Question about Magellan RoadMate 1412 Car GPS Receiver
My Magellan RoadMate's screen does not come on even thought the wire connector's light is on while plugged into ciggerate lighter. I really need this fixed because I do Home Care nursing in some very dangerous areas. Thanks.
  • Anonymous Jan 30, 2009
    Mine will no recharge It does not reset
  • Anonymous Apr 22, 2009
    My Magellan 1412 just suddenly stopped working. Will not go on when plugged into the car adapter or the electric plug adapter.
Try resetting it with the reset button on the side just above the plug in.  Mine did the same thing when I used it the first time.  If it continues I will return it.
Posted on Jan 30, 2009
Just call Magellan, get RA# and send them defective. Youhave a chance to get replacement for free if you GPS still under warranty.
Posted on Jun 18, 2009
Magellan roadmate 5635 LM will not charge in car. I plug in charger and green light wont come on and I cant open screen. Help I have to be someplace in 40 min.
unless you check the lighter fuse(usually a yellow 20 amp) it wont charge...replace it at auto zone or ask them to help they are very good about it...GOD BLESS
Oct 12, 2017 | Magellan GPS
Broken RoadMate 700
Here are a few tests you can do. Bear in mind if the unit has not been charged for some time and the internal battery is completely flat, you will need to leave the unit on charge for some time even to get a charge light from the LED. Leave it on charge for at least 2 hours. First, check the LED is lit when the cable is plugged in to the cigarette lighter socket and/or mains charger? If it is not, the fuse in the cigarette lighter adapter may be faulty or the charger may not be working. If the fthe LED is lit, then is power available at the end of the cable that connects to your unit? Use your DC voltmeter to check this. If no power is available here, then your cable/charger is faulty - obtain a new one. If there is power at the connector, then the unit may be faulty.
Jun 10, 2007 | Magellan RoadMate 700 GPS Receiver
My magellan will not charge from my car, only from my hose.
replace the cigar lighter. some plugs like my new phone will not plug in the lighter socket. It may have a broken contact inside the lighter. about a $10.00 repair job.
Deane
Nov 21, 2010 | Magellan RoadMate 1412 Car GPS Receiver
Magellan Roadmate 2200T -dark screen
its probably not charging...very common problem with this and many others.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040,4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get it repaired, here
or buy the port here
if you need further help, just let me know.
Oct 09, 2009 | GPS
Power adapter for Magellan 700 is broken
Connector J1 is the power connector. The left post corresponds to the center lug. The middle post is the outer connection. The right post closest to the USB connection is just an anchor - no connection.
Jan 04, 2009 | Magellan RoadMate 700 GPS Receiver
No power to unit, but powers on okay in house with AC power adapter
Not sure if you'll see this post, as you asked the question back in Nov, but I
thought I'd tell you what I know anyway.
I and my parents bought the same exact unit within a week of each other.
There's works, and mine does not.
I took their cradle, and hooked it to my GPS, and it came on, no problem.
I took my cradle, and hooked it to theirs, and boom, nothing.
So, with that, I was able to isolate that the problem is definitely in the cradle.
I went to the manufacturer website, registered my Magellan Roadmate 700,
and then I was able to contact customer support. I am writing to you as
I wait for their reply. Here's their website.
https://www.magellangps.com/users/registrationHelp.asp
Hope this helps!
Nov 12, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 800 - External Power Connection
The only thing I can think to add is a general question to Magellan asking why they let a four-year-old child design the power connector as "lightly" soldered to the main circuit board. Very dumb...
Sep 04, 2007 | Magellan RoadMate 800 GPS Receiver
Magellan Roadmate 700 does not power on
Hello, Rafster! Cigarette lighter plug problems are not uncommon, and - hopefully - this is the source of your problem. Because the green LED on your plug is lit, it would suggest that the FUSE inside is okay. Still, it's worth checking! The plug is easy to open, and the fuse easy to inspect/replace. IF the fuse is okay, the cord itself or the plug end that attaches to your Roadmate could be damaged. In order to determine this, you would have to check for voltage at the output end. But, you'd need a circuit tester and a wee bit of electronics knowledge to test it. If you don't have access to a tester, then the easiest test is to simply purchase a NEW cigarette lighter cord. You can get them at most retail discount stores (BestBuy; Circuit City; WalMart; etc.); RadioShack; or directly from Magellan. They're generally less than $10.00!
Jul 20, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 1412 Car GPS Receiver Logo
308 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
