Question about Itronix GoBook III IX260 Notebook
I need to solve a problem with the power conector of a INTRONIX IX260, but it has been very dificult to open it and reach to the connector. Does any of you know where to get a disassembly drawing of it.
I have an Itronix IX260 which will not switch on. The Power Cable is working fine any ideas what it could be?
Take out the memory boards. See if it boots to bios. If it does turn it off and put the memory boards back in. Should be fine after that.
Nov 20, 2010 | Itronix GoBook III IX260 Notebook
MY LG SUPER MULTI GH22NS50 DRIVE IS NOT RECOGNIZE WHERE DO I GET DRIVERS OR HW DO I GO ABOUT SOLVING THIS PROBLEM? IM USING VISTA
Windows 2000 & XP & Vista & 7 all contain the necessary device-driver software for CD/DVD units.
Open "My Computer" -- the device should be listed.
Open "Device Manager" -- the device should be listed.
If not, does the tray open/close when you press the button on the face-plate? If not, there is no electrical power reaching the device.
Check the SATA "power" connector.
Try using a different power-connector from the power-supply to the device.
Sep 15, 2010 | LG GH22NS50 22X DVDRW SATA Drive OEM...
Problem with panel front conector in Dell Dimension 2200 motherbo
The following information is to assist you in performing the right connections. You should take precautionary measures such as grounding yourself and completely disconnecting the PC form any source of power.
This picture shows the connector for the front panel power button, reset button, and power and hard disk lights: an 8x2 pin connector with 1 pin missing:
The table below lists the pinouts for the connector. The orientation of this table is the same as the picture above, this shows the top part of the connector. All the pins below pin 8 appear to be non-connected.
Each pair of pins labeled Power and Reset goes to the 2 wires for the corresponding button. The hard disk and power LED wires connect to the corresponding LEDs, you need to ensure the proper polarity of the + and - wires for each LED or it will not illuminate.
The above information is for your information only.
Mar 01, 2010 | Dell (2M502) Motherboard
When I turn on the camera, the display is black and I can only read the menu info: no images at all! HELP!!
I just solved the problem. The lens system wire connector to the main pcb was out of this female conector. Only you need its disassemble the camera and in the back of the lcd there's the conector, press it with carefully and test your camera.
Dec 25, 2009 | Olympus FE-290 Digital Camera
Need diagrams of the conectors for speakers and power , I lost de conector wen I sale de car,
Find your radio connector detail  on this website (on the left is a Menu)
Example...this ids for FORD
http://www.tehnomagazin.com/Auto-radio-car-connector/FORD-Car-Radio-Wiring-Connector.htm
Dec 14, 2009 | Eclipse Car Audio & Video
Black screen/no images
Dec 01, 2009 | Olympus FE-290 Digital Camera
IX260 hard drive
Hi:
I am reasonably sure that the hard drive accessed thru the battery compartment. You remove teh battery cover, remove the battery, and the hard drive is then able to be removed.
Nov 06, 2009 | Itronix GoBook III IX260 Notebook
I can not attach a new HDD to my itronix IX260 (Gobook II)
Post a photos of your HDD and original one, which was installed in your laptop if you can, and maybe we can help.
Nov 17, 2008 | Itronix GoBook II Notebook
Computers & Internet Logo
162 people viewed this question
Top Itronix Computers & Internet Experts
Steven Wander
Steven Wander
Larry Chandler
justwinwin
Are you an Itronix Computer and Internet Expert? Answer questions, earn points and help others
