Question about Epson Stylus C88 InkJet Photo Printer
Extra horizontal lines on my document.
I did the alignment and changed the black ink cartridge, but extra black, horizontal lines continue to appear on my document. Thanks!
  • Anonymous Feb 21, 2009
    I tried all of your suggestions but I still have the horizontal lines.
    Thanks for trying!
  • 353 Answers
Have a real good cleanup of the ink that was (presumably) leaking from the old black cartridge. Remove the cartridges from the cartridge carrier and use kitchen paper towel to soak up any ink in the bottom. Give the cartridge outlet holes a dab on the towel as well. Replace the cartridges promptly.
Turn the printer on, and as soon as the print head moves, pull the power cord out of the back. You should now be able to (carefully) move the print head by hand. Place a layer of paper towel on the printer track, and move the print head across it to mop up any surplus ink. Move the print head across to the left out of the way and use kitchen towel to mop up surplus ink in the Print Head parking area.
Now turn the printer on and carry out a cleaning cycle (right click the little printer icon in the bottom right corner of the screen and select clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Are there any extra black lines in evidence now? If so, try another 1 or 2 cleaning cycles and nozzle check. Black lines gone now?
If you still have the black lines, come back with a new comment.
If this information is useful to you, please rate it.
Posted on Feb 15, 2009
Lexmark X4650 InkJet Printer black prints fuzzy. Color is fine, but the black appears out of focus.
Try to check and make sure your black ink level is still good and not about to go empty. On the printer operator panel, press the Setup button > Maintenance > Ink Levels.
If the black ink level is still good, make sure the cartridges are aligned. Try this approach. On the printer operator panel, press the Setup button > Maintenance > Align Cartridges. Your printer will then print a page forcing ink through the cartridge nozzles and clean them as well as align the cartridges.
Try to print a document again to verify that the print quality has improved.
Oct 11, 2011 | Lexmark X4650 InkJet Printer
I ran out of both black and color ink. I replaced the black ink b/c I do not print in color. But I cannot complete the alignment steps without the color ink.
Lexmark printers usually require both cartridges to have ink left in them to continue printing. But try to press the Cancel button for the Alignment process (this is not recommended). Then try to print a document again to verify that you are able to continue printing without an empty color ink.
If that doesn't help, I would suggest you replace your color cartridge with a new genuine Lexmark cartridge.
Sep 12, 2011 | Lexmark X2690 All-In-One InkJet Printer
How to refill hp deskjet 1560 black cartidge
Hi
check here
Pls vote us to keep us alive
Nov 09, 2010 | Office Equipment & Supplies
Fine horizontal dashes in black have begun appearing all over the pages whether I print in b&w or color. This gets worse with each page in a long document. Samsung CLX-3160.
Your problem is the black toner cartridge pickup drum has become scratched and is depositing "extra" black toner onto the paper prior to the fuser roller. you need to replace the drum and all should be ok then
Jul 23, 2010 | Samsung CLX 3160fn All-In-One Printer
Horizontal red lines on colour and black/white prints
in the head of the printer in which the cartridge is installed there r very minute holes if that hole is slightly cracked on its side it may lick the extra ink from the cartridge that results in the lines on the prints.or the other problem is thatr the printer needs servicing .
Jan 04, 2009 | Epson Office Equipment & Supplies
HP Deskjet F380 won't print
i think the inside printer have dirt or obstacles that blocken the cartridges while printing.
try to clean manually the printer by using powerful air blower,repeatedly.
Sep 14, 2008 | HP DeskJet F380 All-In-One Printer
Black printing morphs into red after black ink cartridge installation
Your printer creates it's black by using ALL the colours together. This effectively gives a very dark purple rather than black.
It sounds like you have a colour cart that is drying up or may be struggling to get enough air into the cartridge. Make sure you have removed any tape over the vent holes if you are using compatible inks. If not then try running a couple cleaning cycles via the button panel/driver.
If you alter the settings in the driver by going into START - PRINTERS AND FAXES and then right click on your 2610 and select PROPERTIES - the changes you make in here will be set as the default settings for each print job.
Oct 17, 2007 | HP Photosmart 2610 All-In-One InkJet...
Epson Stylus C88 InkJet Photo Printer Logo
552 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
