had my tv for just over 3 yrs now. When i turn the tv on it takes several minutes to come on. There is clicking sounds when it is trying to switch itself on. Any suggestions would be greatfully received.
  • Anonymous May 26, 2009
    tv is constantly clicking with no picture on start up. possible relay problems. is this a manufacturing problem
5 Suggested Answers
  • 195 Answers
SOURCE: my tv turns off by itself and makes a clicking noise
Most likely it has some bad capacitors in the power supply. Flat--panel sets are VERY hard on capacitors, due to the fact that the "rising heat' from the set "cooks" the caps and they fail VERY early.
Posted on Oct 12, 2009
budmrtn
  • 11361 Answers
SOURCE: samsung 40" tv not coming on
I would check out the power supply module for bad caps with bulging tops. Check DC voltages at the output connectors, you should have 5, 12, 24V.
Posted on Jan 08, 2010
Testimonial: "This seems to be a common fault on these tv's. I probably wont attempt to fix myself even though the warranty has ran out. Thanx "
freelance-au
  • 131 Answers
SOURCE: clicking sounds and delay when turning on lcd tv LE52M86BD
Hi
A common fault with this model is bad capacitors in the power supply, Remove the back from your tv and look at the power supply for bulged / swollon capacitors on top, they may even leak a brown like substance and should have a value of around 1000uf 10v
Change these where possible with the same uf but higher voltage lets say 1000uf 25/35v
Hope this helps
Please rate my reply++++
Posted on Apr 05, 2010
taran_2005
  • 10515 Answers
SOURCE: My P42 keeps turning itself
Disconnect the power supply for few minutes, say 30 minutes and then turn ON the TV.This would reset the TV. If you still see the same problem, it confirms a hardware failure.
As you could hear a clicking noise, it is more suggestive of a power supply problem. This a common problem on most of the Vizio's TV. You need to open the TV. Locate the power supply board. You would be able to find blown / bulged / leaked IC's. Take them out and re-solder the new one. ( you could get the caps from radio shack or even from fry's ).
I am pretty sure that it would solve the problem. If the problem still persists, revert and we could troubleshoot further.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 02, 2010
Sony Plasma KDE 42xs955 has delay in of 5 to 10 minutes for picture to appear. Sound turns on immediately
Contact the authorized service centre for Sony. This is not a fault that a normal user can do anything. Electro help
Oct 22, 2014 | Sony KDE-42XS955 42 in. Plasma HDTV
There is a 10 -15 minute delay before sound comes on. It's a Polaroid TTM2401 tv 5 yrs old
Change all the capacitors in and around around the sound output section. Usually Philips capacitors shows a some sort of leak after some years. I says this according my service experience. I'm working with this kind of electonic entertainement equipements since 1974. We cannot predict the exact capacitor poise the problem. That is why recomeds to change all of them. It won't cost so much.
Oct 14, 2010 | Polaroid TTM-2401 TV
42 inch lcd just clicks and does not come on. 3
take the back off of the set. there is an ic chip (27ch304) that needs to be replaced. about 1.39 at radio shack. simple fix, done a half dozen in my shop.
Aug 20, 2009 | Philips 42PFL3603D 42 in. LCD TV
My tv takes like ten minutes untill it's turning on,why?
Replace any swollen capacitors in power supply.
Apr 24, 2009 | Televison & Video
Samsung no picture
There are several capacitors that are known, in Samsung TV's that go out.. ( I replaced mine until the board was burnt through.. bought a new board, they went out again.. BOUGHT A LG TV!!)
Samsung settlement warrants older TVs with faulty capacitors
Samsung LCD Plasma TV Capacitor Repair Kit Replacement Parts
replacing these is not hard at all.. if you can use a soldering iron, you can do it..it just takes time..
Repair Samsung LCD TV Relay Clicks Shuts Off Won Come On
WATCH THESE VIDEOS FIRST.
Samsung TV Won Turn On How to Repair Bulging Capacitor for Clicking Noise
My Repair of 46 Samsung LCD TV with Bad Capacitors
Jul 18, 2017 | Samsung - Projection TV replacement lamp...
Hdtv dlp 52 inch loss of picture and loud buzzing noise
Please see http://www.fixya.com/support/t1011937-transformers. It sounds like your flyback transformer is not properly soldered down/is failing.
Sep 06, 2008 | RCA HD52W59 HDTV Projection Television
Delay to see the picture
Your power supply is going south, I have an old sony with the same problem. The voltage level drops and does not have enough 'kick' to start. It will work better when it is warm. The module will need to be replaced.
Nov 29, 2007 | Sony KV-27XBR45 27" TV
Samsung LE40R74BDX 40 in. LCD Television Logo
108 people viewed this question
Henry  Thomas
Henry Thomas
