I cant seem to turn on my avanti portable washer..
  • 15,935 Answers
If there is power to the outlet the machine is plugged into...It appears your timer has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
My avanti w798ss1 take in water then its does do anything?
Check the water pressure switch in the panel. it has a clear plastic tube in it if u remove the tube place a small pc of tubing into the switch while u have it on wash cycle, then blow into the tube connected to the switch if it goes into wash u may have a bad tube clogged or a pin hole in it. if it does nothing u have bad water pressure switch diaphfram
Mar 07, 2015 | Avanti W798SS1 21" Portable Top-Load...
Avanti portable washer w798ss does not spin
Spin clutch is bad, costly repair
Oct 27, 2014 | Washing Machines
Washer not fully drained before spin cycle then get error message E-5
somethink is blocking the pump , u need to take cover of see what it is?i say its money?
Apr 20, 2014 | Avanti W7571 21 Portable Top Load Washer...
Avanti w798-ss e3 error
It seems there is a fault on the main controller unit of the washer. It seems to start and then drain off in mid cycle. Now choose a different program and see if there is any change. Also check individually the inlet valve, the water level sensor and also the drain valve. Also check all the connections to the main panel.
Mar 13, 2012 | Avanti Top Load Washer W797
Avanti portable dryer - drum does not rotate
The belt is broken . Call Avanti to get it fixed or take it back and get it replaced .
Oct 11, 2009 | Avanti Dryers
Avanti spinning problem
One of the largest problems with this washer has been the lid switch, you must check it out with a ohm meter, if the switch quits you will lose power to the motor. Things can get caught between the tanks as well, this machine is bad for the center bearing tightening up and the spin will quit. This is a new close up pictureof a typical lid switch. You can temporarily join the wires together to test the motor and washer operations.
Apr 03, 2009 | Avanti W789SA Top Load Washer
Avanti w798ss doest start
Close the lid! There's a sensor on the back hinge of the lid. Make sure its working. You should hear a small click when you close the lid.
Nov 08, 2008 | Avanti Top Load Washer W797
Avanti W852 Parts??
It's going to be hard finding parts for this machine because I have one as well. You can search the internet or call the company. The last time I had problems with my machine the company told me they stop making parts for this particular brand. Don't give up looking for parts, maybe someone else sells the parts for this washer. Good Luck!
May 28, 2008 | Avanti W852 Top Load Washer
Avanti W797: Tub won't spin or water does not empty.
Had the same problem. The water pump is not working and since it cant drain water it wont spin. A easy fix. There's a magnet located on the water pump thats comes lose. Simply tie it back into place.
Nov 20, 2007 | Avanti Top Load Washer W797
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
