Question about Vtech IA5854 5.8 GHz Cordless Phone
Phone has "no line" on screen - Vtech IA5854 5.8 GHz Cordless Phone
  • Vtech Master
  • 5,264 Answers
First have you checked the phone line for a dial tone? Is the cable undamaged and plugged into both the phone base and the wall. I keep an old rotary phone and extra RJ11 cables among my diagnostic tools just to track if a phone problem is inside, outside or an individual phone.
I hope this gives you a starting place. I can't help you beyond this. If the problem is the base or the handset, you'll need someone with knowledge of that model or its manual.
(who has lost phone service due to a cut cable down the road (underground service) as well as a problem at the junction near the street.)
Posted on Jan 29, 2009
My nokia 6500 slide, has some problem with its screen. first it was a light brown symbol on the screen and later, two lines appeared to the left side of the symbol horizontally. and now, one more line...
Hi, You will need to unscrew the phone and see if the phone screen is not broken, if the screen is not broken, that means the fllex of the phone is damaged and will need to be replaced.
The flex controls the displaying of the screen.
Oct 08, 2010 | Nokia 6500 Slide Cellular Phone
There is black horizontal line appearing in my Samsung Star phone. This line runs through the entire width.
i think you need a new screen ? but if you find the factory reset code some phone let you chose other test your phone screen ? but make sure you dont reset your phone to the factory reset settings ?
Sep 22, 2010 | Cell Phones
The display of my phone is working but for last 2 days , there are 3 -4 horizontal lines . i dnt knw the reason . i evn tried factory settings but of no use . please provide me with necessary remedy for...
Hi, possible causes for horizontal line on screen are,
Phone Screen problem and,
The flex of a phone.
When a screen displays horizontal lines on the screen, is when screen of the phone is getting damaged due to phone falling on the ground,or hitting phone on an object can cause horizontal line on a screen.
Solution to this problem is to replace the screen of the phone.
The flex of the phone can also cause horizontal lines on a screen. The flex is a thread like object inside the phone that makes the phone to function properly in terms of the display..
When the flex is getting damaged, it can cause such horizontal line on the screen display.
Solution for this problem,is to replace the flex.
Note : flex can be found only on slide phones.
Thanks for using fixya........
Sep 15, 2010 | Nokia BH500 Bluetooth Headset For N95 8GB...
C905 SCREEN IS CRACKED AND CAUSING THE SCREEN TO BE ALL LINES THREW IT AND CANT READ MSG
in this case, you need to replace the screen of your phone. That would be the only way to get rid of the lines.
Get a phone screw driver, loose the phone, remove the screen, take it to a phone accessories shop and use it as a sample in order to get the correct/right screen replacement, and do the replacement yourself.
Or if this task is to much for you, you can simply take the phone to a repairman to help you out.
Take care.
Sep 01, 2010 | Sony Ericsson Cyber-shot C905 Cell Phone
Lg phone screen cracked but when you look it closely it doesn't have crack lines. crack lines only appears when it is turned on and not present when the phone is turned off why am i suppose to do?
The glass of the lcd screen is not cracked, but internally the display is'nt working perfect, few lines are not displayed on the screen which makes us to assume that the screen is cracked which is not the case, you need to replace the display, it its one or two lines you can use the same display screen, their won't be any damage to your phone due to non display of few lines.
Jul 29, 2010 | LG Televison & Video
Lines on phone
More than likely you will need to replace the display screen. Those lines are a symptom of the LCD screen going bad. If you are still under warranty, see if you can get it replaced
If not, a new LCD screen runs about 15 dollars shipped from eBay and is pretty easy to replace.
Check out the following link for instructions on replacing the LCD display and links to buy the screen.
Sony Ericsson W580i LCD Display Replacement
I hope that helps you out
Jun 03, 2009 | AT&T Sony Ericsson W580i Cell Phone -...
AT&T Model 854 4 line phone, turn off unused line lights
It's a matter of cabling.
Make sure that only the line you wish to use is connected.
If all of the lines are cabled with two to four line cable, then reduce the cabling to a single red/black combination on the one line.
Apr 25, 2009 | AT&T ATT-974 Corded Phone
I have lines on my nokia N70 screen
hi
may your memory card containing the virus restart your mobile phone with out memory card
thanks
your friend from fixya!
Oct 25, 2008 | Nokia N70 Cellular Phone
Screen has lines coming when i make phone calls
its your battery.. make it full charge..
Jan 09, 2008 | Nokia 6300 Cellular Phone
Vtech IA5854 5.8 GHz Cordless Phone Logo
109 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
