Boot up problem
What might be the reason for my PCs inability to boot up. The power comes on alright but it does not boot to load files and so nothing comes onto the monitor. I've tried so many means but still.
Initially, it will eventually boot up if you leave it on for a long time for it to get heated up. But now, it will never boot up even if you left it idle for the whole day or night.
I am using the Intel PIV D845PEBT2 mother board. Please I will be someone could kindly help me out.
  • Bright Dey
    Bright Dey Jan 29, 2009
    Thanks for the information but how do I do all the things you are describing. Could you please provide a detailed procedure and guidelines.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 51 Answers
There could be a number of things wrong here are a few things you can try if you are confident in your ability inside the computer case.
Reset the ram
Double check the CPU cooler and make sure that it is in the correct position
Double check the CPU coolers power connection to the three or four pin power connection
use Canned air duster and clean any dust out( be sure not ot let the fans spin freely while blowing)
If confident reapply thermal paste and thoroughly clean off older paste(any residue may affect cooling performance)
Posted on Jan 29, 2009
  • Jarrett Jan 29, 2009
    If you are not confident in the computer case this limits what i suggest you do.
    To reset the ram, First locate it usually it is positioned right of the cpu there are usually 4 slots and they have clips at each end. on these clips push down on them on each side and it should pop the ram out. Make sure you remember the oriantation of the ram. pull the ram out and re-seat it by pushing on the top end and the bottom end until it clicks back into place. repeat this for how ever many Sticks of ram you have.
    To check you Cpu coolers power conector locate the cooler usally a series of aluminium fins with a fan ontop once you hace located this there should be a insulated wire conected to the fan follow it to where it connects to the motherboard. Once you have found it make sure it is plugged in all the way.
    You can pick up Canned air at any computer or electronic store even wal-mart.
Why compaq presario SR3270nx won't boot but fan runs?
Hello There "A"
Usually PCs that won't boot its for any of these reasons:
1) Voltage on outlet check this*
2) bad Power Supply.
3) bad RAM
4) any near CPU capacitors, on the motherboard.*
Carl
May 04, 2014 | HP Compaq Presario SR2170NX (RK549AA#ABA)...
Using F2 at start up, I can't access BIOS on Gateway NE56R31u. Laptop powers on, CPU fan runs and HDD spins. No splash screen running Windows 8.0. Does motherboard Q5WVH LA-7912P Rev. 1.0 have solder
Based upon what you describe, it sounds like you have a boot zero (sector) virus on your hard drive.
http://www.spotmau.com/products/package/bootsuite.html?SSAID=450974&src=shareasale
Jan 03, 2014 | Gateway NE56R31U Celeron Dual-Core B830...
EL1358G-51w
The most common reason a computer won't start can be a piece of hardware has failed or is causing a problem but that hardware isn't usually a hard drive, the part of your computer that stores all of your files. To fix such kinds of issue, you can take the following steps.1.create a bootable usb or cd ,there are kinds of software for you to complete this step, you can choose Fix Boot,EasyBootDisk or Windows Boot Genius. I suggest you to use Windows Boot Genius, it is easier and more effective.2.boot your computer from the created disk3.fix the issue after run the softwareBy the way, before any further steps you should make sure the power supply is good. Any hardware issues such as pc power and cable,motherboard corrupted should be troubleshooted.I don't suggest you to try the solution above until you are sure there is nothing to do with the hardware.
source: http://windows-8-password-recovery.com/computer-wont-boot.html
Jan 15, 2013 | Acer Aspire Computers & Internet
Disk Boot Failure
There are a number of possibilities:
1. The BIOS setting for the boot device is not looking for the correct boot disk. This can happen if the modified by software or by a user unaware of the impact.
2. The BIOS battery may be dead, causing the machine to default to factory settings.
In either case above, reboot the machine, press the proper key to access the BIOS and verify that the proper device is selected as the boot disk and is first priority for boot.
3. The hard drive may have failed. The only solution here is a new hard drive, and a system reload/restore.
4. The OS may have gotten corrupted in the boot sector. TO fix this there are a few things that can be done, but for someone with little knowledge of PCs, this is dangerous territory. You can boot to the OS disk and go to the Repair Console, and attempt to do some fixes, such as CHECKDISK, and fixing the Master Boot Record (MBR), but these can result in total inability to recover. Best if you get to this point if yo can find a friend with some experience here to help.
Jan 12, 2012 | Computers & Internet
I have a Toshiba Tecra M7 that won't boot and up until this morning nothing worked. This is what I've done so far this morning WHEN it does decide to boot. 1. Power up computer from off with ESC...
Your hard drive may have gone south. Remove it and check with diagnostic software. Bad sectors in critical areas of operating system data will do this.
Apr 01, 2017 | Toshiba Tecra M7 Tablet PC
After Planet driver installation i have message : no boot file name received for realtek fast ethernet controler, the animation and windows starts. If card is removed out everything is normal. Please...
If I understand you well, before Windows loads, you get a notification about the ethernet controler. If this is the case, then you'll need to go to BIOS and change the boot options, so that your hard drive is set as first boot device, then DVD as second boot device, then USB drive as fourth boot device, and lastly LAN as fifth boot device.
What happens is that your PC thinks that the LAN is the primary boot device, and in corporate networks PCs bet such a setup so that there's one large server feeding data to the local cubicle PCs to such extent that these cubicle units are just "dumb terminals". In your situation, your PC thinks it should too get boot infro from the LAN, but as your PC is not a part of a corporate network it waits in vain, and after a while it moves on to the second/third boot device, and then finds that it has Windows installed localy and starts loading the OS.
So, to wrap up, you'll need to go to BIOS and set your local hard drive as the primary boot option.
If this was informative please give it a Thumb Up. Thank you.
Jan 20, 2011 | Planet Technology ENW-9605 (enw9605)...
HD booting in one PC but not in another
Ubuntu works with RAM and CPU Memory instead of a pc like xp that uses Virtual RAM. If the pc that could not load ubuntu doesn't have enough ram to support the reading of the Hard drive and the Operating System then it won't work and Xp will only run on the computer that xp was installed onto the hard drive.
Dec 19, 2009 | Computers & Internet
Booting Problems With Dell Optiplex gx270 and gx260
Does anything show up on the screen when you access your BIOS?
Have you tried a fresh install?
Are there two video adapters installed (one integrated and the other in the AGP slot?
Oct 14, 2009 | Dell OptiPlex GX270 PC Desktop
My Computer Does Not Boot
If your system is still not holding the date and time after changing out the CMOS battery, then ther is what is called a "cold" solder joint on the motherboard thjat might work, as you mentioned, after the system is warm.
However, sicne the system does boot up and operate later, it is more likely that the power supply has the issue and is not delivering power properly until it stabalizes.
Get a replacement PS, just make sure that it has at least the same wattage as the original one. You don't even have to physically install it at first, just swtich all the connections from the old one to the new one and see if the system comes up right away. It is does, then do the swap. If not, you can return it and replace the motherboard.
Jan 10, 2009 | Computers & Internet
DV9205eu display problem
HP has identified a hardware issue with certain HP Pavilion dv2000/dv6000/dv9000 and Compaq Presario V3000/V6000 series notebook PCs, and has also released a new BIOS for these notebook PCs, version F.39 for dv2000/V3000, and version F.3D for dv6000/dv9000/V6000.
Click HERE to update your BIOS
May 03, 2008 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
429 people viewed this question
David Payne
David Payne
