Question about Dell Latitude C500 Notebook
Upgrading Laptop Hard Drive
Hello Experts.
I am putting a larger hard drive in my Laptop.
I have a Dell C500 laptop (I know it's old).
I need to do a disk image onto a external portable hard drive (95 gig available). What software do I use to make the image file( hopefully free) and how do I boot the computer with the new blank drive in it so I can transfer the image back to it?
I have many applications that I no longer have COAs for so I need them transfered to new drive without reinstallation.
Thank you for time and consideration.
  • Dell Master
  • 32,281 Answers
I can't advise you on freeware disk imaging software, do a Google search yourself, but I can highly recommend Symantec Norton Ghost.
Posted on Jan 29, 2009
How can i get all my info from old hd to new one including os
If you've experienced trouble with your old hard drive, forget what I'm about to say here--you'll just end up copying bad data (including a corrupted OS) to your new HD.
Ok, having said that, if you're just upgrading to a newer, larger HD, and want to easily copy EVERYTHING, including Windows, to the larger one, first, go out, and buy a new one (yes, @Best Buy, or sometimes Office Depot or Staples has the 'best deals'), with this in mind:
Your laptop will only recognize a maximum of 120GB of space, so don't buy any larger (160GB and up) or they will all only show 137GB for your boot drive (although you can still accept that, and once done, merely download this freeware to create a new partition and use that as if it were another drive 'D:').
There are now only two major reputable dealers--Western Digital and Seagate ('cause Seagate bought out the third biggest, Maxtor, years ago).
Hard drives are one of the most justifiable new purchases, because 100% of them come with better hardware warranties than the ones do if you bought a brand-new laptop right now!
Seagate often sells theirs with a full-on 5-year replacement warranty, and Western Digital sells none with less than 3 years, so the $50-$100 you'll spend is more than worth it in a laptop.
Now, for the reason--those new HDs all come packaged with a software disc with Acronis' 'True Image' software, which will do all the work for you, perfectly, the very first time, as long as you follow the on-screen directions, and have the 'new HD' plugged in to your current laptop as an external drive--for that, you'll have to have a laptop IDE to USB enclosure (as in this link). They have 'em at Best Buy, but much more $$, I saw $39 online, so ...cheap may be fine, esp. if you only plan on doing this once!
Anyway, the software does the rest, immediately reading up that you have a new drive connected (after you install the CD), and actually asks you if you want to copy it (and you do).
It then performs a sometime lengthy bit-to-bit copy (you're legally required to kill off the old one or never use it again, by Microsoft's standards, remember)...and you're done--new, larger HD, with all your data AND Windows OS on it! NOTE: Sometimes this process requires that you reboot once again into your old hard drive with the new one still attached, to finish out!
Once this is done, you turn off your laptop, remove it's battery, then replace the old hard drive with the new one. If you've never done this, it's a lot easier than you'd think--Dell still offers this little method online at the following link>>>>>>>>CLICK HERE
See? Not hard at all!
Once you're done, and start the laptop back up, you'll see it act like it doesn't even know the difference, except you have more drive space.
Remember to download that freeware above (Partition Wizard) if you bought a drive larger than 120GB, because you can then make a new 'data' partition and use it to the max of that actual drive!
Feb 18, 2011 | Dell Inspiron 2200 Notebook
I have HP Pavilion dv6500 laptop with 120 gb hard drive. Are there problem issues upgrading to a 500gb or larger hard drive?
No there is no problem in upgrading the hard drive.
You can upgrade it as much as your system supports it.First check your system capacity of expansion of the hard drive's space.You must know the maximum capacity of the hard disk on your system .
Thanks.
Have a great day.
Sep 17, 2010 | Computers & Internet
I just purchased a external hard drive case to use bc i was upgrading my hard drive to my laptop. now my new laptop has the bigger hard drive and my old hard drive that came out of my laptop reads 4...
It sounds like your old laptop drive had 4 partitions on it.
If that is the case and you want it to be only one partition then you'll have to back up anything you want to keep in those partitions and reformat the drive as one partition.
You can reformat the drive using the Disk Management utility in Windows.
Dec 05, 2009 | Acomdata 250GB External Firewire HD 250 GB...
My Hitachi DK23EA-30 Hard Drive (Dell Laptop) takes forvever to
Sounds like maybe the hard drive is starting to fail (very common in a 15 yr. old laptop). See/get a new one here:
https://www.ebay.com/sch/i.html?_odkw=emachine+8230+power+supply&LH_PrefLoc=1&_sop=15&_armrs=1&_dmd=1&LH_BIN=1&_osacat=0&_ipg=100&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.XHitachi+DK23EA-30.TRS0&_nkw=Hitachi+DK23EA-30&_sacat=0
You should try and locate the support page for your Dell at Dell.com, because if you try to reinstall XP on a new hard drive, most likely many drivers will be missing, and you would have to get them from the Dell support page.
But installing XP in 2018 would leave you without hundreds of updates, as Microsoft has not supported XP since April 2014. They have not supported Vista since April 2017. So I would recommend upgrading to at least Windows 7, as Microsoft will probably support it until 2020.
I just installed Windows 7 on an old HP Celeron (Celeron processor is like one notch better than a Pentium 4). It works pretty well - turned off all the Win7 Aero junk to make it run a little faster. I can even watch YouTube on it and stuff! lol.
Good luck.
Jan 18, 2018 | Hitachi TravelStar DK23EA Series DK23EA-30...
Upgrading my old laptop
this are the things that will help you upgrade your laptop. first of all replace the ram memory with a higher configuration.then get your hard disk reformat by reinstalling fresh operating system like windows xp-sp2 or windows vista.install all the latest updates and drivers and its done. please do not forget to rate the solution.
Jun 12, 2009 | Dell Inspiron 2200 Notebook
Ze4325us laptop...hard drive upgrade.....
I know the original question is over a year old, but here it goes for those just tuning in. Your HP ze4325us can only recognize a hard drive that is under 137.4GB. If you try to install a hard disk larger than 137.4, your computer will start to fail over time. I would recommend a 120GB hard drive, ata-100 / ide / eide, and spinning up around 5400 or 7200 rps. It would make your task easier. If you want to go bigger, use the hard drive manufacturers disk utillities programs (check manufacturer website) to partition and format before installation. So, if you were to puchase a 160GB drive, you could partition it at 137.4GB and 22.6GB. My advice, make it easy and just find a 120GB drive. Less hassles!
May 25, 2008 | HP Pavilion ze4325us Notebook
Dell Cpi-A laptop Bios problem
Hello I am having the same problem. I have two batteries neither of which are detected even at full charge. My laptop only runs when its plugged in. My bios appears just as you said it remains stuck on the first page. This happened after my machine shut itself off i think due to overheating. I have done many upgrades and it has run great for over a year now. I have a much larger processor than my motherboard was meant for but it still ran with it in. Have you made any changes to your laptop recently? This happened to me right after i replaced the harddrive. Please let me know if you have fixed the problem thanks!
May 04, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Laptop
Here is the manual for your laptop.
Turn to page 118 for directions on how to change the hard drive.
Dec 30, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
65 people viewed this question
Alun Cox
