Question about D-Link AirPlus DI-524 Wireless Router
Low signal in the basement
We have a wireless network router 802-11g/2-4Ghz. Signal is strong on all 3 units in the house.
Computer in the basement is new addition to our network however signal in the basement is fading after few minutes. We checked internet connection by taking one of the other computers to the basement, they work fine, signal is strong, only the new one has this problem.
  • John LeFebvre May 11, 2010
    Also how are they connecting, USB dongle, PCMCIA cards, internal laptop antennae etc etc.
    Is the new PC a desktop or a laptop?
  • Allan Claunch
    Allan Claunch May 11, 2010
    What computer model and operating system?
Maybe you should try to purchase a better wireless adapter,like dlink dwa-110
Posted on Feb 14, 2009
Cant get wifi unless I am a couple of inches from router. All other wifi devices work perfectly. I even downloaded the latest driver directly from Intel and problem still exists.
Having a wireless Internet signal in your home allows multiple devices to use the same Internet connection without having to run lengths of Ethernet cable to each device. Given that the wireless network is transmitted over the air, the consistency of your Internet connection depends on the strength of the wireless signal. If wireless signal strength is not strong enough to give you a consistent Internet connection, there are a few simple steps for finding the problem and improving your signal strength.
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home.
Mar 01, 2013 | Samsung 19628 NP300V5A-A0AUS NP300V5AI
Poor signal with WiFi on my zeepad
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home. Hope this helps.
b>
Dec 13, 2012 | Computers & Internet
Connecting to wireless from my basement!
you need to add a repeater or signal booster for reciving signal in basement from uper floor.
My expierince is that whatever roueter you buy doenst matter it will not work properly if you are using wirless on 2 diffrent floors. on a same floor it can work smoothly even having walls.
Oct 02, 2009 | Dell TrueMobile 2300 Wireless Broadband...
Weak signal 60 feet away at neigbhoor's
Some routers just don't put out strong signals. The problems could be wiring in/around/at your house or neighbors....causing weak signal. Are the signal strengths strong in your house?
We have super signal strength on ours upstairs (we have a bi-level house) but downstairs the signal is very low. All the wiring in the house and anything electronic or otherwise can block it.
Hope this helps at least some. Good luck!
Jul 30, 2009 | D-Link DIR-625 (790069292637) Wireless...
2nd Computer in basement cannot access Internet
if your signal is low in there the best work around would be to lay a cat-5 cable up to the router, the wired connection would be faster and more reliable then a wireless, or buy another wireless router and put it closer to the basement than the first and wire the 2 routers togher with cat5 using the second router as a fancy switch.
Jul 02, 2009 | NetGear WGR614 Wireless Router
Using a Netgear wireless-G router wgr614 with an Actiontec GT704W
Try to avoid the breaker box and furnace as mutch as posible. Also you could try both computers wireless and put the router on first floor.
Mar 14, 2009 | NetGear WGR614 Wireless Router
Wireless router signal
I suggest that you move the router around to find the strongest signal for you computer or if your computer has a small antennae try moving that fround for the best signal
Lou Margolis
Allied Electronics
Aug 14, 2008 | NetGear WGR614 Wireless Router
Home network signal - boost needed
You can get a high gain antenna or better yet get a wireless range expander to repeat the signal of your router so it can reach the entire house.
hope that helps.......
Jun 20, 2008 | Linksys Wireless-G WRT54G Router
Linksys WUSB300N adapter not detecting wireless links
I am confused, you are using 2 routers, or you using their dsl modem/router? or your original??
Dec 29, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
D-Link AirPlus DI-524 Wireless Router Logo
257 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
