Question about Dishwashers
Dishwasher discolored The inside of my dishwasher turned orange...How do I fix this?
    Scholar:
  • 140 Answers
Cause = Pasta sauce.
Normally if you run the dishwasher empty (but with proper soap), this can clear it up. Or try running a short cycle with vinegar (about 2 cups) this can also clear it up sometimes.
Posted on Jan 29, 2009
2 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: discolored inside after wash
well i would suspect rusty water heater, best thing to do is trace back the water line and find out where it's clear and when it turns color.
Posted on Jan 09, 2008
Steamist unit installed by general contractor and shower enclosed in porous marble product. Orange discoloration has appeared around the metallic steam dispensing device. What could be causing this?
Orange discoloration is most often caused by rust or other minerals in the water.
Usually, the solution is to have a filter (or more than one) installed in the circuit.
God bless your efforts.
Jan 06, 2017 | Steamist Electrical Supplies
Discolored copper hue inside
A copper discoloration is usually caused from iron in the water. One way to help would be to use a water softener with the green bag of salt. The green bag of salt helps with iron content.
Sep 06, 2011 | Cma Dishmachines AFB Dishwasher
I have my Mom's 193909WB coffeemaker, It runs like a top! How do I clean it?
Here are the cleaning instructions directly from West Bend's instruction manual. Good luck!
Cleaning Instructions
1. Unplug coffeemaker and allow to cool before cleaning.
2. Clean basket, stem and cover in hot soapy water with a dishcloth, rinse and dry. Coffee stains on underside of cover or stem may be removed by scouring with a damp cloth and a non-abrasive cleanser.
3. Clean inside of coffeemaker by filling with hot water until about one-third full. Add small amount of liquid dishwasher detergent and wash with a dishcloth or sponge. Then clean the heating unit well (where stem fits) with a scouring pad, to remove coffee residue. Twist pad inside heating unit well to clean thoroughly. IMPORTANT: If heating unit well is not kept clean, coffeemaker will not perform properly.
4. After cleaning inside of coffeemaker, drain and rinse inside. Clean faucet by letting clear water run through it into sink, while moving faucet handle up and down. Drain water from inside of coffeemaker and dry.
5. Clean outside of coffeemaker with a damp cloth and dry with a soft cloth. Do not use abrasive metal scouring pads or cleansers on outside of coffeemaker as scratching will occur.
DO NOT WASH COFFEEMAKER PARTS IN AN AUTOMATIC DISHWASHER.
Special Cleaning Instructions
To Remove Mineral Deposits: If coffeemaker is used daily, a special cleaning every 2 weeks OR every week if used for heating water, is necessary. Fill coffeemaker with 1 quart each of water and white distilled vinegar. (If a white mineral buildup has formed on inside of coffeemaker, use an additional 2 cups of vinegar.) Place stem and empty coffee basket in place, secure cover onto coffeemaker and plug in. Allow coffeemaker to complete perking cycle, then let stand for 10 to 15 minutes. Unplug and drain coffeemaker. Allow to cool and follow general cleaning instructions.
To Remove Discoloration: Inside of the coffeemaker can discolor when used for heating water, which is normal. To remove/lighten discoloration, fill coffeemaker with water to the level of discoloration (at least to the 12 cup level, but not past maximum cup level). Place stem and empty basket in place. For every 12 cups of water added to coffeemaker, add 2 teaspoons cream of tartar to basket. Secure cover onto coffeemaker, plug cord into coffemaker and then into outlet and allow coffeemaker to complete perk cycle. Let stand for 15 to 20 minutes or until discoloration is lightened. Unplug cord and drain coffeemaker. Allow to cool and follow general cleaning instructions.
Do not use baking soda to clean coffeemaker, as it will discolor inside metal.
After frequent use, coffee residue may collect inside faucet. To clean, unscrew top half of faucet. Move a small brush up and down through faucet. Insert brush through opening inside coffeemaker to clean faucet connection. Rinse and replace top half of faucet.
Jan 11, 2011 | West Bend (58036) 36-Cup Coffee Maker
Have Whirlpool dishwasher #GU2300xtsqo. White
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 16, 2010 | Whirlpool GU2300XTS 24 in Builtin...
Discolorization(orange) inside coffee maker.
Try mixing in some vinegar with your water (about a cup) and run it through a cycle, this may clean it out.
Tom
Oct 04, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
What causes an orange stain in the tub of the dishwasher and around the edge of the door?
Dishwashers are prone to mold and mildew this time of year. Clean all of the orange stains with a solution of one cup of clorox bleach in two quarts of water. Then run the dishwasher on its hottest and longest cycle adding only two cups of vinegar through the door opening. That will clean up the entire insides and remove the clorox smell.
Aug 02, 2009 | Dishwashers
Clothes and our towels have an orange discoloration
The orange spots are caused by benzoyl peroxide that is used in some facial cleaners.
Jul 18, 2009 | Kenmore Washing Machines
Discolored inside after wash
Dec 16, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Dishwashers Logo
357 people viewed this question
Top Dishwashers Experts
