Question about Jenn-Air JED8230 Electric Cooktop
Griddle needs to be cleaned
The griddle has burnt on stuff all over it and needs to be cleaned but I'm afraid i will take the coating off. Any ideas on how to clean this off?
    President:
  • 1,214 Answers
Slide an old towel underneath the griddle to protect any painted surfaces.
Then carefully spray easy off onto the surfaces, or, soak another towel in easy off or other cleaner, and lay on the soiled surfaces, pressing down to assure good contact. Lay another towel on top, and allow to lay there for awhile.
I really dont' think you've got anything to worry about. Most cooktops are today are powder coated, rather than laqeur painted. Powder coat is a hard, baked on surface. It won't solvent melt like finsihes of old.
Posted on Jan 29, 2009
Replacement Griddle for Kitchen aid KGCP463KSS
If Kitchen Aid is of no help, try an appliance parts supplier
Apr 21, 2013 | KitchenAid 36 in. Architect KGCP463KSS Gas...
A guest used the electric griddle on my Jenn-Air. She made terriaki chicken and now the griddle has balack cooked on stuff ( probably from the sugar in the terrikaki sauce. I've had this griddle for...
if it has slightly raised sides or a fat drain
let it heart up and then used water on the hot surface to steam loosen the crud
you could put a bit of washing up detergent in the water ( just a few drops )to assist in breaking down the surface tension and release any grease
The same as cleaning a BBQ plate before using it
Nov 18, 2017 | Jenn-Air JED8230 Electric Cooktop
How do I clean a Viking griddle that hasbeen
I use a product called Greasecutter Plus by ECOLAB, it makes the griddle look brand new, gets everything off. You just spray it on and let it set for a little bit then it wipes clean.
May 13, 2010 | Viking Cooktops
Need to restore the non-stick surface on a GE griddle
Put a sheet of wax paper between the two plates for a few minutes while it heats up, then remove. It will transfer the wax to the grill so you'll temporarily restore the non-stick coating.
Oct 17, 2009 | GE Cooktops
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
KitchenAid Stovetop with grill and griddle - KGCP484KSS0
hi im gerbee, try to clean the sensor valve by using a scott brite, the sensor place in the side wen the flame is on like a gold metal, 2nd try to adjust the flame control by using a plat or + screw,u see it at the gas control knot on top the small screw.adjust to high flame is touch the sensor valve.sory for my english.tnx gerbee i hope i help u
Nov 30, 2008 | KitchenAid Architect KGCP484KSS Gas...
Thermador PCS364GDUS griddle needs cleaning.
Wear gloves, put all items in a garbage bag. Put outside and spray a can of easy-off oven cleaner on all parts. Seal bag and let sit for 24 hrs. They should come out looking new after you rinse them off. After you wash them off, put them in a 300* preheated oven for about 30 min to ensure they are dry.
Oct 22, 2008 | Thermador PC366BS Stainless Steel Gas...
Broken griddle control
Hello
It sounds like you have a short. Replace the switch is very simple. Here are the Owners Manual and the Instalation Instructions.
  • Owners Manuals (1)
  • CCGP2720P.pdf (942.48 KB)
  • Jun 28, 2008 | Jenn-Air 36 in. CCGP2720P Gas Cooktop
    Jenn-Air JED8230 Electric Cooktop Logo
    496 people viewed this question
    Top Jenn-Air Cooktops Experts
    Dan Webster
    Dan Webster
    jason
    Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
