4E code keeps apearing
Samsung J1045A
Filters have been cleaned.
rinse cycle work fine so does the drain cycle. but every time it is put on a wash cycle 4E appears after a few minutes.
When a wash cycle is first put on water enters the drum after a few moments the drum rotates. minutes later 4E apears on the front pannel and machine stops.
  • 15,935 Answers
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
  • craig kent
    craig kent Jan 14, 2014
    great stuff - all sorted tx
Samsung front load washing machine model wf42h5000a. During rinse cycle machine stops and displays error code e4 and Cannot be reset.explain error code. What are possible solutions ?
hi Judi.
this is what i found.
If your Samsung washing machine is displaying a E4/error code on the control panel after completing the spin cycle and the clothes are still wet, we've got the solution for you. This fault is most commonly caused by an unbalanced washing machine load.
Samsung Washing Machine E4/UE Error Code ' eSpares
https://www.espares.co.uk/advice/symptom/samsung-washing-machine-e4ue-error-code
What does 4e mean on my Samsung washing machine?This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed or pressure switch problem check pipes as well. Water fill time out: The washing machine has failed to fill with water in a reasonable time.24 Nov 2015Samsung washing machine error code 4E and E1 Fault Not filling in ...https://www.youtube.com/watch?v=cFlnxeB0P0gSearch for: What does 4e mean on my Samsung washing machine?
or try this link.
Samsung front load washing machine error code e4 Google Search
Nov 27, 2017 | Samsung Washing Machines
4e on my samsung front load WF42H5000AW
A 4E code indicates your machine is not sensing that it is filling. The corrective action is to check that water supply is on and has adequate pressure, hoses are not kinked, and that filters on the inside end of the water valve are not clogged.
Nov 21, 2016 | Samsung Washing Machines
Samsung WA12F5L4. Got 4e error. Machine set to wash rinse and spin. When it reaches the rinse cycle, the tub fills, it start rinsing, but the water keeps flowing, it doesnot turn off. Help please. Jus
this could be the water valve getting stuck on. you may need to replace the valve in question (hot or cold). it could be the pressure sensor that tells the machine when to stop filling. check there are no obstructions to the pipe leading to the pressure sensor, then replace the sensor (or board it is on)
Dec 08, 2014 | Samsung Washing Machines
Samsung washer reset
sound like module problem try to remove all the conection connecting the module and connect maybe after 30 mins.
Nov 06, 2013 | Samsung WF218AN Front Load Washer
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
My fontloader samsung wassingmachene p843 giv me and error code e3 4e and5e
5E - WATER DRAIN ERROR
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
A "3E" error in a Samsung washer indicates that there is an issue with the motor. Restarting the cycle may clear the error, but a service technician should be consulted if the error code appears again.
Oct 22, 2012 | Washing Machines
Washer keeps displaying '4E' Lack of water error
If you have pulled out and cleaned the filter at the back of the machine where the hose connects then I would check that your pump is not running during the cycle and also make sure your drain line is at least half way above your drum at its highest point, If its too low then it will drain off even if the pump is not running.
Apr 11, 2009 | Samsung Washing Machines
4E showing on Samsung Washing Machine
Apr 06, 2009 | Samsung WF337AAL Front Load Washer
Open Questions:
Samsung Washer WT1101cw will not drain. Originally had a OE error. Running "Spin" or "Rinse Spin" cycles but pump cycles on for less than 1 second and goes into spin with water in it. _Laundry loaded with a OE error and water not draining. _I manually drained the system, took apart the drain and did not find a clog or anything to prevent the motor from turning. _Pump motor reads continuity. _Ran multiple SPIN cycles and then a RINSE and SPIN cycle and actually had the pump run for a few seconds and even for a minute or so one time but could not repeat and hasn't since. _checked the Pressure Switch and see continuity between common and outside contact. Tried to increase pressure by blowing into the tube using a straw on the end of tube but saw no change. Not sure how the pressure is created inside the bowl. _There was no overfill condition originally and I have not tried to run a normal cycle because the washer is in an upstairs location and draining is difficult and messy. ___I believe that something is preventing the voltage from being sent to the pump motor but I have am not sure what logic conditions need to be satisfied for this to happen.I keep looking at the pressure switch because the drum will perform a load sense and then go into a spin cycle with water in it which sloshes around. Questions: --Shouldn't the drain pump normally be running prior to the spin? --what causes the change in the pressure switch? Does the switch only change at a "full" level? Please only answer if you have a clear understanding of the system. I am trying to avoid excessive expense in this repair and swapping parts unnecessarily. I am beginning to think that it is the control board and do not want to spend hundreds of dollars if it is not. Thanks.
Apr 23, 2018 | Samsung Washing Machines
Washing Machines Logo
1,321 people viewed this question
Top Washing Machines Experts
