Question about Coby TF-DVD5050 Portable DVD Player with Screen
My portable dvd says "wrong disc"
Hi, I have a coby portable dvd player. lately when i put a disk in it says "wrong disc" i know for sure that this disk is ok, more over it says that to any other disc i put in. what can be the problem? Thanks, Keren
  • 2 more comments
  • Keren Regev Aug 13, 2007
    Thanks for trying. For my portable DVD it didn?t help. After talking with coby (the manufacture) I have came to understand that I simply through $100 to the garbage - we used this portable DVD maybe 10 times since I bought it in February.
    Thanks for your advice anyway...
    keren
  • Anonymous Feb 26, 2008
    "wrong disc" message displayed on any disc I put in the dvd is new never used edee dvd224
  • Anonymous Nov 11, 2008
    I have the same problem, however, I have unplugged the system, cleaned the machine and even repositioned the player and I still get the same error. The player is only 4 months old how can I fix this?
  • Anonymous Feb 25, 2009
    every time i put in a disc it said "wrong disc". So i looked on some forums to no avail, but i was tinkering with it when i found out that if when i spun the disc in the opposite direction and then shut the case so that it would load, for whatever reason it works now. So i guess just spin the disc manually in the opposite direction it usually goes then shut the top and you're good to go.
    Hope this was helpful
Had same thing, was the holder that the dvd snaps into....it seems to slip downward on the shaft and making the disc to close to the eye. carfully work the carrier back up and no more error, works great!
Posted on Aug 25, 2007
  • 4 Answers
I've been having this problem too. I tried turning it off and then on, unplugging it, changing DVDs, and using the factory default. Nothing worked. AND THEN! I took the disc out and unplugged it for ten seconds. Now it is working. So just unplug it for a minute without a DVD in the drive.
Posted on Aug 13, 2007
  • Coby Master
  • 12,061 Answers
Your problem is either the laser Diode has faulted OR perhaps the Lens is "Dirty" it can be cleaned with a special "Cleaning Disk" but I would think unfortunately that the laser assembly has gone faulty, a common problem unfortunately :(
Posted on Jul 31, 2007
I have a coby vzon that says wrong disc but reads cds then when cleaned and blown loads up mp2 instead of dvd or says wrong disc still please help.
All DVD players use a dual laser pick up. One laser is for CD/VCD/MP3 and the other laser is only for DVD. If you have watched more DVD and less CD's you could be having a problem with the DVD laser. Must have become week and the system cannot read the disk. Change of the lens unit will solve your problem.
Mar 10, 2011 | Coby TF-DVD7107 Portable DVD Player
Says loading disk and then says wrong disk everytime. tried several different dvds. always the same answer!
The DVD portable player and the DVD disc came from the same countries?Ur DVD portable player and DVD disc u are using might have the wrong region DVD disc format frequencies.Like PAL frequencies only play Euroupean,Asia,Middle East,Austriala and Africa products.NTSC frequencise play only USA,Canada and Mexico DVD Disc products.
Dec 13, 2010 | Coby 7" Widescreen TFT Portable DVD Player...
Dvd player says loading then wrong disc
If it is disc made with a computer, you may need to convert the format to one that the DVD player is compatible with so it will recognize the disc contents.
Sep 22, 2009 | Coby TF-DVD7005 Portable DVD Player
Coby DVD shows Invalid Disc HELP PLEASE
Did you make the disk if you made the disk your computer has to give it a digital signature so the DVD player can read it if you're using a regular DVD then I would very carefully using rubbing alcohol and Q tip clean the actual laser I would be very careful doing this if too much rubbing alcohol is on the Q tip it will ruin the laser you can also try resetting the DVD player by taking out the battery and unplugging it from any power source and leave it that way for at least 20 seconds to a minute if that doesn't work you might have something else wrong
Jul 18, 2009 | Coby TF-DVD7005 Portable DVD Player
Coby DVD Player wont play
try running an optical disk cleaner it worked for me but I have to clean often.........a cheap fix if it works.
Jan 26, 2009 | Televison & Video
My coby portable dvd player keeps saying wrong disc
You may need to clean the laser in the unit. You can purchase a cleaning disk at Radio Shack or Best Buy. They are normally less than $20.
Nov 06, 2008 | Coby TF-DVD7107 Portable DVD Player
Coby 224 wrong disc
you can reset the settings through the menu, its under the advanced option in the menu. however, its not a regional error, if it was in the wrong region, it would say wrong region and not wrong disk, try putting the region back to 1 or 0 or 9, 1 is USA, 9 and 0 are all regions.
Jul 06, 2008 | Coby DVD-224 DVD Player
"another wrong disc"
I too do not understand how to check the motor or change the wire
Jun 29, 2008 | Coby TF-DVD7100 Portable DVD Player
Wrong Disc
I work for Coby technical support.
Thanks for using FixYa.
If the unit is showing "wrong disk" on every disk that you try to play, unfortunately, the unit has developed a defect and needs to be replaced. It can not be repaired. Our warranty is 90 days from the date of purchase. If you received the unit as a Xmas present, please call 1-800-727-3592 for instructions on getting the unit exchanged.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Aug 09, 2007 | Coby TF-DVD7005 Portable DVD Player
Dvd player will not spin disk
Unfortunately, your DVD player is broken. Portable units like these often get bumped and jostled and the motor that spins the DVD quits (very small and fragile). Sorry, I wish there were a magic button.
May 15, 2007 | Coby TFDVD5000 Portable DVD Player
Coby TF-DVD5050 Portable DVD Player with Screen Logo
304 people viewed this question
Top Coby Televison & Video Experts
Steve Allison
Steve Allison
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
