Question about Sewing Machines
After replacing the bobbin on my sewing machine it went to E1 ERROR and I can't get it cleared.
    New Friend:
  • 186 Answers
Make sure the bobbin winder is not engaged. If this doesn't help, let me know the model and make.
Posted on Jan 30, 2009
My Janome sewing machine 4900 is showing error E1 how do I fix it.
try these suggestions
change the needle--normally flat side goes to the back of the machine
rethread the machine top & bobbin
make sure the bobbin is wound correctly & that the bobbin is inserted
correctly in to the bobbin case
also make sure that the bobbin spindle is in the position to the left when not in use
clean under the needle plate & in the bobbin area for lint or loose threads
if none of these suggestions work then the machine needs to be checked
Apr 10, 2012 | Sewing Machines
Janome meory craft 4900 showing E1 error mesage
have you tried changing the needle?
clean under the needle plate for any loose threads or lint
inserted correctly in to the bobbin case
if none of these suggestions work, then the machine needs to
be serviced
What does error E1 mean on a brother CS6000i
hello,the E1 code simply means the machine is working so hard,you can follow the information below to help you fix the problem,
The instructions for bobbin winding tell you to click the start button for the bobbin to wind. When you do that you get that E1 with a beeping. What they don't explain is that in order to press that "UP" arrow button to get the bobbin to wind..........you need to UNPLUG the foot control. So, in other words it to be used for sewing w/o a foot pedal. Now instead of doing as per instructions, assuming you've plugged everything in (foot pedal), after winding is finished just press the foot pedal and your off and running or sewing as the case may be. BTW, look it up in the TROUBLESHOOTING SECTION OF YOUR MANUAL.
please kindly rate the solution if it;s helpful,
take care.
Jun 06, 2010 | Brother CS6000i Computerized Sewing...
Singer Furtura E1 error message.
Hopefully, you didn't use any bobbins that weren't specifically meant for this machine. Here's the joke-there are special bobbins that that this machine only works with. And anything else gives you a mess.
They're not terribly easy to find, but they are available on eBay. Do a search for Singer Futura CE100 bobbin under crafts. I just bought a bunch from a place called World Weidner in Oklahoma through there. This will hopefully take care of your problem.
Wish I had been on here answering posts for you a number of months ago. If this doesn't help, please leave me a message in comments. If nothing else, I'll buy the bobbins back from you.
Jan 16, 2010 | Singer CE-100 Futura Computerized Sewing...
E1, E2 error messages after needle breaks. Cleaned everything as good as possible, still getting message. I have a Kenmore Model 385.19233
Theirs a problem with the fuse on those machines. The e1 indicates that a fuse has been blown. check out the link for more details.
http://www.sewingmachineryrepair.com/forums/index.php?topic=79.0
Aug 31, 2009 | Kenmore 19233 Computerized Sewing Machine
Lost the clear cover that snaps over the bobbin
hello it is called the hook cover plate. go to kenmore .com check accessories
Mar 06, 2009 | Kenmore Drop-In Bobbin 16231 Mechanical...
My Janome Harmony 8048 sewing machine came up with an E1 error. My manual says that this means that the machine is out of order. I've noticed that if the needle is lowered and then turned on, it will...
make sure the bobbin winder on the top of the machine is all the way to the left. otherwise the machine thinks you are trying to wind a bobbin and sew at the same time.
Jun 29, 2008 | Janome Harmony 2041
Sewing Machines Logo
133 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
