Question about Liquid Video L17LCD2 17" Flat Panel LCD Monitor
Blinking Blue Power Led on front, Monitor is non-responsive
Does anyone know what this means? Maybe there's something loose inside....I'm not feeling real confident about taking it apart, I've torn apart laptops and computers before without problems, this seems a bit tougher. Is this going to serve as an expensive paper weight for me or do you think there's something I can do to fix? Nothing displays on screen, just blue power LED on front flashing every few seconds or so when plugged in. Any help is appreciated... Thanks! Josh
Hello, I had a similar proglem with the Blue light flashing briefly and getting a glimpse of the screen. I fixed it by replacing C922, a 1000uf 16volt electrolytic capacitor as was suggested in another section here. These capacitors bulge on top when they fail, so if yoy take off the back cover you can look for C922 and see if the top is bulging. Compare it with other similar capacitors on the board. Good luck. John, K9KA
Posted on Sep 05, 2007
Hallo.Sorry for me english first.I have question.You plugg in a monitor with a notebok,or dektop pc? If you conect monitor with a notebook, i thing, you must change a display settings.This is very easy.On the ntb keyboar press and hold Fn-key and at same time press f4 key,and you cann chage the output canal for video signal,Lcd in notebook,external LCd or Both. I hope, it will help for you. Bye Perdo
Posted on Jul 27, 2007
Hisense LTDN42V77US will only power on and actually be functional at times and those times are diminishing. Have to unplug and plug back in and usually get 3 flashes of front LED then non responsive.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
May 29, 2016 | Hisense Televison & Video
How do I turn it on
Hello.
To power on the Gateway VX750, press the power button on the front. The power button has 3 sides with a "G" in the middle.
The LED indicates the power status of the monitor.
  • Not lit - The monitor is turned off or does not have power connected.
  • Blinks one time and then goes off - The LED blinks one time when the monitor's power cord is plugged into an AC outlet to indicate that power is detected.
  • Lit solid blue - The monitor is turned on and active.
  • Blinking blue - The monitor is in power saving mode. Before entering power saving mode, a message briefly appears.
Hope this helps.
Aug 12, 2010 | Gateway VX750 (Black, Platinum) 17" CRT...
Blinking blue power light and greenish tint....
Is the monitor still under warranty? (probably only the first 12 months)
Try connecting the monitor to a different desktop/notebook computer, to see if it is fine.
If it is, you have a problem with the video-card in your computer, not a problem with your monitor.
There are "capacitors" inside the monitor, that serve to supply "smooth" and "ripple-free" power to the electronic circuits. If you have "bad" capacitors, they are not doing what they should be doing, which causes the electronics to malfunction.
So, if your monitor is a CRT monitor, it's time to responsibly recycle it, and buy a new one.
If your monitor is an LCD monitor, take it to any TV/video repair shop, and pay them $25 to $50 to "inspect" it, looking for "bad caps". Or, spend that $25 to $50 to buy a new LCD monitor.
May 31, 2010 | eMachines E19T5W 19" Monitor
My monitor has blanking led blue also when not is connected a graphic card and the monitor does not turn off
if i want turn off the monitor it does not turn off. Connected or not connected is the same while when it was good if there wasn't the signal output the led was orange. Now if there is or there isn't the signal output the blue led blinks
May 10, 2010 | LG Flatron L1715S 17" LCD Monitor
After powered up, no video signal, power led blinking very fast
maybe u have to check ur video card if its is properly attached to the mobo...
Nov 06, 2009 | Computers & Internet
I am getting no response when i push the power button. I have a mitsubishi medallion 65'' 1080p tv. This just happened out of nowhere. there is no blinking light nothing. i noticed that there is power...
Front buttons . Remove the lower front speaker covers/panels by pulling . Then unplug connector ZF to the keypad . Then wait 3 minutes and try to turn it on with the remote . You may have to remove the access panel to find connector ZF (just follow the wiresdown from the front keypad). Don't touch , turn or break anything else while inside the access panel!
Let me know if that works
Oct 21, 2009 | Televison & Video
Hooked up a monitor and im not getting any picture. i just purchased the computer second hand today. i tried a second working monitor and still no pic. any ideas?..
Assuming that your monitors are good, if nothing is shown on the monitor, that means it does not receive any signal from the computer (or CPU). When you bought it, did they show you the computer and monitor are in good working condition (that means Windows desk top screen comes up on the monitor if it is a PC). If everything was OK when they showed you, but when you took it home, it does not any more, then maybe something became loose while transportation.
Make sure that when you turn the computer on, you hear the fan on the power supply and inside the computer running, and there should be some lights in front of the computer . If you do not hear anything nor see any lights in front of the computer then that is the reason nothing comes up on monitor. If it is the case, you may want to remove the cover of the computer and physically inspect inside the computer to see if anything becomes loose while transportation.
Just some ideas for you to work on. Good luck!
Aug 18, 2009 | Fujitsu Siemens SCENIC E600 Green PC...
Problem with Casio xj-s35 projector
You have to disconnect power to reset it.
Nov 08, 2008 | Casio XJ-S35 DLP Projector
LG Flatron ez t713sh 17" CRT Problem:
I already have the solution to that problem. It is a faulty capacitor that needs replacement. If you want you can copy and paste this link http://loversdelight-ididitmyself.blogspot.com.
Jun 30, 2008 | LG Flatron Ez T710BH 17" CRT Monitor
Monitor lite blinks from blue to yellow
I bought my monitor last year and had it for only a couple of months and the same thing, it is blinking the yellow and blue led. I can't believe that so many people are having the same problem. I went to the I-INC web site and there is nothing posted about this problem. I think that they really need to address this and let the consumers know what is going on with this. I feel like just trashing this monitor. I ahd to end up buying a cheap bulky monitor to replace it.
Dec 27, 2007 | Hannstar I-Inc TW-191D Monitor
Liquid Video L17LCD2 17" Flat Panel LCD Monitor Logo
80 people viewed this question
Top Liquid Video Computers & Internet Experts
Rommel Balcita
Mark Gough
Are you a Liquid Video Computer and Internet Expert? Answer questions, earn points and help others
