Question about Sony KP-57WS500 57" Rear Projection Television
Sony rear projection screen is red then tv shuts off
We have a 6 year old Sony KP-57WS500. The screen suddenly went red while watching then shut off. When you turn the tv on the screen is red with some arc lines, then all red but you can make out the picture underneath and can hear sound until it shuts off. The timer/standby led blinks. Any suggestions would be greatly appreciated.
  • 1 more comment
  • klafleur Feb 13, 2009
    cbuchin- We have the EXACT same TV and the same thing happened to us on Tuesday of this week (Feb 11, 2009). The TV is about 6 yrs old also. Our TV goes completely blue and shuts off. Prior to Christmas we were having a problem with the color and we had a repairman in who was able to fix that for $75 by modifying some dials. We tried to see if we could replicate what was done prior, but it seems like they are separate problems. What did you do? We are bummed about having to buy a new TV. There is expense in the TV and in getting the space re-built / re-worked to accomodate the flat panels with no speaker system. Let us know what you decided to do when you have a moment.
  • Anonymous Feb 17, 2009
    Same Tv same problem ill let you guys know if i can fix it
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Its failure of Red Gun in TV.
    Red Gun replacement will cost you much (if available some where) and new TV is better option.
  • 201 Answers
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Posted on May 02, 2009
Sony kp-65w5500 rear projection TV red tube needs replacement
there is a company called Video Display Which sells rebuilt tubes
Jan 19, 2009 | Sony KP-57WS500 57" Rear Projection...
2 separate colors on screen
sounds like your convergence IC's have finally gone bad.. they seem to last 5 years on average.. have a look here:
Dec 19, 2008 | Sony KP-53V75 53" Rear Projection...
Sony KP-57WS500 rear projection red screen
sounds like the red crt is bad, you can get a replacement at the following link, if your not sure which one you need just leave them a email with your model number and what youre needing.
Sep 07, 2008 | Sony KP-53S65 53" Rear Projection...
My tv too had a blue screen problem. Then it started to shut down after staying on for less than a minute. I thought that I would with a huge repair bill but I followed the directions at this link: and now my tv works perfectly.
May 01, 2008 | Sony KP-57WS500 57" Rear Projection...
Blue screen flashes and the tv shuts off
You will need a service manual you can get one here it could be the tube, video or numerous things. Your service manual is available at the following link. Plus online support
Jan 07, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500 57 inch TV
Probable convergence IC failure = replace both for reliability..T.
Nov 24, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony 57 in Rear Projection TV
If the picture is playing fine and you notice that the background is getting more and more red, until it is too red and the set shuts down, it could be that the red screen control is set just a bit too high. If this is the case, you can probably correct this yourself. If you are watching a perfect picture and then it suddenly flashes a very bright red, with thin red lines in the pictureand then shuts down, it usually means that the red picture tube has developed a short in it, between the cathode and heater. A good tech might be able to remove the short by arcing, but if the short persists then the red tube will have to be replaced. Either way, this is something that should only be done by a qualified tech.
Aug 27, 2007 | Sony KP-57WS500 57" Rear Projection...
Rear projection tv flickers green/shuts off
rodman, i just started having the exact same thing on my Sony (same model). it's about 5 years old. did you ever find a solution?
Dec 10, 2006 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
755 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
