Question about General Electric Microwave Oven
I am trying to find the wattage of the Hotpoint Model JES636WKO1. Thanks
  • GE Master
  • 9,098 Answers
According to the owner's manual (page 11) it is 700 watts.
Posted on Jan 30, 2009
What is the wattage
it all depends on what you're trying to measure, the wattage used or the wattage output. the handbook will tell you these figures. if you don't have the handbook, you can google for it using the model number and the word manual
May 03, 2015 | Microwave Ovens
Jes636wk01
you must read in the back label the specifications of how many Watts, maybe can be .1100watts -to 1800watts or use the formula
P=e voltaje x i anp= watts,
God bless you
Jul 20, 2013 | Hotpoint RVM1435 Microwave Oven
Microwave oven wattage question
hi, you are correct it is 950 watts as you have read this on the microwave itself, when they sold these they kept the same model number but as they bought newer ones out the wattage increased so they kept the same number so its nothing to worry about it was just yours must have been a newer model then the first ones they made.
the first ones they made started at 700 then they did an 850 then a 950 so you are right its just a case of giving the same model number as the only difference is the wattage everything else is exactly the same, you wouldnt tell the difference if you had them side by side as its only the wattage that changed on this model
Jul 10, 2010 | GE JES735WJ Microwave Oven
Wattage Power
Unfortunately, the old owner's manual doesn't say, but you can do a test to see what its heating power is:
MICROWAVE HEATING POWER TEST
The following test will provide a suitably accurate measurement of the output power of any microwave oven. Variations or errors in performing this test will produce uncertain results. If the line voltage (from the electrical outlet) is low, the magnetron output will be correspondingly low.
Equipment needed:
- Microwave safe container with 1000 mL (1 Liter) gradation.
- Fahrenheit or centigrade thermometer
Procedure:
Pour exactly 1000 mL (1 Liter) of cool tap water into the container. Using the thermometer, stir the water, then measure and record the temperature. For accurate results the water should be about 60 degrees F (20 degrees C).
Place the container on the center of the oven cooking shelf (do not leave the thermometer in the container and remove any metal racks), and heat the water (at full power) for 63 seconds. Use the second hand of a watch, not the oven timer.
After the heating time is completed, immediately remove the container, stir the water, re-measure and record the temperature of the heated water.
Subtract the starting water temperature (step 2) from the ending water temperature (step 3) to obtain the temperature rise.
To determine the output power in watts, multiply the total temperature rise by a factor of 38.75 if you're using a Fahrenheit thermometer or by 70 if you're using a centigrade thermometer.
Apr 28, 2010 | Hotpoint RVM1435 Microwave Oven
Wattage Sharp Microwave Ovens Carousel Model R-3A35
i just checked my R-3A36 manual to find out the wattage. it's 800 watts. i make pralines in my microwave. i am always asked for the recipe. so i needed to be able to tell people the wattage of my oven so they can adjust the recipe to their oven.
garry, metairie,la.
Oct 06, 2009 | Sharp Microwave Ovens
I have a new job and I am here alone. There is a
the magnatron has gone bad and needs to be replaced
Sep 17, 2009 | Microwave Ovens
F3 Message given from my GE jvm1650wb008 Microwave!
WATTAGE AND CU.FT IS UP TO YOU. JUST MAKE SURE WHAT YOU GET FITS LIKE THE OLD ONE DID DIMENSIONS WISE. THE HIGHER THE WATTAGE THE FASTER THEY COOK AND HEAT FOOD UP.
Apr 08, 2009 | GE JVM1650 1000 Watts Microwave Oven
Changing the fuse in microwave hotpoint mosel JES636WKo1
This model seems to have a fuse in a cylindrical white nylon fuse holder, probably located near the right rear.
It will also have a thermostat on the magnetron which may be out.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here or here.
Aug 18, 2008 | General Electric Microwave Oven
Microwave makes a loud noise while using.
Could you describe the noise?
It may be a noisy fan motor or a failing magnetron or high-voltage transformer.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Oct 13, 2007 | Microwave Ovens
General Electric Microwave Oven Logo
81 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
