Question about Poulan Pro Chain Saw 46cc 20"
Rewind don't work
Hi I have a polan 2050 chain saw, and I replaced the rope fofr the rewind. So I put it back together and I pulled on it to start. and when the rope comes to the end it does not rewind back into the rewind. I got the same size rope but it calls for 39 inch and I think I put in about a 28 inch rope. but here is the thing I don't get is when I take the rewind pack apart it works It's just when it's on the saw it don.t work?
  • 360 Answers
As you put the side with the recoil starter back on the saw, ensure the rewind pack isn't binding. before tightening the screws, pull the rope out a few inches and let it rewind. if it won't, something is binding. keep moving the side panel till it will rewind. I have done this before myself. get it all put back together and it won't work.....
Posted on Jan 29, 2009
How do I cure kickback when starting a Stihl 044 chain saw , as soon as you pull the starter cord it snatches it out of your hand it really hurts.
pull rope just pass compression piston top dead center release rope let it rewind fully .then pull rope quick and firm.
Oct 10, 2017 | Stihl Garden
Cord rewind assembly
If you place the chain saw on a work bench with the bar and chain pointing at you. We will call the side with the chain and bar the left and the side where you gas and oil the saw the right side. Now on the right side just behind the oil filler cap is the starter rope and assembly . There are four screws that holds this assembly to the saw. Remove these 4 screws while carefully watching and lifting this assembly from the saw. turn the assembly over and if you can see and grab the old starter rope . Grasp it and pull out on the rope a few times so you can see how it works, play with it a bit, so that when you replace the old rope with a new you will be familiar with the action.You can find starter rope at local chain saw or hardware stores, estimate the length you will need. Re-thread the new rope in opposite direction that you saw the old rope function being careful to duplicate the knot at the end of the rope which will be inside the assembly, threaded in as you saw the old one come out. So look carefully. Play with it a bit. Familiarize yourself with how the two holes line up and thread through the spool and the knot is tied. Now make sure the end of the rope coming out of the assembly has the recoil action. Tie on the handle being sure to take only enough re-coil that there is no slack in the rope and handle end. Replace the assembly and check the action. Have fun! Alvin
Sep 30, 2013 | Husqvarna Garden
Homelite chain saw XL925 cord pull too hard but if you remove the spark plug then it pulls OK.
I have a Homelite XL and was having problems with rope pulling from difficult to unable to pull rope while trying to start saw. I removed the muffler, squirted some WD40 through the exhaust port ABOVE and BELOW the piston compression ring. Then pulled the rope about 20 times without spark plug to fully lubricate the piston and cylinder. Left it till the next day, pulled it through about 20 more times, put the spark plug back in,and it works well now. Guess it was just gummed-up a little and the lubrication freed it.
Oct 31, 2011 | Homelite ZR10926 16 Chain Saw
Homelite model No. 10609. 1H2100076 My pull rope won't recoil.
Not that i know of, take the cover off and rewind by hand, use greese on the coil and pull the rope in and out, if the rope doesnt recoil you are going to need a new pull start assembly
Apr 28, 2010 | Homelite ZR10926 16 Chain Saw
Starting rope won't rewind
There are two or three screws that hold the retract assembly on to the engine cover. Take these off, and pull the retract off. First, try to turn the pulley on the inside in the direction that the rope would turn it if you you were pulling it out. Will it rewind? If not, there is a screw on the top of this assembly, that's covered up with a sticker. you'll need to remove this screw, and pull the pulley out. There will be a spring on the inside of this. check the spring to see if it's broken. If not, and it's just come loose, put it back into the slot that holds it, and wind it up enough to get it back together. turn the spring in the direction that the rope would pull it out, until it won't go any more. Hold it, and reinsert the rope, tie a couple of good knots in the end, trim the excess, and let it retract the rope into the assembly. Put the assembly back on your engine, and you're good to go.
Feb 09, 2010 | Yard Machines Tecumseh 148cc Front Tine...
The pull cord will not retract back into the saw. When I tried to start the saw, I pulled the cord and now it did not retract back. It is all the way out and will not recoil.
When I have had this happen it means that you need to manually rewind the cord and put some additional tension on the take up pulley. To do this you'll have to open the saw up and untie the handle. Turn the pulley like one turn, put the rope back through the hole and tie the handle back on. All this is done while maintaining tension on the rope.
Feb 05, 2010 | Poulan Pro Chain Saw 46cc 20"
Poulan model p3314 recoil spring won't go in correctly
You need to pretension it. Remove the pull handle, rotate the spool about 2 revolutions against the spring, rethread the cord and reinstall the handle.
Lou
Sep 04, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan 16" cannot start...pull cord locked up
Remove the cover, should be 4 screws that holds it on once the 4 screws are loosened the rope could rewind on its own. If not check to make sure the spring is not broken.
Apr 06, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Spring repacement
Hi fwadden
Remove the housing-fan. Remove the screw and detach the pulley- starter and the spring -starter.Put the new spring-starter(it usualy comes with a support).The spring-starter"spires are counterclockwise oriented.Put the puley starter back and the screw.Wrap up the rope clockwise on the pulley-starter until the starter works propperly.Hope this helps you.
best regards savumihai71
Dec 12, 2008 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro Chain Saw 46cc 20" Logo
147 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
