Question about Frigidaire Gallery GLEFM397DS Electric Kitchen Range
I want to replace the bottom oven panel under the heating element
I have burnt the finish off, I know I'm supposed to remove the heating elements before I do anything but it looks like a special tool is required to remove them. Then after I remove them how do I get the old panel out?
  • 3 more comments
  • tws10 Jan 29, 2009
    The bottom part of the oven, under the heating elements is all discolored & the nice shiny finish is gone. I have the new part to replace it. On Frigidaire's body part diagram it is position 8A, part #316411102. I've been told that I first have to remove the heating elements but it looks like I need a special tool to do that. And once I do that how do I get the old piece (bottom of oven) out?'
    Thanks for any help!
    TWS10
    I wanted to run the self clean but the person I spoke to at Frigidaire asked me if I had used a chemical on the bottom & I said yes. What I used was Zud, vinegar, ammonia, grease relief, etc. So she told me not to run the self clean.
    The problem happened because I put an aluminum oven liner on top of the heating element forgetting that I had a silicone liner on the bottom piece under the heating element. The heating element burnt partly through the aluminum & the silicone liner sort of shredded. The consequence was a tremendous amount of smoke when I opened the oven door & a burning in my throat & my family's throats which lasted at least an hour. For all I know, the heating elements may need to be replaced also. There's still some odor in the oven & this all happened just about a month ago.
  • tws10 Jan 31, 2009
    I'll give it a shot & get back to you! Thanks!
  • robert samples May 11, 2010
    have you run self clean
    i dont understand what you mean by burnt the finish off and what you want to replace do you mean the ovencavity how could you burn the finish off that
    President:
  • 1,314 Answers
Well the person at frigidaire was talking about caustic chems like easy off elements should be ok get as much of the silicone and foil out as you can then run self clean only prob i see is the oder the oven wilkl self clean for three hours send the misses and kids to a movie get you a six pack of brew sit on the front proach depending on where you live and let er rip then lets see what to do from there how much stuff you got stuck on there
Posted on Jan 30, 2009
Bottom oven bottom element doesn't heat
Phil. If you do not have voltage at the element, then the Electronic Oven Control ( EOC ) has failed. Part number # 5701M403-60
In order to check for the correct voltage at the element you will need to remove power and pull the range out of its installed location and remove the back panel of the range to gain access to the wiring and element. CAUTION ! I cannot stress this enough ! There are dangerous voltages in this area!! After the panel has been removed, return power to the range,set the lower oven to bake, and check the voltage at the element. You should find 220-240 volts between the element terminals with them connected to the element. If you do not have the proper voltage then you will need to replaced the EOC.
Apr 18, 2014 | Maytag MER6772 Gemini Electric Kitchen...
Kitchenaid superba stove baking element does not heat
There has to be a baking element. Find it and replace it.
Aug 19, 2017 | KitchenAid Kitchen Aid Superba Series...
We have a free standing Frigidaire flat top stove oven that is electric I decided to use the self cleaning feature on it and the bottom element burnt into My husband removed the bottom element before...
I THINK THE HEATING ELEMENT YOU GOT COULD BE WRONG SIZE. I KNOW MINE WENT OUT WHEN COOKING SOMETHING HOTTER THAN I USUALLY USE LIKE 450 DEGREES, IT BURNT OUT. BY CLEANING OUT YOU'RE OVEN, WHICH REQUIRES REAL HOT TEMPERATURES, IT SOUNDS LIKE YOU ON THE RIGHT TRACK. IT BEING OLDER STOVE, A LOWER RATED ELEMENT I WOULD TRY..
Mar 24, 2017 | Kitchen Ranges
I have a Elba Excelence cooker Px906. the lower heating element doesn't work. And the oven doesn't have enough heat. Is the element burnt out? If the answer is yes how can I replace it?
4 elements, 2 top , 1 back, 1 bottom. remove covers in oven to see rear and bottom if they heat.
possibly selector switch fault.
mine looks wired wrong from factory, cant for life of me see how it can heat as display indicates ???????????????????
Oct 19, 2010 | Ovens
My oven will not heat up. When I turn the oven on the lights indicate that the oven is on but it never heats up. The stove works fine.
check the back element to see if it is burnt out ...this is most likley the problem use a flash light to inspect ..to replace the element unplug range..remove racks remove the 2 screws holding the element.. in the back of oven..remove screws on the element to dissconnect the wires ../install new element ..take the back off the range to view all them wires an switches inspect all the wires an switches ..look for burnt wires or broken wires .P/S inspect all wires an connections if bake element looks fine ...good luck ,.let me know if you need more help../joe/
Aug 29, 2010 | Ovens
My Creda convection oven does not heat up. The
THIS SOUNDS LIKE THE ELEMENTS HAVE BURNT OUT TO FIX FIRST TURN OFF THE POWER THEN LOCATE THE SCREWS HOLDING THE PANEL INSIDE THE OVEN REMOVE ALL SCREWS AND PANEL THEN REMOVE THE ELEMENT FROM ITS PLUG CONNECTION TAKE THE ELEMENT TO A ELECTRIC AND PLUMMERS SUPPLY STORE REFIT ELEMENT AND YOUR OVEN SHOULD WORK FINE .
Nov 20, 2009 | Ovens
My top oven will not heat up...Maytag MGR6775... Anyone know where to start?
IT SOUNDS LIKE THE ELEMENT HAS BURNT OUT ,TO FIX THIS FIRST TURN OFF THE POWER TO THE COOKER , THEN LOCATE THE SCREWS ISIDE THE OVENS BACK PANEL REMOVE AND TAKE OFF PANEL YOU SHOULD SEE THE ELEMENT REMOVE IT FROM THE CONECTOR BY PULLING IT OUT BUT FIRST UNCLIP IT , THEN BRING THE ELEMENT TO AN ELECTIRCAL AND PLUMMERS SUPLY STORE FOR NEW REPLACEMENT THEN FIT NEW ELEMENT AND YOUR OVEN SHOULD BE LIKE NEW, GOOD HUNTING.
Nov 17, 2009 | Maytag MGR6775 Stainless Steel Kitchen...
Fan runs no heat from element
IT SOUNDS LIKE THE ELEMENT HAS BURNT OUT , REMOVE THE BACK PANEL FROM THE INSIDE OF THE OVEN BUT FIRST MAKE SURE THE POWER IS OFF WHEN THE PANEL IS REMOVED DISSCONECT THE TWO WIRES FROM THE HEATING ELEMENT TAK IT TO A PLUMMERS SUPLY STORE FOR REPLACEMENT , REPLACE NEW ELEMENT AND YOUR OVEN SHOULD WORK FINE .
Nov 16, 2009 | Ovens
Broiling works but baking does not work
CHECK FOR 240VOLTS AT THE TERMINALS OF THE BAKE ELEMENT. GAIN ACCESS BY REMOVING THE BACK PANEL OF THE RANGE. SOMETIMES THE TERMINAL WILL BURN OFF OF THE WIRE GOING TO THE ELEMENT. THE WIRE WILL JUST BE HANGING THERE. BE SURE TO UNPLUG THE OVEN BEFORE REMOVING BACK PANEL. IF THE WIRE IS BURNT, REPLACE THE TERMINAL AND REATTACH TO THE ELEMENTS TERMINAL. IF THE TERMINAL IS DAMAGED, REPLACE BAKE ELEMENT.
IF THERE IS NO VOLTAGE TO THE ELEMENT, REPLACE CONTROL.
Apr 03, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire Gallery GLEFM397DS Electric Kitchen Range Logo
499 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
