Question about Gold Medal 5094 Deep Fryer
Gold medal 5094 fryer
We are having problem with the 5094 gold medal fryer need help. You get it lit and will get up to temp maybe stay on for a while then all of a sudden the gas shuts off ploit and all then the next time you try to lite it you have proplems then maybe it will lite stay on . Then mabey not.
  • klansey Jan 03, 2008
    i have a gold metal fryer that is propane.
    The jets will not stay lit, some will not light at all. I cant maintain my cooking temperature.
    I was told that it could possibly be a build up of carbon in the jets, is this possible? if it is how can the problem be corrected.
    Have others experienced similar problems with this deep fryer.
    Can anyone help? Or refer me to a knowledable service center in the Los Angeles area.
    Thank you
    AS
  • 640 Answers
It sounds like the pilot orfice could be clogged or the thermocouple is weak.will the pilot always light then go out?if so the t-couple is bad
Posted on Aug 06, 2007
Hey
i've got two gold medal fryers up in canada
yes, carbon does build up and things either won't stay lit, or they only fire partially.
the jets are pin sized holes, and carbon will build up to the point that they won't even fire.
clean the jet noodle heads (copper fixings where flame comes out)
i'll tell you right now though...they are hard to get at in the 5094, a little easier in the 5099
thxs
Derek Husser
Summer Fun Funnel Cakes
Posted on Jan 25, 2008
What is part number for high limit??
Check old one, ask appliance parts house for replacement. Try Ebay or thefind.com
Mar 08, 2015 | Gold Medal Products 8068FL Gold Medal -...
Gas fire wont stay lit
The thermostat probably reached the set temp, but maybe the pilot lite blew out. Or the control needs to be replaced.
Nov 25, 2013 | Kitchen Appliances - Others
Bakers pride deep fryer will only stay lit for couple of minutes and then shut off
Hi there!
Normally hi limit sensing bulb is thicker and shorter than that of thermostat.
Try tightening all wire terminal crimps and connection.
Regards.
Feb 05, 2013 | Imperial IFS40 Deep Fryer
Hi i have a new imperial fryer and im tring to light it and cant seem to get it to work. any idea on how to get it working?
Have a lighter handy (I use one of the elongated ones for caravaners)
in-between the burners is a pilot light (top right) keep the lighter flame where the gas comes out.
On the right hand side of the fryer at the bottom is a gas valve with a little black knob.
Press and hold the black knob in and gas will come out of the pilot light and ignite by the lighter flame. You need to hold the button in for quite a while. (until it stays lit)
When it stays lit depress the little black knob and turn it anti clockwise. Gas comes out of the burners and ignites from the pilot light. When it reaches temp. it will cut out.
To turn it off turn the little black knob clockwise. To turn the pilot light off, push and turn clockwise.
Mar 04, 2011 | Imperial IFS40 Deep Fryer
Pilot stays lit but when you turn on temp switch pilot gets very low and burners will not light
has orifice been changed? Is this a used fryer that may have previously operated on LP gas? If so, there will be insufficient volume of gas (Nat) to the burner. Also check supply pressure at unit. Make sure supply line isn't damaged or distorted in that it may restrict flow to fryer.
Nov 19, 2010 | Pitco Frialator SG14 Deep Fryer
Light pilot on Royal deep fryer. Pilot will not stay lit. Second fryer has larger pilot have no trouble keeping it lit. How can I adjust the pilot so that it will stay lit?
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
Feb 06, 2010 | Vulcan GR45 Deep Fryer
Imperial gas fryer problem, when the burners are
You have a bad gas valve. It's not reading the signal from the thermostat. The gas valve is stuck open.
Oct 19, 2009 | Imperial IFS40 Deep Fryer
Imperial fryer IFS-40
I had a very simular problem. My fryer would do exactly as you described, but sometimes the pilot light would stay on until the burners tried to re-ignite and then it would go out.
I finally had to call the gas company. They took the pilot light apart and cleaned it. The fryer works perfect now.
Hope this helps!
Ken
Oct 18, 2008 | Imperial IFS40 Deep Fryer
Temperature flux
may be your regolator not working properly. to check it u can use another applience or change it.
Hamid
Aug 11, 2008 | Imperial IFS40 Deep Fryer
Gold Medal 5094 Deep Fryer Logo
494 people viewed this question
Top Gold Medal Kitchen Appliances - Others Experts
john h
Tom Chichester
Jerry King
Jerry King
Are you a Gold Medal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
