Question about Omega Seamaster James Bond 007 2220.80 Watch for Men
Left hand side winder
What is it's function
  • 2,334 Answers
The crown on the left side is HELIUM VALVE and is designed for compensating and keeping the right air pressure inside watch case if it is used for diving purposes.
If you will try to set something using this crown, nothing will happen, as it has special springs, gaskets and bars built into it, but has no any connection with watch movement.
Do not forget to rate, please.
Posted on Jan 31, 2009
Weide wh1103 watch.hands stopped working.function buttons work ok.battery powered.hands move when turning winder button.
The Weide watches use springs for their electrical connectivity and I've found that they don't work very well. I had the same problem and after tinkering with all of the connections I came to the conclusion that they were built to not have the battery replaced.
Nov 01, 2017 | Watches
I cant set the time on my casio ediffice 5118 watch
you will find the instructions on the first page left hand side
the crown is the funny litle winder thing like thing that exists on the older wristwachers
Jan 12, 2014 | Casio Watches
Stop watch not zeroing
Pull out winder 1 step and us the push buttons to adjust hands to 12 o.clock . when you have done this pull winder right out and use push buttons to set other hands then push winder back in.
Jul 06, 2010 | Tag Heuer Aquaracer Quartz Chronograph...
I have a new tissot Prc100 T22268631 watch, but i don't know how to adjust the time and date. What will I do?
The usual way to adjust time and date is to screw out (not pull) the winder and rotate it backwards or forwards. The winder will have two "out"positions, one for the date and the other for the time. (the "screw" for the winder is to improve water resistance).
If you have already tried this and it does not work, then go to the Tissot web site "tissot.com", locate your nearest dealer and ask for advice.
Alternatively on the Tissot site find your watch under the heading "sport". To view all the watches in a section move your cursor along the dots, this moves the images along to find the one you want.
Select the PRC100 and details of your watch appear and at the bottom of the menu on the left hand side select "user manuals".
Click on "download" on the right and instructions will appear
Jan 13, 2010 | Tissot Prc100 T22268631 Watch
Instructions were for a different fully analog model. The major problem aside from the digital settings, is the mechanical setting of the hands. Even after pulling crown out to position 3, the hands won't...
Tag Multigraph: With the crown pushed in you turn the winder quickly a couple of times and the digital displays appear. Scroll through to the function you want then pull the crown out and turn it to change time/settings. The time can be changed either by pulling the crown out on the T setting (digital) or when no digital display is shown on the dial. If you turn the winder slowly the time/settings change very slowly, which is barely visible. If you flick the winder round very quickly the settings leap forward faster.
Aug 05, 2009 | Tag Heuer 2000 Classic Multigraph...
What is the function of the winder on left hand side please
Jan 29, 2009 | Omega Seamaster James Bond 007 2220.80...
I have a Rado DiaStar watch (with digital display), and the hands are out of synch with the digital display. Is there a way of adjusting the hands independently of the display? or must it be sent back to...
Hears how i do my watch, i have the same watch as you.Just make sure nothing is displayed on the clock face by turning the winder, ie NO digital time, NO daul time, NO alarm, NO stop watch etc, Pull out the winder(crown) and adjust the hands to the time you require by spinning the winder.(Gentley for mins and fast for hours) The digital clock will display wilst doing this, but not change the time.handy if you want to sync both clocks.Push the winder back in at the time to sync and the digital display will go out, then spin the winder again if you want to display the digital features. I hope this helps, please post if it does, Maurice Chevalier- Herts
Nov 01, 2008 | Rado Diastar Anatom Jubile watch
Adjust the date and day on a festina 3 dial watch
I've just worked it out! Change month....depress inset button on side above hand winder. One push with cocktail stick or similar will advance month. Change date.....pull out hand winder half way, turn knob anti-clockwise until desired number is met. Change day...... pull out hand winder fully, turn clockwise passing midnight repeatedly until day is set, continue to set time, keeping an eye on 24 hour display for am/pm.
All the best, Bob
May 06, 2008 | La Crosse Technology E. Howard Ambassador...
How do i change second hand
I have a Fossil Speedway watch (FS2895). The second hand was on the 2, and I wanted it on the 12. Like the above suggestion says, pull out the winder twice as if you are going to reset the time. However, leave the winder alone after that and, instead, press and hold the chronograph start/stop button (above the winder) until the second hand reaches the desired position. If you want to move the hand a small bit at a time, just press and release that same button until the hand reaches the desired position.
Apr 02, 2008 | Watches
Omega Seamaster James Bond 007 2220.80 Watch for Men Logo
163 people viewed this question
Top Omega Watches Experts
Geoff
NavigatorX
Level 1 Expert
Are you an Omega Watch Expert? Answer questions, earn points and help others
