Question about Oster Golden A5 2-Speed Universal Motor Clipper 78005-140
Blades are not cutting
I had my blades sharpened and sent them back cause they would not cut. They catch the hair in the blade instead of cutting. I have been trying to line them up again. Not sure of if there is a way to know they are set properly? Can these blades ware out and be no good anymore? Help me know if I can solve this problem please.
  • 193 Answers
Hi, yes blades can wear out but your sharpener should advise if there is a problem with them. check to make sure the clipper is moving your blades and your blade cannot be removed without depressing the latch. If your are experiencing tram lines with larger blades then it is more likely to be a clipper problem. However if your blades just wont cut i would recommend a new sharpener as it is a specialist area.
Posted on Mar 15, 2009
Hi, I have a Braun series 3 shaver and sometimes
blades are blunt and the hair gets stuck between the clipper blade and the fixed blade
have them sharpened or replace with new one s
Nov 10, 2017 | Braun 380 Electric Shaver
Andis agc 2 not cutting very well
Yep as simple as that just make sure they are a well recignised sharpener otherwise you will waste your money. You can rule out a clipper problem if other blades cut ok. Clipper Blade Sharpening
Mar 03, 2013 | Andis AGC2 Hair Trimmer
My clippers are pulling the dog hair instead of cutting, why?
Most common cause will be the blades have gone dull and should be sharpened or replaced. Check that the 2 screws on the blade latch assy are tight where it screws onto the front housing, blade off to check them. 3rd thing to check is for excessive wear in the lever that drives the blades, if it is worn replace it.
Nov 24, 2012 | Wahl KM2 Speed Electric Clipper: Two Speed...
I have an Andis outliner II I purchased a year ago. I recently changed the blade but it won't cut my hair. Do you kow why?
Sometimes the new blades from Andis are not sharpen enough to get that clean cut. also all trimmers need to be readjusted for power and alignment, plus sharpening the blade, it look like you need a complete sharpen & service on your Andis trimmer. check out Manny's Sharpening they have a Mail Order service, the service they provide is fast and they will sharpen make all the adjustment and give your trimmer more power and the blade will cut clean. They will even adjust the blade at your request on how you want that blade to be set at. Line Ups or Fade Cuts and even shave set. Manny's Sharpening been around for over 20 years and they have a very good rating on the net. Check it out Manny's Sharpening
May 21, 2011 | Andis Outliner II Hair Trimmer
My andis t-outliner keeps pulling hair when cutting and it barley cuts the hair. Do the blades need adjusting?
sound like your clipper blades may require sharpening, just remove the blades and send them to a professional company specialising in scissor and clipper sharpening.
Jun 08, 2010 | Andis 01690 Hair Trimmer
Hi, used a blade sharpener for my a2 horse clipper blades and they are still blunt. Do i sharpen between the teeth
no . The blades are sharpened by grinding away the base of the wear until the edges between the teeth are sharp. It also necessary for the tension between the cutting blades is correct other wise the cutting teeth ride up over the hair and will not cut. Have a person who does sharpening of knives ,scissors and blades sharpen the clippers for you as the machine will get it right.
Nov 18, 2009 | Makita 9820 - 2 Blade Sharpener
Oster A5 single speed clipper not cutting
not usually we will not sharpen blades that are worn out as we cannot charge for something that does not cut!
make sure your blade is connecting with the drive of your clipper they might need an extra push depending if the blade has been adjusted.
Jul 17, 2008 | Oster 76974-160 Hair Trimmer
Wahl razor's not cutting, how do I fix it?
have you tried taking apart the blades and replacing them so that they line up together? Have you had a professional shear sharpener look at your blades? mabie all they need is to be sharpened again. Blades like knives or scissors need to be sharpened every once in a while. Also try replacing the blades with a new ones. The blades may have worn out. also try oiling the blades every once in a while.
Jun 24, 2008 | Wahl The Peanut Hair Trimmer
Wahl clippers
Contact a scisor sharpener in your area. They usually do clipper blades as well ..
Oct 04, 2007 | Health & Beauty
Oster Golden A5 2-Speed Universal Motor Clipper 78005-140 Logo
541 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
